G'day,
I'm after a new brass bush (main shaft) for a 'Bosch Electronic Ignition Distributor' off a V8 blue motor. Bosch don't make them any more, so it seems the only option I have is to manufacture one... I thought maybe someone here may know of some available or of another option...
I hope we haven't covered this in the above pinned threads.... I did look.... I promise...
A bush for my Dizzy
_napes_au_
, Sep 16 2011 08:28 AM
1 reply to this topic
#1 _napes_au_
Posted 16 September 2011 - 08:28 AM
#2 _hutch_
Posted 16 September 2011 - 08:51 AM
What i done when faced with this problem was to bore the bush still in place in the distibutor and fit 2 new bushes IE if the existing bush outter diameter is 16 mm and the shaft is 12 mm you can fit a bush with and outter diameter of 14 mm,most of of the dizzies i fixed had one fairly long bush from memory about 50 mm long
Phillip
Phillip
