I want to check my Oil/Temp/Fuel gauges on the bench before they are fitted to the cluster. Oil/Temp/Fuel gauges are all identical in coil resistance. The fuel gauge resistance range is 10ohm to 73ohm.
What are the resistance values of the Oil/Temp senders?
SL/R 308 Oil Pressure and Temp Sender resistance values.
, Nov 29 2011 03:11 PM
3 replies to this topic
Posted 29 November 2011 - 03:11 PM
Posted 29 November 2011 - 06:20 PM
I would imagine that because all 3 gauges have the same coil winding resistance of 15ohms that the resistance scale of between 10 and 73 ohms is the same for oil and temp?
Posted 29 November 2011 - 09:49 PM
From my notes Brad I've got, using VDO temp. sender p/n 320003 and Holden p/n 9932443, identified by a blue ring
Deflection on gauge is approx. 10 ohms for hot, 75 ohms for cold
Boiling water reads approx. 40 ohms
Hope this helps mate
Posted 30 November 2011 - 08:05 AM
Thanks for that info Mark! Values as I expected. Cheers mate!
