Breather problem
15 replies to this topic
#1 _napes_au_
_napes_au_
Posted 24 September 2011 - 08:07 PM
I've got my engine back in and I'm a little concerned about the lack of room for a breather pipe on the passenger side rocker cover...
There's only around 21 mm gap between the rocker cover and the fan box and the elbow is just touching...
I'm not sure if this is right as when I bought the car it had alloy covers and I've since replaced them with stock standard ones...
Any thoughts on how to deal with this problem? Maybe make a lower profile elbow out of copper???
#2 _Bomber Watson_
Posted 24 September 2011 - 08:11 PM
Swap your rocker covers left to right???
#3 _napes_au_
_napes_au_
Posted 24 September 2011 - 08:18 PM
G'day,
But the PCV goes in the front of the other rocker cover.
So if I swapped them, the breather hole would be in the exactly same place and the oil filler cap will be on the wrong side..... But thanks for the input....
#4 _CHOPPER_
_CHOPPER_
Posted 24 September 2011 - 08:25 PM
HQ - HZ and Torana 253/308 rocker covers had the PCV hole at opposite ends of the covers. Looks like you have the wrong ones.
#5 _napes_au_
_napes_au_
Posted 24 September 2011 - 08:49 PM
G'day,
I hope this doesn't come across as rude, but I disagree....
Here are a couple L-34 engine bays with the PCV's on the same side as my LH L-31.... And the filler cap is the same as mine as well....
Thanks for the feed back
#6 _CHOPPER_
_CHOPPER_
Posted 24 September 2011 - 09:07 PM
Well I'm sure they are different, so I'm buggered if I know why you have that clearance problem then.
#7 S pack
  • 15,668 posts
Posted 24 September 2011 - 09:21 PM
G/Day Napes
You need rocker cover breather outlet, GMH part no. 9932185. It is a low profile design elbow that should clear your heater.
Dave.
Edited by S pack, 24 September 2011 - 09:21 PM.
#8 _diggaman_
_diggaman_
Posted 24 September 2011 - 09:38 PM
I just shaved the rubber grommit a little to give more room.
Not sure if thats a good thing but worked for me.:blink2:
#9 _Mint_
_Mint_
Posted 24 September 2011 - 09:52 PM
S pack is right..the original holden breather elbow is a low profile one..different to what youve got
Edited by lxssv8, 24 September 2011 - 09:53 PM.
#10 _hammondracing21_
_hammondracing21_
Posted 24 September 2011 - 10:16 PM
http://www.ebay.com....=item3cbc2490ad
This is what u need
#11 _napes_au_
_napes_au_
Posted 24 September 2011 - 10:48 PM
Thanks everyone for the advice.... I'm confident it's all sorted as I bought the one off eBay.... :spoton: :spoton: :spoton:
#12 _trna76hb_
_trna76hb_
Posted 25 September 2011 - 07:29 AM
PM mick (sstorana) he has remade the breather for the Torana rocker cover
Ian
#13 _chrome yella_
_chrome yella_
Posted 25 September 2011 - 10:25 AM
it looks like all 3 of those pics have different front breathers, the one i have is like that ebay one except
it is cast alloy, the one on my 5/74 308 sandman engine is cast alloy also.
so which is correct for an L34
#14 S pack
  • 15,668 posts
Posted 25 September 2011 - 10:44 AM
The breathersyou can see on the front of those engines are PCV valves, not the plastic breather elbow that Napes has just bought off ebay.
#15 _napes_au_
_napes_au_
Posted 25 September 2011 - 05:14 PM
Yep, the breather is at the back of the passenger side rocker cover...
#16 _napes_au_
_napes_au_
Posted 02 October 2011 - 06:48 PM
G/Day Napes
Dave.
G'day Dave,
Got the new Genuine GMH Breather fitting and it sure fixed the problem....
SH!T they're a tight engine bay!!!!!
Thanks everybody.... This one had me stumped...
