IFS Front end LC LJ
34 replies to this topic
#26 rodomo
  • 18,037 posts
Posted 30 January 2012 - 10:11 PM
Having the steering rack behind the wheel axis means you can quite easily get toe-out on turns. Something that a Torana fails to do in standard form haha
Toe out on turns is set into the steering arm angle so wether in front or behind wouldn't matter.
#27 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
  • Car:76 LX Sedan, 4 seater
Posted 30 January 2012 - 10:33 PM
Uh huh
#28 orangeLJ
Posted 31 January 2012 - 09:31 AM
The angle of the steering column-rear rack wouldnt be that big of a hurdle, do away with the uni and use some form of geared re-directional unit and whalla!
Im pretty sure they make small versions (Ive only seen truck ones)
#29 _waddingtons_
_waddingtons_
Posted 31 January 2012 - 01:13 PM
here is a link to the kits http://www.ebay.com....984.m1555.l2649
#30 orangeLJ
Posted 31 January 2012 - 04:18 PM
All well and good, but can you provide answers on any questions?
how would someone go about hooking up the rear rack to the original column shaft?
#31 dattoman
  • 16,487 posts
Posted 31 January 2012 - 06:44 PM
You don't !!!
This is the point I have tried to make twice in this thread so far
Its designed for more applications than a Torana ... therefore more options
#32 orangeLJ
Posted 01 February 2012 - 03:41 PM
I understand that Datto, but they are marketing it as a bolt in option for LC/LJ torana with FRONT AND REAR RACK POSSIBILITIES
Hence the questioning.
If they were marketing it as a "hot rod front end" then you would assume as per your opinion.
Its a completely legitimate question and one that IS NOT answered by what you've said ;)
#33 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
Posted 06 February 2012 - 09:10 PM
You just use two solid unis like most hotrods.......it's not that big a drama........
Just ensure you can clip onto the Commo rack and it's sorted......
The torana setup is the best for non-powered rack, and considering the subi conversion, you wouldn't go rear mounted.....clearance issues are the least of your problems.....
#34 _waddingtons_
_waddingtons_
Posted 18 February 2012 - 07:05 AM
Attached File  open day.doc   413.5K   33 downloadsCastlemaine sawp meet / Waddingtons open day
#35 _DomDom_
_DomDom_
Posted 11 March 2012 - 09:11 AM
This is a beautiful set up. I have a few questions though.
Let's say I want one for an LH-UC, will I notice the difference on the road?
Will it feel like I'm driving a more modern car?
WIll it make a non standard engine installation easier?
Do air bags handle as well as springs?
All that said could one just use tubular arms on the Torana K-frame and get a similar but less expensive effect?
Thanks in advance.
Dom
Edited by DomDom, 11 March 2012 - 09:13 AM.
