Whiteline rear sway bar for LC torana
#1 _injlc304_
Posted 04 December 2011 - 11:38 PM
Has anyone fitted a whiteline rear sway bar to a LC Lj torana with a ford 9" diff??
I have just bought one but I'm not all that certain how to fit it. As I have to drill into the chassis/upper control arm for the mounting bracket I want to get it right the first time. Has anyone got a step by step guide pref with photos??
Thanks heaps
#2 _Quagmire_
Posted 04 December 2011 - 11:53 PM
Posted 04 December 2011 - 11:58 PM
#4 _Quagmire_
Posted 05 December 2011 - 12:00 AM
Posted 05 December 2011 - 02:05 AM
Edited by ls2lxhatch, 05 December 2011 - 02:06 AM.
#6 _toranarama_
Posted 05 December 2011 - 07:35 AM
#7 _injlc304_
Posted 05 December 2011 - 08:23 AM
#8 _injlc304_
Posted 05 December 2011 - 08:31 AM
How did your car perform after putting it on? I get quiet a bit of diff movement in mine so I'm trying to eliminate that.
Posted 05 December 2011 - 10:51 AM
I ended up using the K-MAC front mount UC style swaybar because I preferred how the drop links are mounted to the body. This is my car. I have not driven the car since the swaybar was fitted.
Edited by ls2lxhatch, 05 December 2011 - 10:56 AM.
Posted 05 December 2011 - 11:25 AM
#11 _injlc304_
Posted 05 December 2011 - 11:28 AM
#12 _injlc304_
Posted 05 December 2011 - 01:04 PM
Posted 05 December 2011 - 03:50 PM
#14 _injlc304_
Posted 05 December 2011 - 04:15 PM
#15 _injlc304_
Posted 05 December 2011 - 04:26 PM
on mine the bar ends are horizontal and the link rod bolts down through.
interesting.
also in there pic the u bolts are straight down and the bar is horizontal with the chassis where as on mine the u bolts are back on an angle to keep it horizontal.
can you understand my jibberish?
Edited by ryan_525, 05 December 2011 - 04:29 PM.
Posted 05 December 2011 - 05:20 PM
Sounds like the bar you have is the same style as the bar in the photos I posted which is not adjustable. The angle of the bar is not critical, it will change during suspension travel.
#17 _injlc304_
Posted 06 December 2011 - 09:30 AM
see how the U Bolts are on the angle they are to keep the bar ends where the adjustment rod is horizontal? but in doing so the bar is hitting the rear of the diff housing?? and where i have drawn where i am going to get a bigger angle to fix to the chassis is that a good spot so i dont have to re drill?
#18 _CHOPPER_
Posted 06 December 2011 - 10:43 AM
Posted 06 December 2011 - 10:44 AM
Have you tried flipping the bar upside down to see if that gives you better clearance on the diff?
You could also try putting a spacer plate on the u-bolt clamp to lower the bar or adjusting the length of the drop links until the bar clears.
Once you have the position sorted you could get brackets welded on to the diff instead of using the u-bolts.
#20 _injlc304_
Posted 06 December 2011 - 10:58 AM
i can get heaps of angle in all diff sizes from the boilys at work so that shouldnt be an issue.
Chopps:
you are prob right mate just looking at it i could only picture the rear of the bar piviting up as where it bolts to the control arm will go down.ill have a fiddle and see what happens.
the more info i get the better
Ps. i emailed whiteline the same photos and they said it looks like the bar should be flipped. so will try that. also they said the bar ends DON'T have to be horizontal either so ill see how i go with that info.
Edited by ryan_525, 06 December 2011 - 11:07 AM.
#21
Posted 06 December 2011 - 12:33 PM
#22 _injlc304_
Posted 06 December 2011 - 02:48 PM
As the diff goes up the front of the bar is pushed down and the rear of the bar will pivot towards the diff.
in other words the way it is atm it isn't going to work. surely this thing shouldn't be too hard to fit. geese man
#23
Posted 06 December 2011 - 04:42 PM
#24 _CHOPPER_
Posted 06 December 2011 - 04:44 PM
The front of the bar is attached to the body, so that won't move much. The point is, on suspension travel the bar will move closer to the housing in one direction and away from it in the other.
But yeah, I'm starting to think the bar could be upside down.
#25 _toranarama_
Posted 06 December 2011 - 04:47 PM
