Hi all...well... as much fun as I was having driving the new rocket.... it was all short lived unfortunately....
As well as it all went... I noticed puffs of blue smoke out the back... not good for a fresh engine.. I had a good hunch of where it was coming from too by the symptoms... anyway... wont bore you with the details so off came the head and this is what I found along the way....
I found oil where it should not be!!!
Anyway... the guys were very good about it all and when they tore it down, they noticed the valve seal, which on a blue motor are "O" rings inside the guide, were not doing anything and oil had the right of way down there into the cylinders.... Due to some mods they did to the head, the standard stuff did not work.... so, they machined all the post's and fitted the old style outside caps and that should sort it....
At work atm so will get it together when Im home...
