IFS Front end LC LJ
34 replies to this topic
#1 _waddingtons_
_waddingtons_
Posted 20 December 2011 - 05:09 PM
Here is a few pics of the new IFS front end WADDINGTONS are making
#2 _waddingtons_
_waddingtons_
Posted 20 December 2011 - 05:33 PM
few more pics
#3 _waddingtons_
_waddingtons_
Posted 20 December 2011 - 05:39 PM
Front and rear rack available, coil over or airbag
Front ends will be around $3500
#4 _Liam_
_Liam_
Posted 20 December 2011 - 06:28 PM
Cool, are these able to be used in Street Registered vehicles?
#5 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 20 December 2011 - 07:09 PM
What have you done with the geometry compared with standard?
#6 _Liam_
_Liam_
Posted 20 December 2011 - 09:14 PM
Are you planning to run the Steering rack behind the X-Member instead of the front?
#7 dattoman
  • 16,487 posts
Posted 20 December 2011 - 09:36 PM
Looks like you get your choice on rack position
#8 _Liam_
_Liam_
Posted 20 December 2011 - 09:46 PM
Benefits of which would be?
#9 dattoman
  • 16,487 posts
Posted 20 December 2011 - 09:48 PM
That front end isn't restricted to just Toranas
Common conversion to Hotrods also
And Wad's plays with hotrods
#10 _Liam_
_Liam_
Posted 20 December 2011 - 09:52 PM
Fair enough, but what is the benefit? To run certain sumps or to have underslung alternators etc without too many issues on steering racks?
#11 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 21 December 2011 - 06:22 PM
Looks good, I like the Mc Donald bros cross member better as its tube steel, probably lighter?
#12 _CHOPPER_
_CHOPPER_
Posted 21 December 2011 - 06:36 PM
I would prefer torsional rigidity over weight savings on the front crossmember. Unless improved steering isn't important.
#13 ls2lxhatch
  • 5,332 posts
Posted 21 December 2011 - 06:39 PM
Making a k-frame out of tube will probably end up heavier than a sheet metal k-frame.
The problem with tube is it has the same strength in every direction whereas with sheet metal you can put the metal/strength only where it is required.
#14 _CHOPPER_
_CHOPPER_
Posted 21 December 2011 - 06:44 PM
I'd like to know what stub axle is used in the first image. And what discs/calipers will bolt straight on.
#15 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 21 December 2011 - 08:38 PM
Good point
#16 _waddingtons_
_waddingtons_
Posted 22 December 2011 - 06:48 AM
Front ends come fully engineered. Will get more info and more photos of the finished item.
Many thanks Waddingtons
#17 _CHOPPER_
_CHOPPER_
Posted 22 December 2011 - 01:33 PM
Is power steering an option?
#18 orangeLJ
Posted 30 January 2012 - 10:04 AM
How much room is there with a rear rack for extractor and sump clearance?
looks pretty tight in the ebay photos?
#19 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
  • Car:76 LX Sedan, 4 seater
Posted 30 January 2012 - 01:15 PM
McDonald brother not street legal.
Commodore power rack would mount on the back, just need to find/modify a sump to suit.
Easier (but more expensive) to get the Subaru Power steering conversion to fit on the front.......
Chase hotrods to find what they use......
Grant..
#20 Heath
  • 18,385 posts
Posted 30 January 2012 - 04:30 PM
One month on and nobody has answered your question? I am disappointed with this place sometimes...
Having the steering rack behind the wheel axis means you can quite easily get toe-out on turns. Something that a Torana fails to do in standard form haha
But then you need to connect the steering column to the rack, and I definitely haven't looked into solutions for that.
Edited by Heath, 30 January 2012 - 04:31 PM.
#21 _Liam_
_Liam_
Posted 30 January 2012 - 07:24 PM
I see. I imagine the steering column would have a much more severe uni angle? Not to mention that K-Frame cleat with a hole for the tie to pass through would clash with it.
Cheers Heath, it isn't a drama for me, I have the big brother Torana haha.
#22 Heath
  • 18,385 posts
Posted 30 January 2012 - 08:11 PM
I think the uni angle would be at a pretty severe extent of severity.
I'm assuming you mean it isn't a drama for you because this arrangement is only being made for baby Toranas not box Toranas, yes that is true. But the same steering geometry problem arises in box Toranas too!
#23 _Liam_
_Liam_
Posted 30 January 2012 - 08:40 PM
Yeah that's what I mean. I'm not too worried Heath, as long as I can steer it pretty well haha.
#24 dattoman
  • 16,487 posts
Posted 30 January 2012 - 09:28 PM
Its not just built for Toranas
Waddingtons are hotrodders too....so I'm sure its designed for more applications
And not specifically as a Torana front... but just another option for rodders after a narrow front end
Not too many Torana folk will shell out for it
But plenty of hotrodders... worldwide might
#25 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
Posted 30 January 2012 - 09:43 PM
Yeah, I answered it this morning. The main benefit is greater selection of racks including more common rear types.
Crapping on about geometry with the rear mount is a waste of time.
Toranamat69 has done more R&D into this than Holden and he hasn't moved to a rear mounted rack.
If you set the rest of your geometry up right t doesn't matter whether it's front or back.......if the steering arm distance is the same to the tie rod then it doesn't matter......
Grant..
