UC 5000
#51
Posted 01 April 2012 - 10:49 PM
Here's the V8 commo booster and the original 4cyl starfire one (note the studs on the commo one are thinner) -
Measured then cut the ends off each booster -
Welded the Torana end onto the commo booster. Don't let the rod get too hot, I wrapped a soaking wet rag around it while I welded it -
All bolted up. I used some big flat washers on the booster so the smaller nuts wont pull through the firewall. And as a bonus because the UC is late '79 and originally had a metric master cylinder with built in prop valve, all the brake lines screwed straight on...
#52 _V6 UC_
Posted 03 April 2012 - 04:14 PM
#53
Posted 04 April 2012 - 02:10 PM
#54
Posted 19 May 2012 - 08:09 PM
We've also started on the engine wiring by running the ecu harness into the cab from under the blower motor -
Got the whole of next week off so we should make a lot more progress on the old 'bird...
#55 _alchemist_
Posted 25 May 2012 - 10:22 AM
#56
Posted 25 May 2012 - 11:30 AM
#57
Posted 25 May 2012 - 12:37 PM
Looks good mate, keen to suss out your conversion I'll be doing the same soon. I'm in Warnbro!
Cool you're not far from us. Feel free to ask about anything if you need to.
Nice, where did you mount the reservoir for the pump?
I'll probably mount the reservoir next to the air box, depends how crowded that side of the engine bay looks after mounting the ignition module and running the engine loom etc. I'm not hiding wiring etc, just going for a neat look.
#58 _berro59_
Posted 25 June 2012 - 07:13 PM
Now we just need to get them registered with a v8! Keep me posted you are a closer than me.
#59
Posted 25 June 2012 - 07:39 PM
#60
Posted 09 July 2012 - 07:44 PM
The engine bay is getting crowded, I'm hoping the charcoal canister will squeeze between the radiator and battery, then I've got the air box and p/s reservoir going on the other side. Not sure if the engine relays will fit in there somewhere, I might have to run them under the dash maybe.....
#61
Posted 09 July 2012 - 10:14 PM
Put the charcoal canister under the battery
#62
Posted 09 July 2012 - 11:43 PM
#63
Posted 10 July 2012 - 07:28 AM
Edited by Neils LX, 10 July 2012 - 07:30 AM.
#64 _alchemist_
Posted 10 July 2012 - 08:03 AM
#65
Posted 16 July 2012 - 12:45 AM
A small hole with a grommet for the wiring and coil lead to go through
Beats the original Commodore coil location...
#66 _UCV80_
Posted 16 July 2012 - 08:59 PM
Are coils waterproof? Might get wet where it is.
#67 _alchemist_
Posted 17 July 2012 - 10:52 AM
Cheers Berro, hopefully that article you posted was bs, I used to have modified cars licensed all the time and I've never heard of anything preventing a V8 UC from passing. Mind you that was 7 or 8 years ago and the rule's have changed since then so . I was planning to have mine inspected in Rockingham because they (transport) outsourced the vehicle inspections to a few local mechanic shops and sometimes they're a little more lenient than DOT run inspection pits.
My UC was passed with flying colours from 4cyl to 8cyl without engineering or anything at Welshpool. Was no dramas at all.
#68
Posted 17 July 2012 - 01:19 PM
You've been busy! been a while since iv had a look at your thread. Looks good!
Hmmm good call, I was thinking it shouldn't get much water on it with the wiper plenum on, but it might be worth putting a plastic cover or something over it.
Looking really cool now mate, you've progressed heaps!
Cool, I was hoping it wasn't going to be too much hassle, how long ago did you have yours passed?
#69 _alchemist_
Posted 17 July 2012 - 09:27 PM
Previous owner did it, but was almost 4 years ago.
#70
Posted 29 July 2012 - 09:04 PM
Also fitted a T-piece for the oil pressure gauge sender and the efi sensor
Did a bit of other stuff too but nothing worth posting pics of. We did pick up some more parts yesterday from another member -
Guess where they came from hehe
#71 _alchemist_
Posted 01 August 2012 - 12:33 AM
#72
Posted 09 August 2012 - 07:07 PM
This schematic is a hand drawn copy of a conversion harness we bought once for a previous project from a 'professional' conversion specialist (who shall remain unnamed ). Now we use it as a reference when making our own neater, simpler, easier to fit harness.
So far it looks like this -
All I need to do now is trial fit it and then tape it all up once I'm happy with the fit.
And here's the leftovers from the VN engine bay harness that I don't need (except the ECM) -
Once that's done I'll sort out the fuel pump and then its vroom vroom time....
#73
Posted 17 August 2012 - 01:21 PM
Here's a blurry phone pic of the sensor and loom, and a new speedo cable to match -
Not sure if I'll use their loom or maybe splice it into an original gbox loom so I can keep the factory plugs....
#74
Posted 18 August 2012 - 10:38 PM
We've taped it now and just need to splice the Torana plug on the end then refit it tomorrow.
We also added a new vacuum outlet for the brake booster in a more accessible location at the front of the manifold. We drilled and tapped a thread and fitted a booster fitting off a commo V6. I wasn't comfortable trying to cram the hose down the back of the manifold with all the other stuff back there, it was just too damn crowded....
#75
Posted 28 November 2012 - 07:36 PM
NOS mint condition blue UC crashpad still in the Holden box anyone?!?
I'm stoked! I've been chasing one of these for ages....
