Low oil pressure
139 replies to this topic
#101 _WYLDLC6_
_WYLDLC6_
Posted 15 January 2012 - 05:03 PM
none whatsoever bomber lol. Really a bit out of my depth there.
#102 _355 EH_
_355 EH_
Posted 15 January 2012 - 05:39 PM
oiling band is the grey recessed area that goes 360deg around the outside of the lifter body. if any of that sticks out of either end of the lifter bore in the block then oil escapes and releases the oil pressure from the oil gallery in the block.
Edited by 355 EH, 15 January 2012 - 05:40 PM.
#103 _Bomber Watson_
Posted 15 January 2012 - 06:07 PM
If you have a look, you will get what were on about
Basically, the grey bit in the pick Andy posted up, and the description Paul gave, you shouldt be abel to see that whilst turning the engine over by hand. Either from above (through the sideplates) or from below (looking up from the sump area)
#104 _WYLDLC6_
_WYLDLC6_
Posted 15 January 2012 - 06:24 PM
Yeah cool i understand that bit but what would cause this to happen.
Would it be pushrod length when at full lift the pushrod being to short and allowing this to occur.
Cheers chris
#105 _oldjohnno_
_oldjohnno_
Posted 15 January 2012 - 06:33 PM
I really doubt that the oil band is getting exposed - if it was the idle pressure would be down as well. Plus it would probably have been one of the first things the builder would have checked.
If and when you do the pressure test you wouldn't be looking for any specific amount of oil, what you'd be watching for is a noticeable increase when the pressure goes over 30 psi.
#106 _WYLDLC6_
_WYLDLC6_
Posted 15 January 2012 - 08:23 PM
So basically remove sideplates and rocker cover and start it up and check it that way.
#107 _oldjohnno_
_oldjohnno_
Posted 15 January 2012 - 08:48 PM
The height of the lobe nose is limited on the Holden six by the size of the skinny cam journals, so the oil band shouldn't really be exposed at full lift unless they were the wrong lifters altogether. Likewise at zero lift, even with a much reduced base circle it's unlikely the band would become exposed so long as they were the right lifters. And again, the OK idle pressure indicates otherwise anyway.
You could try cutting the top out of an old rocker cover or trim the top off some old sideplates so you could run it without making too much of a mess. Watch how much oil flows at say 1000 - 1500rpm and compare it to what you get at 30psi (say 3000rpms or so).
If you don't see anything obvious you may have to drop the sump off and pressure test it as described earlier.
#108 _WYLDLC6_
_WYLDLC6_
Posted 19 January 2012 - 12:07 PM
Tiny, i gave mark at easy10s a call today, nice bloke but basically same as everyone else. Never heard of it happening and said that basically weve covered everything it could be, so the frustration continues.
Engine builder is actually going to come to my house next week and do some testing and checks with it while its in the car and running.
Guess we'll just see how that goes.
Thanks Chris.
#109 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 19 January 2012 - 01:09 PM
Sorry to hear Chris :(
I'm glad he helped you out, he's a top
Bloke!
#110 _Liam_
_Liam_
Posted 19 January 2012 - 03:00 PM
I know this has been said but it definitely isn't a faulty bypass valve, or heaven forbid a bypass valve put in back to front?
Edited by LX Torry Freak, 19 January 2012 - 03:01 PM.
#111 _oldjohnno_
_oldjohnno_
Posted 19 January 2012 - 04:07 PM
The only way that I can think of where a bypass valve could cause this situation would be if the bypass was blocked off and the filter was unable to pass enough oil (either because it was dirty or just too small/unsuitable for the job).
#112 _WYLDLC6_
_WYLDLC6_
Posted 20 January 2012 - 06:18 AM
The bypass valve is in the pump i guess. Id be a bit stiff for 3 pumps to have that happen.
#113 _Ned Loh_
_Ned Loh_
Posted 20 January 2012 - 08:35 PM
Odd. Sorry to read about it. I am sure it's frustrating. I started building my own engines following a similar experience (and I'm a tightarse and needed more money for racing).
My suggestion is to take it out and pull it down yourself. It should only be an afternoon to get it on a stand. THEN GO THROUGH EVERYTHING YOURSELF. (yes I have trust issues!)
#114 _WYLDLC6_
_WYLDLC6_
Posted 21 January 2012 - 07:06 AM
Yeah i'd love too but probably not confident enough to do it. If it was just a stocker i'd give it a go but whilst its under warantee i'm better off just leaving it alone.
If anything though i have learnt lots through this experience lol.
Cheers Chris.
#115 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 23 January 2012 - 01:14 PM
does this engine have a main's stud girdle fitted?
#116 _WYLDLC6_
_WYLDLC6_
Posted 23 January 2012 - 01:30 PM
No it doesnt.
Cheers chris
#117 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 23 January 2012 - 10:10 PM
any reason you asked this Kevin?
#118 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 23 January 2012 - 10:17 PM
arh not really mate just grasping at straw's, and trying to relate to other's.
i figured that with the girdle bolted down, if the caps werent all the same height and eng wasnt line honed with girdle fitted it could have distorted the block enough to open the clearances up.
im just a little weary on them as ive been told by my eng builder buddy that in certain applications they like to turn main bearings out. ie 308's.
#119 73TORANA!
73TORANA!
  • 163 posts
  • Name:Geoff
Posted 09 July 2012 - 10:48 PM
Hey chris any updates on your oil pressure problem .
Geoff.
#120 Peter UC
Peter UC
  • 771 posts
Posted 09 July 2012 - 10:53 PM
He got fed up, lost interest and sold the car, it is the new owners problem. Chris now owns a HZ one tonner.
#121 _WYLDLC6_
_WYLDLC6_
Posted 10 July 2012 - 10:17 AM
Yep Pete summed it up perfectly. After 2 and half years and over tipping money into it I sold it.
Honestly I am actually enjoying playing with cars again now.
I know that the new owner has tipped about 2g into the motor lately but I'm unsure on the outcome.
Did hear that car will probably be on the market again soon lol.
Cheers Chris.
#122 73TORANA!
73TORANA!
  • 163 posts
  • Name:Geoff
Posted 10 July 2012 - 04:02 PM
Sorry to hear you couldnt solve it but its good to hear you have a new toy .
Have fun ,Geoff,
#123 orangeLJ
Posted 10 July 2012 - 04:46 PM
did you sell it locally Chris?
#124 _WYLDLC6_
_WYLDLC6_
Posted 10 July 2012 - 05:11 PM
Yeah I did mate. There was a few other reasons I sold it, but basically couldn't stand looking at it anymore.
It hardly moved for 3 years and is lost total interest in the end.
I actually enjoy working on something different after having the torry for so long.
It is funny fixing someone else's crappy work but it is an extremely clean car.
New paint, 308, forged bottom end, reverse cowl scoop, fully fabricated tray with tubs and comfortably fits 10s on the back, n2o etc.
Few things to sort but nothing major. And the funny thing is I actually had cash left over lol.
#125 orangeLJ
Posted 11 July 2012 - 09:07 AM
Sounds like you got a bargain with the new toy!
Can completely understand where you are coming from. Throw up some pictures of the tonner!
