UC 5000
#126
Posted 01 April 2019 - 06:30 AM
Keep plugging away but by bit you doing good work,
#127
Posted 22 April 2019 - 07:34 PM
Rusty bit removed, donor patch ready to weld in (my phone's camera sucks, always blurry) -
20190422_165354.jpg 133.96K
7 downloads
20190422_165529.jpg 190.11K
8 downloads
#128
Posted 26 April 2019 - 08:18 PM
Patched the holey area at the bottom left corner, its hidden by the beaver so it doesnt need to be pretty - just strong!
20190426_160420.jpg 153.81K
5 downloads
Tacked the new(ish) tail light section in. Ran out of daylight but if I have time I'll finish it tomorrow
20190426_173105.jpg 134.53K
5 downloads
#129
Posted 29 April 2019 - 01:16 PM
Getting there, good work. Do you have much more rust to cut out after the rear end is done? Looking back through your thread the front looks pretty much done.
#130
Posted 29 April 2019 - 01:33 PM
The front is pretty good, there's a bit on the rh rear wheelarch (should be able to cut most of it off when fitting the flares) and a couple of small bubbles on the sills. The back was so bad because it was hit and just bogged up, the bootlid seal was no longer sealing properly and just let heaps of water in. Luckily the bung in the spare wheel well was removed at some point or I'm sure that would have been rotten too!
#131
Posted 05 May 2019 - 11:24 PM
Cleaned it all up, took off the old paint and gave it a coat of etch primer. Ended up digging out a fair bit of filler from the centre around the fuel cap, thats gonna be fun to straighten..
20190505_161223.jpg 118.08K
11 downloads
Tried it with some tail lights, just for fun
20190505_163837.jpg 122.45K
11 downloads
Little bit of rust to fix on the bottom lip, and some tapping with the hammers and dollys to get it straightish (will probably still need a skim of bog). Then its beaver time!
20190505_161545.jpg 101.99K
10 downloads
#132
Posted 06 May 2019 - 08:37 PM
#133
Posted 07 May 2019 - 12:29 AM
I have a new beaver panel ready to go, I forget where I bought it? Suits LH LX - slight difference in the UC sedan boot floor shape but close enough to make it work.
#134
Posted 16 June 2019 - 07:26 PM
Patched the last bit of rust on this lip -
20190518_151448.jpeg 32.78K
5 downloads
Test fitting the beaver, went on and off quite a few times for trimming and tweaking -
20190616_120030.jpg 131.27K
5 downloads
Once I was happy with the fit I tacked it on and started welding -
20190616_161254.jpg 139.97K
5 downloads
I'll finish welding & grinding and get some primer on it next weekend.
#135
Posted 23 June 2019 - 11:24 PM
Well that was a long weld -
20190623_162811.jpg 112.87K
4 downloads
Looks good with a bit of epoxy primer on it. Next I've got to fix this gap -
20190623_162811gap.jpg 261.3K
4 downloads
#136
Posted 02 January 2020 - 03:28 PM
Had to remove this little bootlid latch panel so I could get behind it and straighten the top lip area
20200101_125407.jpg 138.16K
4 downloads
Managed to get it looking pretty straight, a bit more tweaking and I can weld the latch panel back on.
20200101_151259.jpg 130.91K
4 downloads
I also put my good bootlid on and managed to get it lined up pretty evenly, decent gaps etc.
#137
Posted 08 January 2021 - 12:11 PM
How was the fitments of the front spoiler you bought?
#138
Posted 08 January 2021 - 12:47 PM
Very slowly - its hotter than hell here at the moment so probably no more updates until it cools down a bit.
That front spoiler came off Burty's car, I'm not sure where it was made but it fits great - probably the best UC spoiler I've seen!
#139
Posted 08 January 2021 - 03:22 PM
