HELP WITH STUD PATTERN ?
51 replies to this topic
#26 _nial8r_
_nial8r_
Posted 21 November 2011 - 06:55 AM
hey Gordy is that list for every model car with the same stud pattern ??
#27 _toranarama_
_toranarama_
Posted 21 November 2011 - 07:10 AM
go to google...
type in 5 x 114.3 PCD
AND....
Look
For
Yourself !
:P
#28 _CHOPPER_
_CHOPPER_
Posted 21 November 2011 - 08:25 AM
Actually, there are a lot more.
#29 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
  • Car:76 LX Sedan, 4 seater
Posted 21 November 2011 - 12:12 PM
It only goes back to about 1990.
Valiant is the same yeah Chop?
#30 _Gunmetal LH_
_Gunmetal LH_
Posted 21 November 2011 - 02:31 PM
I think the Valiant PCD changed from a smaller one to the same as Ford around 1970.
I also remember seeing the odd Valiant 5-skoke sport steel wheel from the Charger era on some Fords.
#31 _CHOPPER_
_CHOPPER_
Posted 21 November 2011 - 06:21 PM
Real early Aussie Valiants had a very unusual stud pattern - 5x4.25". Later ones used Ford stud pattern, but with a slightly different offset.
#32 _nial8r_
_nial8r_
Posted 24 November 2011 - 06:37 PM
thanks for all your help fella's got my hands on 3 x 97" Magna 15' rims with RE92 tyres for 50 clams and they fit perfect. thanks again :spoton:
#33 _Bomber Watson_
Posted 24 November 2011 - 06:48 PM
Torry/early Holden pattern?
#34 _CHOPPER_
_CHOPPER_
Posted 24 November 2011 - 06:49 PM
So you paid for the tyres and got a discount for the rims?
#35 _CHOPPER_
_CHOPPER_
Posted 24 November 2011 - 07:06 PM
Correct Bomber, I was just seeing who was awake.
#36 _nial8r_
_nial8r_
Posted 25 November 2011 - 03:11 PM
got the 3 rim & tyres for $50 so i cant complain about that :D
Edited by nial8r, 25 November 2011 - 03:12 PM.
#37 _SS Hatchback_
_SS Hatchback_
Posted 25 November 2011 - 04:53 PM
Lee, if you walk around looking like the pic on your avatar no wonder they gave you them for 50 bucks , too cool
#38 _Big Rob_
_Big Rob_
Posted 25 November 2011 - 07:38 PM
They look like early Magna to me, but whatever, they are a Ford stud pattern. :shoot: ( so ditch the stub axles and change them to Torana so all your wheels match and you only have to carry one spare). :driving:
#39 _CHOPPER_
_CHOPPER_
Posted 25 November 2011 - 09:08 PM
What I was getting at is the tyres are worth more than the rims.
#40 _nial8r_
_nial8r_
Posted 26 November 2011 - 07:16 AM
lol as a young bloke i used to think i was the Fonz :rolleyes: and even now if something isnt work i give it the old Fonz hit :D
#41 _nial8r_
_nial8r_
Posted 26 November 2011 - 07:20 AM
this Trailer wont be getting towed by my LX as it wont be getting a tow bar fitted, its for behind my 4X4 HiLux, just had to get it to match the height of it so i did a spring over on the trailer and with the 15' rims it will be just under level ride height untill i put some light truck tyres on it then it should be good to go " i hope "
#42 _nial8r_
_nial8r_
Posted 26 November 2011 - 07:23 AM
yeah i think they even sell second hand tyres for about $35 each at the tyre joints. one if the tyres still has a Bob Jane sticker on it.
#43 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 26 November 2011 - 07:36 AM
Ealy Val and early Holden are not the same.
The Val is smaller,5 on 4"
#44 _toranarama_
_toranarama_
Posted 26 November 2011 - 09:26 AM
I'm a stud & I have a pattern with the Ladies
Hope this helps :P
Now POR 15 that trailer dammit !
#45 _nial8r_
_nial8r_
Posted 26 November 2011 - 10:05 AM
im almost finished the underside of it. the people i brought the trailer off tried to us a stick welder to stitch the new floor in and just made one hell of a mess of it, so i have sorted that out and the lower section of the tail gate ( again they used the stick welder on 1.2mm steel) just need to hit the surface rust with a twist knot wire wheel on the grinder then deoxidine, primer and then stone gaurd it then i can flip it back over and repair a couple of spots of rust on the side and front and the give it a lick of paint and its done. Oh and i have welded 2 new saftey chains on it also :D
#46 _CHOPPER_
_CHOPPER_
Posted 26 November 2011 - 10:49 AM
I was sure they were Torry pattern, but since it has been over 20 years since I had an old Val in a tyre shop, I won't be argueing.
#47 _torbirdie_
_torbirdie_
Posted 03 December 2011 - 07:16 AM
in the 1st link you posted it it says centre to centre on one and two wich gives a reading of 70mm
and a 110mm from centre to centre from one and three
According to your measurements , adjacent studs 70mm = pcd 119.1mm
Opposite studs 110mm = pcd 115.7mm
Basically either or both are incorrect.
Basic check of your measurements : dist (1-3) = 1.618 x dist(1-2)
keep measuring until you get numbers that satisfy the above and you will have the correct measurements, then apply:
PCD = 1.701 x dist (1-2)
and 115 from the outter on one to the centre on three.
This is a pointless measurement unless you measure the size of the stud hole and adjust. When you only have the wheel to measure, measure the dist from the inner/closest point on one hole to the outer/furthest on the other.
#48 _nial8r_
_nial8r_
Posted 03 December 2011 - 07:53 AM
thanks torbirdie, i have since located some 15" rims and tyres and they fit fine. i took the 14" with me to the wreckers and put it on the magna and it fit nice then when i got home i put the 15" on the trailer and it also fit nice :D thanks for the help anyways
#49 _walpolla_
_walpolla_
Posted 03 December 2011 - 09:44 AM
Lee, I have only just had a look at this thread, and I can tell you that the rims on your trailer ( in the pics on page 1) are BMW.
I had a trailer some years back with BMW rims on. Same as yours.
Now as it happens my next door neighbour has an '85 Beemer parked in his drive and guess what? Those rims are sitting there. That explains the Metric measurements - not Japanese, but European.
regards,Rod
#50 dattoman
  • 16,487 posts
Posted 03 December 2011 - 10:28 AM
BMW is 5 x120 same as Commodore
