I'll show you how to cut hatch back guards from start to finish
108 replies to this topic
#1 Ruts
Ruts
    How Fast!?
  • 1,118 posts
  • Car:Blown A9X replica, Black SS hatchback, LH SLR5000
Posted 08 October 2011 - 07:53 PM
Hi all, I have a fellow forum members hatch arriving next week and the owner wants me to fit a new set of rear flares and cut the guards to fit 15x10 hotwires.The car is owned by Rob350hatch and is already fitted with a full set of flares. Rob has purchased a set of extra wide rear hatch flares and wants me to fit and paint them. The previous guy who put the flares on did a s$#t job of cutting the guards as well as not taking enough of the inner guards to clear big wheels. The job will be done so I will not have to paint any of the car except the near flares as they are not painted. I'll again add all photo's along the way so watch this space, HERE WE GO AGAIN!
Ruts
Edited by Ruts, 08 October 2011 - 07:53 PM.
#2 eyepeeler
eyepeeler
  • 1,959 posts
Posted 08 October 2011 - 08:00 PM
Cheers Ruts in advance for doing that. I will be cutting the guards on my race car soon and it will be good to see how you go about it.
#3 _LS1 Hatch_
_LS1 Hatch_
Posted 09 October 2011 - 09:59 AM
#4 _uctorry_
_uctorry_
Posted 09 October 2011 - 11:29 AM
kool :3gears:
#5 madmax
madmax
  • 67 posts
  • Car:Vf ssv redline ute Walkinshaw enhanced Pedders coilovers
Posted 09 October 2011 - 02:01 PM
will be paying attention on this one B) B)
#6 Tyre biter
Tyre biter
  • 982 posts
  • Car:Should have gone with Palais...
Posted 09 October 2011 - 09:09 PM
...Rob has purchased a set of extra wide rear hatch flares and wants me to fit and paint them. The previous guy who put the flares on did a s$#t job of cutting the guards as well as not taking enough of the inner guards to clear big wheels...
Oh crap - Wish you'd done this thread about three months ago Ruts.:dohdoh:
See, I've ordered and paid for a set of Hotwires (15 x 8 and 15 x 10) but I don't have "extra wide" flares for mine nor did I consider exactly how much needed to be taken out - just cleaned up a previous owner's work and took a little more to do so thinking that should be right...
Like others, I will be watching this one with interest, but unlike most I imagine that I will be one of only a few if not just myself who is now sh%#@ing bricks, hoping I have jagged it somehow...
Cheers, TB
#7 Ruts
Ruts
    How Fast!?
  • 1,118 posts
Posted 09 October 2011 - 09:53 PM
By the look of the your car TB your doing just fine.
#8 Tyre biter
Tyre biter
  • 982 posts
Posted 10 October 2011 - 07:19 PM
Ruts,
Thanks - I hope your best estimate is correct - fingers crossed...
BTW - Did you make it to W2W or following that, PRD on 29th Sep here in Canberra or elsewhere?
Cheers, TB
#9 Ruts
Ruts
    How Fast!?
  • 1,118 posts
Posted 11 October 2011 - 08:47 PM
Car has arrived work starts tomorrow
#10 Tyre biter
Tyre biter
  • 982 posts
Posted 12 October 2011 - 08:31 PM
Ruts,
If I could jump the gun a tad - I've searched but no luck - do you have any tips or methodology to install the rubber beading about the edges of the flares?
Just that I am looking at doing this the next few days and am interested to learn any lessons from those like yourself who have done this before is all.
I am guessing I'll need to cut across the tail of the beading in order to get it to curve nicely?
If so, is there a specific place to do this - ie; either at each bolt hole or between the bolt holes, or not cut at all?
Do you secure the beading with masking tape or similar during this job or even for all time?
Anything else I should be thinking about?
Thanks in advance of whatever advice you can lend.
Cheers, TB
#11 Ruts
Ruts
    How Fast!?
  • 1,118 posts
Posted 12 October 2011 - 09:22 PM
You have the right idea TB. What you do is bolt the flare on the body with NO piping but do not tighten the bolts completely. You have to leave enough room between the flare and body to slid the piping between. You should be able to rattle the flare against the body that way you pull the flare out a tad which helps the piping go in. At every point where there is a bolt you cut a slit in the piping about 2mm wider either side of the bolt and leave about 5 to 10mm down from the piping. What you are actually doing is cutting a rectangle shape out at each bolt location. You then slide the piping in until the piping bead sits on top of the flare. When all the piping is in and you are happy how it sits you go ahead and tighten all the bolts. That's how I do all mine. Hope this helps and if you have trouble understanding what I'm trying to say then drop me a line and I'll take a few pictures for you.
Ruts
#12 Ruts
Ruts
    How Fast!?
  • 1,118 posts
Posted 12 October 2011 - 09:40 PM
Forgot to mention, USE THE SMALL PIPING NOT THE LARGE it looks a better and it's what they used from the factory.
#13 _76LXSS350_
_76LXSS350_
Posted 13 October 2011 - 04:44 AM
Looking forward to seeing you work on this one Ruts. Bought a Repliglass Kit for my SS a few months ago, fitting it is next on the adgenda after the engine bay
Gotta say, it makes me cringe everytime I think of cutting the guards, so I went and bought a couple of desent rubbers to encourage me to fit the bugars..haha
Tell me the repliglass stuff is ok, oh yeh the piping they supplied I suspect is the LARGE, the pipe section is approx 8mm high/wide. Who supplies the SMALL piping?
Anyway i'll be throwing questions at you as you progress...
Cheers for putting threads like this together mate
Grant
#14 GML-31
Posted 13 October 2011 - 06:21 AM
most rubber/foam shops stock both piping sizes
#15 Tyre biter
Tyre biter
  • 982 posts
Posted 13 October 2011 - 07:18 AM
There are two sizes??? :DOH:
Ruts - thanks for your advice and tips - much appreciated, and yes your instructions are understood thanks.
On the size thing - since it does seem to matter after-all... I think mine is the small size (of course it is) given Grant-76LXSS350 has 8mm wide piping - mine is definitely smaller than 8mm so maybe a break for me.
Cheerio, TB
#16 _rob350hatch_
_rob350hatch_
Posted 13 October 2011 - 01:29 PM
[quote name='76LXSS350' timestamp='1318445081' post='628113']
that makes 2 of us :stirpot:
by the way i have a pic of number 14 at bathurst circa 1977 with the fat piping.was it factory or dealer sourced?is it just a case of some got the larger stuff and some got the smaller depending on the supplier,but i do like the smaller one better.but if you hadnt pointed it out to me i would have gone through life not knowing this :blink:
#17 Ruts
Ruts
    How Fast!?
  • 1,118 posts
Posted 14 October 2011 - 08:17 PM
Ok here we go. As stated this car belongs to a forum member and although it has flares already fitted and some guard work already done you can follow the same steps as if you are starting from scratch. Rob's car is a nice LX hatch with flares fitted and is currently running a set of 14x8 hotwires all round. The plan is fit a new set of rear flares which Rob managed to get from a guy who makes the hatch rears 20mm wider than the standard rears. When finished the car will have a set if 15x10 hotwires on the rear and with plenty of room for tyre clearance. I'll explain everything the best I can along the way and like the last post when I cut the sedan rears if anyone has any suggestions to help me along the way then I am more than happy to take on any CONSTRUCTIVE advice or criticism . Please keep in mind that there are many ways guards can be cut and then way I do is not the only way it can be done. Anyway here is the first instalment.
The car arrived and the first thing I did was put in on my new hoist so that I can now work at a reasonable height. Yeeeehaaa no more sore back and knees. Gotta love this garage.
Attached File  Copy of cutting hatch guards 001.jpg   257.33K   9 downloads
Got the car up to a good working height
Attached File  Copy of cutting hatch guards 008.jpg   192.86K   5 downloads
Attached File  Copy of cutting hatch guards 007.jpg   187.57K   3 downloads
When the car was up I could see that someone has tried to guard and bend the guards in the past. Rob said that even with the 14x8's the tyres would rub.
Attached File  Copy of cutting hatch guards 006.jpg   135.69K   4 downloads
Attached File  Copy of cutting hatch guards 005.jpg   180.12K   3 downloads
This car is also fitted with the ugly large flare piping which I will be changing front and back
Attached File  Copy of cutting hatch guards 009.jpg   153.03K   5 downloads
Attached File  cutting hatch guards 015.jpg   103.07K   3 downloads
Attached File  cutting hatch guards 013.jpg   184.38K   4 downloads
Take the wheels off
Attached File  cutting hatch guards 014.jpg   164.18K   3 downloads
Now the plan is to take the standard width rear flares off and replace them with extra wide rears. I must say that these new rears are the goods. These are some the best quality rear flares I have seen in a long while and to top them off they are 20mm wider than standard. Might save $$$ on getting diffs shortened.
Attached File  Copy of cutting hatch guards 012.jpg   188.86K   5 downloads
With the original rears removed you can see the difference between the two
Attached File  cutting hatch guards 023.jpg   132K   3 downloads
Attached File  cutting hatch guards 022.jpg   141.79K   2 downloads
Attached File  cutting hatch guards 024.jpg   213.39K   3 downloads
By the time they go on we will be able to fit these without having to shorten the diff. Nice 15x10's
Attached File  cutting hatch guards 010.jpg   191.29K   5 downloads
When I said that these flares are good quality, how many of you have seen a set on of flares that can held against the body with one finger and still fit perfectly. Check this out, look at the fitment against an unflared body the flare being held up with only one finger :thebird:
Attached File  cutting hatch guards 011.jpg   169.32K   3 downloads
Attached File  cutting hatch guards 032.jpg   117.63K   5 downloads
Attached File  cutting hatch guards 029.jpg   84.35K   2 downloads
Attached File  cutting hatch guards 030.jpg   83.78K   2 downloads
Attached File  cutting hatch guards 031.jpg   125.91K   3 downloads
#18 Ruts
Ruts
    How Fast!?
  • 1,118 posts
Posted 14 October 2011 - 08:49 PM
Ok, the first and biggest problem we have with this project is that we wanted to fit the new flares without have to fill and paint the original holes and 1/4 panels. The problem with that is that the new flare would not line up with the old holes without some major work to the inner guards and new flares. Here is what the wheel arches looked like after the flares were removed and how different the new flares sit on the 1/4 panel.
Attached File  cutting hatch guards 021.jpg   193.39K   3 downloads
Attached File  cutting hatch guards 020.jpg   163.79K   1 downloads
Attached File  cutting hatch guards 035.jpg   140.37K   5 downloads
Attached File  cutting hatch guards 025.jpg   115.3K   2 downloads
Attached File  cutting hatch guards 026.jpg   106.75K   2 downloads
Attached File  cutting hatch guards 027.jpg   121.67K   1 downloads
Attached File  cutting hatch guards 028.jpg   102.98K   2 downloads
Attached File  cutting hatch guards 041.jpg   109.42K   1 downloads
Attached File  cutting hatch guards 045.jpg   110.92K   1 downloads
Attached File  cutting hatch guards 043.jpg   105.18K   2 downloads
Now the problem I had was that to get the new flares to sit sort of in place I had to cut away some of the inner guard first. Please not that the initial cuts are NOT where the final cuts will be. I marked the first cut and then worked on from there.
As I went along I had to keep trying the flare so that it would sort of sit in the correct position.
Attached File  cutting hatch guards 036.jpg   140.92K   3 downloads
Attached File  cutting hatch guards 037.jpg   158.17K   1 downloads
I then marked and cut the inner panel
Attached File  cutting hatch guards 038.jpg   156.67K   2 downloads
Attached File  cutting hatch guards 039.jpg   147.12K   2 downloads
Attached File  cutting hatch guards 042.jpg   122.79K   2 downloads
Once I cut the major of the inner guard away I kept trying the new flare on. As I went along I kept finding bits that needed trimming so that the flare would sit against the 1/4 panel
Attached File  cutting hatch guards 048.jpg   161.17K   2 downloads
Attached File  cutting hatch guards 049.jpg   142.84K   2 downloads
Attached File  cutting hatch guards 052.jpg   135.47K   2 downloads
Attached File  cutting hatch guards 053.jpg   121.61K   2 downloads
Attached File  cutting hatch guards 054.jpg   136.29K   3 downloads
Once the majority of the inner guard was cut away we were getting closer to having the new flare in the correct position. What we were trying to achieve was to get the new flare to cover the old flare holes. The next problem we had was that when the new flare was sitting in a position to cover the old holes the bottom of the new flare at the front would not got all the way to the bottom of the sill panel. Old holes covered with new flares.
Attached File  cutting hatch guards 046.jpg   124.07K   2 downloads
Attached File  cutting hatch guards 055.jpg   112.72K   1 downloads
Bottom of flare not reaching the bottom of the sill
Attached File  cutting hatch guards 047.jpg   106.76K   2 downloads
Now to get the new flare to sit correctly and to cover the old flare holes we have to do some major surgery to the flare which meant cutting the bottom of the front of the flare and extend it to meet the sill panel. Cut along the dotted line.
Attached File  cutting hatch guards 057.jpg   139.92K   3 downloads
Attached File  cutting hatch guards 060.jpg   114.03K   2 downloads
Attached File  cutting hatch guards 061.jpg   102.71K   2 downloads
Attached File  cutting hatch guards 062.jpg   111K   3 downloads
Attached File  cutting hatch guards 063.jpg   98.2K   2 downloads
Attached File  cutting hatch guards 064.jpg   96.67K   2 downloads
With the cut end of the flare screwed in place you can see how much will need to in-filled with a bit of fibreglass work.
Attached File  cutting hatch guards 065.jpg   116.9K   1 downloads
Attached File  cutting hatch guards 066.jpg   128.1K   1 downloads
Attached File  cutting hatch guards 067.jpg   99.51K   1 downloads
Attached File  cutting hatch guards 068.jpg   88.05K   2 downloads
#19 Ruts
Ruts
    How Fast!?
  • 1,118 posts
Posted 14 October 2011 - 09:04 PM
Once the inner guard and flare were cut I was able to fit the new flare on to cover the old holes and have a nice fit all round.
Attached File  cutting hatch guards 073.jpg   172.75K   1 downloads
Attached File  cutting hatch guards 074.jpg   189.7K   1 downloads
Attached File  cutting hatch guards 075.jpg   224.67K   1 downloads
Attached File  cutting hatch guards 076.jpg   166.99K   1 downloads
Attached File  cutting hatch guards 077.jpg   132.97K   1 downloads
With the 15x10 on you can see how the new flares cover the wheels nicely
Attached File  cutting hatch guards 078.jpg   137.31K   1 downloads
Attached File  cutting hatch guards 079.jpg   175.96K   2 downloads
Attached File  cutting hatch guards 080.jpg   181.81K   1 downloads
Looking up from underneath you can see the first cut that I did to the inner guards just to get the new flares to fit. Don't forget that this is not the final cut there will be a far bit to still come out here.
Attached File  cutting hatch guards 072.jpg   242.08K   1 downloads
Attached File  cutting hatch guards 071.jpg   266.72K   1 downloads
Attached File  cutting hatch guards 070.jpg   118.94K   1 downloads
Just to finish off I have added these pictures of the flare piping to shot TB how to splice the flare piping to make it easy to fit. The first picture is the hard way to do it and the second has the old and new with the cut out making it much easier to fit.
Attached File  cutting hatch guards 016.jpg   123.62K   1 downloads
Attached File  cutting hatch guards 018.jpg   100.63K   3 downloads
Next Instalment: cutting more guard and fibreglassing the cut flare.
Edited by Ruts, 04 July 2019 - 07:13 PM.
#20 _76LXSS350_
_76LXSS350_
Posted 14 October 2011 - 11:55 PM
Ruts
What size bolts were used on those flares, 1/4 or 5/16 (m6 or m8)? and were they secured through the cars outer and inner guard or are they an allen cap head self tapper (havn't been able to find cap head self tappers in these larger sizes)?
#21 Tyre biter
Tyre biter
  • 982 posts
Posted 15 October 2011 - 08:26 AM
Just to finish off I have added these pictures of the flare piping to shot TB how to splice the flare piping to make it easy to fit. The first picture is the hard way to do it and the second has the old and new with the cut out making it much easier to fit...
Ruts, very kind of you - thank you.
I'll have a whirl this weekend if I get a chance and let you know how I go.
Cheers, TB
#22 _rob350hatch_
_rob350hatch_
Posted 16 October 2011 - 09:07 AM
very nice ill be around soon to have a look.
the $180 getting those flares from hornet composites in melbourne was money well spent it .sure beats the $1500 odd to get the diff shortened.
#23 Tyre biter
Tyre biter
  • 982 posts
Posted 16 October 2011 - 08:22 PM
Ruts,
I fitted two flares today and your instructions and photos worked a treat - thank you.
There are a couple of pics in the build thread if you are interested.
In reference to my first post in this thread (#6), my flares are lower in the centre of the wheel arch that my cut guards, and so one could only hope this means I ought not have any clearance problems - probably just shot myself in the foot for saying so but hey, it looks promising nonetheless.
All the best and thanks once more - TB
#24 Ruts
Ruts
    How Fast!?
  • 1,118 posts
Posted 16 October 2011 - 08:32 PM
TB yours are in the correct position the red car's flares are a bit higher than I like. I had to do it like that because we needed to cover the old holes on the 1/4 panel. Have a look at the picture of the flare against the 1/4 panel on the yellow car. That' where the flare should be sitting. I would prefer them a bit lower so that that the car looks like it sit's lower to the ground if you know what I mean.
Ruts
#25 rodomo
  • 18,037 posts
Posted 16 October 2011 - 08:55 PM
What are you using to do the cuts Ruts?
