Tips on fitting Roof Lining
#26
_LH8VD69_
Posted 17 November 2011 - 09:20 PM
#27
Posted 18 November 2011 - 12:04 PM
#28
Posted 18 November 2011 - 09:40 PM
pics brad pics!I actually found it quite hard to find the holes for the grab handles, as the headlining was stretched so far away from the steel... very lucky I had my drawings and had some measurements in the GMH workshop manual. If I didnt.. Id be stuffed....
#29
Posted 19 November 2011 - 09:29 PM
Grab handles:
Sunvisor mounts:
Rear view mount:
Why is it that the manual says to cut a slit in the lining on the inner section of the rear view mount?
All finished. Bought a new windscreen so now good to go to fit the glass, I want to try and sort out the mylar chrome locking strip though... I simply dont believe that the correct profile stuff is not available....
#30
Posted 20 November 2011 - 03:11 AM
bracket upside down
you should see couple of tapered pins and a small spring
roof lining needs to be sliced so these pins can locate into
the mounting bracket properly
i used nos mylar that my mate gave me
i,m sure the stuff is still available though
lookin great!
davemc
#31
_moot_
Posted 20 November 2011 - 06:35 AM
That is a good price!
One small thing I did prior to fitting the headlining was to take a few bits of paper and mark out the positions of all the holes for the grab handles, sunvisor mounts and rear view mirror. Hopefully will save me having to poke around endlessly searching for a hole...?
now you've done it i'll tell you the easy way
screw all the screws you need into the roof first,leave a bit of them hanging out,then put the roof lining in.this way you can feel the screws and cut around them.
#32
Posted 20 November 2011 - 09:24 AM
brad turn your rearview mirror
bracket upside down
lookin great!
davemc
Ahhhhhh Yes Dave very good!!!!! Thank you!
Yeah your bloody right there to!!! That would of made things heaps easier!!!! You shoulda told me that before!!!!!
#33
Posted 20 November 2011 - 09:58 AM
#34
Posted 20 November 2011 - 10:38 AM
dianella w.a have it
08 92728999
they deal in lots of nos parts, they have allsorts
parts panels all sorts of rubber and glass
just remembered i got some mylar there a short time ago!
good luck
davemc
#35
Posted 20 November 2011 - 10:54 AM
#36
Posted 20 November 2011 - 12:06 PM
not first thing brad!THANK YOU!!!! I will call them first thing monday morning!!!!!
we are 3 hours behind in w.a.
some think more!
wait till midday your time or
if you want me to i,ll give them a call
just let me know how many mtrs plus a bit extra
happy to chase it up for ya!
cheers davemc
#37
Posted 20 November 2011 - 03:16 PM
Edited by hanra, 20 November 2011 - 03:16 PM.
#38
Posted 07 October 2014 - 02:52 PM
I decided to give the headliner a go my self, I followed the write up from c&g but when I pull the headliner to stretch it the front rod keeps sagging and is almost stright with no bend in it or arch.. Just wondering why that happending and if anyone else has been in this suitiation before?
I pretty certain that I installed the rod out of where it came from.
#39
_abtorana_
Posted 08 October 2014 - 01:23 PM
bit hard to explain but here goes
when you have pulled it tight at front and clamp it with pinch weld offcuts ,yes the rod tends to roll over (causing it to sag), mine did the same
all you do is get at the rod from the door openings and spin the rod back or
you can even grab the rod thru the headlining (clean hands and pinch it with fingers) and flick it back, and hook it on ,it will roll back trust me
I think I had about a dozen goes at it as the rod would roll back too far and also sag.
hope this helps and I have not confused the issue
also there should be a couple of holes to choose from for each rod and for me it was trial and error, even tho I marked the holes they come
from ,but I still had to use different mounting holes on two of the sides.
#40
Posted 13 October 2014 - 12:56 PM
It's weird because the rod is pretty loose dosent matter which hole I use. Top top or even if I go top and bottom.
Might have to attack it on the weekend.
#41
_uca78t_
Posted 13 October 2014 - 05:22 PM
Most importantly work from the middle out & then front to back & before you start put all your screws back in & when it's comes to finding them just feel with your finger tips & use a stanly knife to do a tiny criss cross slit.
I hope this helps
Cheers Shane
