Getting flywheel off?
10 replies to this topic
#1 _Liam_
_Liam_
Posted 12 September 2011 - 07:40 PM
Hey guys on Friday I was trying to dismantle the 253 to get it on the stand to clean up etc, but can't (don't know)get flywheel off. It's got the shallow headed bolts in the centre is that how it comes off? Bugger keeps spinning as I try to take it off... Will put a socket on the crank nut and that should stop it turning so I can attack the flywheel bolts?
#2 rodomo
  • 18,031 posts
Posted 12 September 2011 - 07:43 PM
6 x bolts with 11/16" heads?
Yes, undo those.
#3 _CHOPPER_
_CHOPPER_
Sounds like that should work.
#4 _Mint_
_Mint_
Posted 12 September 2011 - 07:50 PM
stick one of the bellhousing bolts in the block..on the left side looking at the flywheel..then a large flat blade screwdriver in one of the teeth and then get a decent breaker bar on there
or a rattle gun
#5 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
throw a bellhousing bolt in,and get a decent size flat tip in the teeth of the flywheel against the bolt to help stop the flywheel turning while your trying to crack the bolts
#6 _Liam_
_Liam_
Posted 12 September 2011 - 07:53 PM
Cheers fellas will do that. I'm going to get the 253 running so anyone can rock up to buy it running... Worth more I'd imagine, Anyone want an Aussie 4 speed?
#7 dattoman
  • 16,487 posts
Posted 12 September 2011 - 10:08 PM
Or you could make one of these
#8 76lxhatch
  • 7,202 posts
Posted 12 September 2011 - 11:10 PM
The V8 flywheels normally have a hole right through which you can just push in a suitably sized old bolt so it grabs on the skirt of the block to stop everything moving
#9 rexy
rexy
  • 3,715 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 12 September 2011 - 11:40 PM
Long thin phillips head screwdriver through one of the small peripheral holes in the flywheel works a treat.
#10 _CHOPPER_
_CHOPPER_
Posted 13 September 2011 - 12:39 PM
Nice pic Neil.
#11 _bathurst-racer_
_bathurst-racer_
Posted 13 September 2011 - 09:34 PM
Just use a bearing shell on the ring gear and hard up against something protruding from the block such as a dowel or bellhousing bolt.
