Low oil pressure
#76
Posted 13 January 2012 - 01:33 PM
#77
_WYLDLC6_
Posted 13 January 2012 - 03:50 PM
Any other suggestions.
Chris
#79
Posted 13 January 2012 - 04:16 PM
That would rule out the oil pump and pickup in one.
#80
_WYLDLC6_
Posted 13 January 2012 - 04:24 PM
I dont know what else i can do.
I know the block was good as i'd used it on my last engine with no problems.
Actually over it.
#81
_Drag lc_
Posted 13 January 2012 - 04:40 PM
#82
Posted 13 January 2012 - 05:14 PM
#83
_WYLDLC6_
Posted 13 January 2012 - 05:52 PM
Cheers chris
#84
Posted 13 January 2012 - 07:51 PM
I ask because a lad i know is going thorugh this exact issue, after months of frOcking around with professional engine builders/machine shops screwing him around they have wiped there hands clean of his engine and he has come to me to build him one..........
Only thing we can think of is that perhaps theres a hariline crack in the block somewhere near an oil journal that opens up when the engine reaches operating temperature.
This particular block has been on an "oil dyno", a rig kinda thing that pumps oil through the block to check for leakages, and come up perfect, everything else is spot on as you say, just when it reaches operating temperature the oil pressure drops to 0 at idle. They do not warm the block to operating temperature during the test, which i think is wrong.
Were starting with another block when we get around to doing this, i've convinced him of that, and i'll be inspecting his old block VERY closely, if i can find anything he will be going to small claims court.
Just thought perhaps you should check your block again, never know, the machine shop may have dropped it during the latest build or something stupid like that.
Edited by Bomber Watson, 13 January 2012 - 07:52 PM.
#85
Posted 13 January 2012 - 08:27 PM
#86
Posted 13 January 2012 - 09:07 PM
Im using hpr 40.
First page.
#87
_CraigA_
Posted 13 January 2012 - 09:08 PM
Which specs, im not sure of tollerences but its got 11.1 comp, solid cam 535 lift 320 dur 1.5 rockers, lots of headwork should make around 280 hp.
It has a brand new standard oil pump. Ive tried shimming the pump and its made no difference. Engine builder put a new crank in this time.
Im using hpr 40.
Penrite HPR40
I use this oil in a 202 with a standard pump and external pickup and get about 15psi idle hot and about 40-50psi running at speed.
Certainly a strange and frustrating problem :(
#88
_threeblindmice_
Posted 13 January 2012 - 09:38 PM
#89
_WYLDLC6_
Posted 14 January 2012 - 09:22 AM
Im not sure which direction to go with this now as the mechanic said that he cant justify the expense of prepping another block after the time spent so far.
With other expenses that i have aswell i cant justify it either.
Pretty shit situation atm.
Cheers chris.
#90
Posted 14 January 2012 - 12:30 PM
take the sideplates off and start er up to see if you somehow have a dodgy set of solid lifters, worth a try, youve looked at everything else
Edited by greens nice, 14 January 2012 - 12:30 PM.
#91
_oldjohnno_
Posted 14 January 2012 - 07:57 PM
Just thinking out loud now... to summarise whats going on idle and low rpm pressure is ok whether hot or cold but once it's warm it won't build up any more than about 30psi. This sounded to me like classic symptoms of a restricted suction but I was proven wrong with the sump and pickup swap. Excess bearing clearance or a missing plug etc. would make the lack of pressure even worse at idle but the fact that it's ok rules that out. That and the fact that it's already been checked.
Several pumps have been tried (including known good ones) so they can also be ruled out. Shimming the relief valve makes no difference. The grade of oil is one that has been OK in any number of similar engines. It seems something may be "opening up" at pressures over 30 psi and bleeding off oil (like a crack as Bomber suggested). Whatever it is it must be dumping quite a lot of oil to be able to limit the pressure to 30psi even with a HV pump. It'd probably take something like 5 litres/min or more to do this.
Now, you said you tested it with an external pump and looked for internal leaks. Did you do this with over 30psi? This seems to be the magic number, it'd be interesting to see how much runs out at say 20psi and then compare that to what comes out at say 50psi. If it was a crack or some other sort of leak that opened under pressure I'd imagine it would be fairly obvious. I don't know what sort of gear you have available but I've made similar pressure testing/prelubing rigs using an old truck or trailer air tank (an old BBQ gas tank would work too) filled with oil and pressurised with an air line. Obviously the oil pressure will equal the air pressure less any friction losses in the line from tank to engine.
I think Kevins suggestion to check how much oil the lifters are pumping (with the engine running if possible) is a good one too. I think you mentioned changing lifters already but I'd still check it and if it proves to be the problem change to a different type.
Anyhow good luck and hang in there.
Edited by oldjohnno, 14 January 2012 - 08:06 PM.
#92
Posted 14 January 2012 - 08:14 PM
Your car has always been one of my favourites and it's awesome how much you've done with it!!
Hang in there mate, With the blokes youve got thinking about this problem in this thread you will find it!!
All the best.
#93
Posted 14 January 2012 - 08:17 PM
It might pay to bounce it off yet another person and he's a top bloke. Tell him I told you to call him from the GMH-T Forum and i'm sure he will give you some time mate! 02 9623 2416 - Mark - Eze10s
http://www.eze10sperformance.com.au/
#94
_76S.L.R_
Posted 15 January 2012 - 11:37 AM
#95
_355 EH_
Posted 15 January 2012 - 04:21 PM
#96
_WYLDLC6_
Posted 15 January 2012 - 04:24 PM
What would i be looking for with sideplate covers off, would there be oil pumping out.
Thanks tiny, we will get too the bottom of this and im happy to talk to anyone about it so i'll try and get in contact with him over the next couple of days.
355 EH, i dont think so, what would i bee looking for. Do i have engine running to do this.
Cheers guys, Chris.
Edited by WYLDLC6, 15 January 2012 - 04:25 PM.
#97
_355 EH_
Posted 15 January 2012 - 04:34 PM
#98
Posted 15 January 2012 - 04:46 PM
#99
_WYLDLC6_
Posted 15 January 2012 - 04:53 PM
Chris
#100
Posted 15 January 2012 - 04:55 PM
