Plastic plugs for nose-cone badge
112 replies to this topic
#26 _BIGCAV_
_BIGCAV_
Posted 20 December 2011 - 10:44 PM
The 5th line down from the catalogue link at the top of the page, is there something useable in there?
http://www.rsp.net.a...clips/index.htm
CLIP BADGE RETAINER PUSH IN TYPE
sorry website wont let me link directly
Edited by BIGCAV, 20 December 2011 - 10:45 PM.
#27 _heapa_
_heapa_
Posted 20 December 2011 - 11:03 PM
I may have some in the shed that I could photograph/measure.
They are not the same, but I would have thought one of the 1/8" CLIP BADGE RETAINER PUSH IN TYPE clips would work.
Les, does Rares still make the letters, or have they been discontinued? I think I'm short an A.
pm me your address and i will post you a A
yeah went with the letter in hand and the car to rare spares at prospect and nothing
#28 _Big T_
_Big T_
Posted 21 December 2011 - 07:41 PM
Try 'super' glue. God, I thought you were professional Tony!
You know Pat, I did seriously consider a permanent solution like that !!
Edited by Big T, 21 December 2011 - 07:42 PM.
#29 _Big T_
_Big T_
Posted 21 December 2011 - 07:49 PM
These look like the jiggers I have but I am unsure of correct size though.
PN# SP1335 CLIP 7/64" PUSH IN METAL SUIT BADGES
PN# SP1606 CLIP TUBULAR 1/8" STUD SUIT PUSH IN BADGES
#30 hanra
  • 10,975 posts
Posted 21 December 2011 - 08:43 PM
Im pretty sure Ive got some of those. They are used to hold the LH SL/SLR front window corner moulding in place.
The ones I have, the inner diameter is to large to accommodate the shaft of the badge.
The measurements Ive taken are:
Badge mounting shaft: 2mm
Body mount hole: 4 to 4.5mm
#31 _Yella SLuR_
_Yella SLuR_
Posted 07 January 2012 - 08:44 PM
Clips that look like this (There are 12 of the suckers):
I fixed these up while I was at it:
Let me know if you want measurements. They are plastic.
The other post I saw looking for this one suggests that some peeps silicon them in (little silicon). I don't like the thought of silicon and paint, but anyways.
Thought I was missing a letter, but I aint. Woohoo.
Edited by Yella SLuR, 07 January 2012 - 08:47 PM.
#32 _les_
_les_
Posted 07 January 2012 - 09:34 PM
The letters are being remade along with a lot of our badges I have no time frame at present ,I will try and find the plastic plugs next week.
#33 hanra
  • 10,975 posts
Posted 07 January 2012 - 09:38 PM
I'll be chasing some plugs also!!!
#34 _Yella SLuR_
_Yella SLuR_
Posted 07 January 2012 - 10:07 PM
Cool, thanks Les.
#35 _les_
_les_
Posted 09 January 2012 - 05:42 PM
I cannot find that one, can sombody either give me a sample or the measurements what size hole it fits in, what size is the stud it has to take and the length
#36 hanra
  • 10,975 posts
Posted 09 January 2012 - 10:47 PM
Badge mounting shaft diam: 2mm
Body mount hole diam: 4 to 4.5mm
Edited by hanra, 09 January 2012 - 10:48 PM.
#37 _les_
_les_
Posted 10 January 2012 - 06:39 PM
Try part number 13150 it may do the trick one of our distributors may have some that you can check out
Les
#38 hanra
  • 10,975 posts
Posted 10 January 2012 - 06:52 PM
Do you have any distributors in FNQ?
#39 _Yella SLuR_
_Yella SLuR_
Posted 10 January 2012 - 08:58 PM
Mmm, I'm onto it, but the nose cone I'm currently preparing has holes at 3.6mm or 9/64 measured with veneer calipers and confirmed with a drill bit. Drawing to follow shortly.
Pins on letters 2.4mm dia.
#40 _Yella SLuR_
_Yella SLuR_
Posted 10 January 2012 - 09:48 PM
Drawing. I only measured to the nearest 0.05mm. Plugs are plastic and round.
Edited by Yella SLuR, 10 January 2012 - 10:02 PM.
#41 hanra
  • 10,975 posts
Posted 11 January 2012 - 06:33 AM
Nice One!
#42 _les_
_les_
Posted 11 January 2012 - 12:32 PM
Give me your name and address and I will send you some to try at no charge just let me know if they do the job, in the mean time I will continue to look for the correct ones
Thanks for that I will try and find the correct ones
#43 hanra
  • 10,975 posts
Posted 11 January 2012 - 12:59 PM
Awesome Les!!!! Ill send you a PM now!!!!
#44 _Yella SLuR_
_Yella SLuR_
Posted 11 January 2012 - 10:23 PM
I have some original ones. Hanra, PM Les your address and give them a whiz. You could send me a couple to compare the fit with the old ones. I was worried that the little nick measured too small, considering the go into 1.6mm steel, but that's what it measured.
#45 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 11 January 2012 - 10:43 PM
Torana panels aren't 1.6mm thick - I think they are 1mm last time I checked .
#46 _Yella SLuR_
_Yella SLuR_
Posted 12 January 2012 - 08:10 AM
Thanks Matt, I'll go measure. Sounds promising.
#47 _napes_au_
_napes_au_
Posted 19 January 2012 - 07:47 AM
Has anyone came up with a suitable plug yet???
#48 hanra
  • 10,975 posts
Posted 19 January 2012 - 07:54 AM
I got the ones that Les sent to me yesterday. They are to large in outside diameter to fit into the nosecone, and then they are to small towards the ends of the inside to allow the badge mounting shaft to go all the way home.
#49 _napes_au_
_napes_au_
Posted 19 January 2012 - 07:58 AM
Bugger
#50 hanra
  • 10,975 posts
Posted 19 January 2012 - 08:02 AM
I might be able to fix the problem with a drill... but rather not...
