Low oil pressure
#126 _WYLDLC6_
Posted 11 July 2012 - 04:25 PM
Probably was a bargain but I also think the even now overiflated prices of torries helped.
I'll definitely get some pics up once I've finished a few things off.
#127
Posted 10 November 2012 - 12:54 PM
Ive got a known earth/electrival gremlin that plays havoc with guage readings, but as with all things, you just kind of know where it should sit and how various quirks behave in your car.
So when it dropped to near zero and refused to come up with revs (had been fine cold) as you also do, every noise became a freak out moment (are the rockers getting noisier, pull over turn it off, feel everything check sender wires, start and listen etc)
Finally got around to putting a mechanical guage in today (temporarily) and found the following-
40psi cold idle pressure
43psi cold @2000rpm
At oprating temp
20-25psi at idle
40psi at 3500-4500rpm.
Chasing an electrical problem now, but its nice to know im not pulling the motor down again .
Im guesing that once hot, the sender is not reading correctly, and combined with my dash demons, was giving a false oil pressure reading. New guages I have are mechanical, so should solve that eventually.
#128
Posted 10 November 2012 - 02:00 PM
#129
Posted 10 November 2012 - 08:43 PM
#130 _gtrtorana_
Posted 10 November 2012 - 09:26 PM
#131 _coupe202_
Posted 11 November 2012 - 07:38 AM
#132 _gtrtorana_
Posted 11 November 2012 - 10:01 AM
#133
Posted 11 November 2012 - 11:54 AM
#134 _coupe202_
Posted 11 November 2012 - 04:21 PM
#135 _gtrtorana_
Posted 11 November 2012 - 04:45 PM
Cheers for the tip coupe202. I will add it to my to-do list.would fit a 75amp alternator in your case gtrtorana I had a 75amp now i have gone to 120amp but mine is EFI
#136
Posted 12 November 2012 - 08:38 AM
Comes pretty well reccomended, not overly cheap (thats $70 worth of oil in those 5 bottles) but its cheaper than some of the other stuff people run (like royal purple etc etc)
#137 _Ned Loh_
Posted 12 November 2012 - 09:52 AM
Mechanical gauges all the way!!
I run mechanical, but there are pluses and minuses to both. I clearly recall pumping the oil from the sump in my late teens, due to poor installation of the copper lines.
#138 _Ned Loh_
Posted 12 November 2012 - 09:56 AM
Also, grabbed this to give it a whirl too
I've heard good things about that oil, but have never tried it (mostly because I'm a tightarse). Let us know how your filter looks when (if?) you cut it open.
#139
Posted 12 November 2012 - 11:22 AM
Its just a prick they dont do it in bulk.
#140 _Ned Loh_
Posted 12 November 2012 - 03:15 PM
I plan on cutting open the current filter (been running Penrite) and doing a comparo in 6 months time when I change the oil (hey, its $70, I may as well draw out the oil change! haha)
Cool. Post up in six months if you remember.
