Moving an LC/LJ diff forwards
62 replies to this topic
#51 Orchid LJ
Orchid LJ
  • 5 posts
  • Name:Tony
  • Car:LJ Coupe
Posted 02 August 2014 - 01:09 PM
I originally had my uppers & lowers shortened to centre the wheel
Hey Ben any chance you can remember the total amount both upper and lower arms were shortened by, as I'm just in the process of centering my 9" would be handy to get some figures to work with?
Cheers Tony.
#52 _Evilj6_
_Evilj6_
Posted 04 September 2016 - 10:20 PM
can you you get diff mounts welded on so the diff will sil centre
#53 gtrboyy
gtrboyy
  • 3,236 posts
Posted 04 September 2016 - 11:31 PM
Yes some people have done that..wish I'd thought of it back then.
Shorter control arms would work well too.
#54 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 05 September 2016 - 12:20 AM
John langs (pro 9) adjustable control arms.
in 4130 chromoly tube and plate in either
nolathane or heim joints 🖒
Attached File  13892185_558455287613048_696825324550537354_n.jpg   39.16K   12 downloads
Edited by madtoranajzedded, 05 September 2016 - 12:30 AM.
#55 _71lc_1JZ_
_71lc_1JZ_
Posted 05 September 2016 - 08:45 AM
Madz they look cock might have to get me self some
#56 _Evilj6_
_Evilj6_
Posted 05 September 2016 - 08:54 PM
are those pro9 adjustable arms good for bringing he diff forward to centre wheels i am in the process of doing diff shorten and centre built need to get the wheels centre for clearance
#57 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 05 September 2016 - 09:58 PM
Well yes and no .i think you can only move
slightly as the spring wont line up with the
the top hole when bolting up.same with shock
as it will b on an inclination .i spose a 1/2 ,1'?? spacer could go on first then shock.will have to redrill a hole for top mount to spring.
Im sure you would have to do this.some one
will correct if im wrong...i was just
thinking if it was adjustable from spring end
you wouldnt have to adjust spring only shock
if clearances allowed.
Edited by madtoranajzedded, 05 September 2016 - 10:01 PM.
#58 IMORAL
IMORAL
    Bored
  • 2,569 posts
  • Name:Paul
  • Car:LX SS HATCH - IMORAL
Posted 06 September 2016 - 11:46 AM
Do they make ones that can be adjusted with out having to remove one end?
They sure do look good
#59 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 07 September 2016 - 01:02 AM
Not that im aware of,only the tops ones that
Ray Mcdonald does.
Attached File  uptrail4.jpg   26.28K   4 downloads
#60 IMORAL
IMORAL
    Bored
  • 2,569 posts
  • Name:Paul
Posted 07 September 2016 - 02:22 PM
I got a set similar to that on the hatch and was hoping you can get the same for the little ones
#61 gtrboyy
gtrboyy
  • 3,236 posts
Posted 07 September 2016 - 09:38 PM
Cant remember exact reason but was told adjustable lowers were no-no for rego..very few sold so most never bothered.
Shouldnrt be that hard if weld lower spring perch on after set the distance of the wheels..mine got coil-overs,narrowed diff & rear discs decade ago easy to forget what standard rear look like.
#62 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 08 September 2016 - 02:54 AM
I dont think they would b illegal bud as
bushed adjustable parrallel 4 link is not illegal.
But that said there isnt no spring on lower
arm as all are running coilovers mounted to
housing,
If your mean like the lowers can b adjusted
from centre without having to remove to
adjust you could b right as no one makes them
like that for lowers.
Edited by madtoranajzedded, 08 September 2016 - 03:06 AM.
#63 gtrboyy
gtrboyy
  • 3,236 posts
Posted 08 September 2016 - 03:45 AM
Yeah the adjustable lowers...even my tubbed sle weirdly has fixed upper & lowers from 10+ years ago from macdonald bros kit. Cant remember exact reason why availability stopped do remember when they did come out it was only very short period then only fixed length available.
