Posted 16 January 2012 - 08:27 PM
Can anyone please tell me whether there is any real advantage fitting an L34 fuel pump over the standard ones? I know they are slightly better in pressure but do they actually deliver better volume? The reason I ask is that my new 308 drains my 770 Holley dry full noise in third gear. I have since fitted a fuel log and that has improved things quite significantly but want to be sure that fuel volume meets the engine needs. I really don't want to go down the electric pump avenue as I really want to maintain the stock fuel system. I know that I am probably on the border line of exhausting the potential of the standard system but want try and keep the system as stock as possible using the best available stuff. At this stage I haven't been able to check my current fuel pressure but suspect it is ok.
Cheers, Gerry
Posted 17 January 2012 - 07:56 AM
I am running a L34 spec pump on my 355, I was originally running it with standard fuel lines etc, but I have since upgraded the fuel line as well to 3/8th (-6AN)
With this setup, my fuel pressure sits on about 6psi, which is pretty much what I have been told to set an electric pump to...
Saying all this though, my engine is still fresh and hasn't seen much action... Once I have had it on the dyno, I'll get a better idea if the L34 pump is up to the task... If not, I will go an electric pump.
Posted 17 January 2012 - 08:07 AM
Posted 17 January 2012 - 09:59 AM
Exactly you need the bigger fuel lines to deliver volume. The L34 pump delivers higher pressure with standard fuel lines, remove the fuel lines replace with bigger lines and increase the flow the pump will deliever around the same pressure as a standard pump then.have you increased the size of your fuel line yet?
Posted 17 January 2012 - 11:36 AM
Thanks, Gerry
Posted 17 January 2012 - 12:50 PM
Posted 17 January 2012 - 12:58 PM
Exactly you need the bigger fuel lines to deliver volume. The L34 pump delivers higher pressure with standard fuel lines, remove the fuel lines replace with bigger lines and increase the flow the pump will deliver around the same pressure as a standard pump then.
I thought the pressure delivered by the pump is dictated by the spring in the pump.
A larger delivery line would have no effect on fuel pressure at idle. The only time the larger delivery line would make a difference is if the carby was consuming fuel at a rate higher than the standard delivery line can deliver at the fuel pump pressure.
Posted 17 January 2012 - 02:11 PM
Thanks for all input!
Posted 17 January 2012 - 02:58 PM
Posted 17 January 2012 - 03:57 PM
#11 _ass308_
Posted 17 January 2012 - 06:09 PM
did the L34 or A9X have a bigger outlet from the tank,and bigger fuel lines,compared to standard REDA9X ?
Posted 17 January 2012 - 08:35 PM
Posted 17 January 2012 - 08:56 PM
just through losses of the 5/16 cross sectional area from tank to pump to carb.
Never understood the bigger line concept hence the quest.
#14 _ass308_
Posted 18 January 2012 - 06:35 AM
i had to use a standard tank,to get engineering,and the standard outlet wasnt enough,to drive over 2500rpm on the freeway,without running out of fuel.
the rest of my fuel system was 10mm at the time.
my normal set up which keeps up with my 355 no problems at all is,
half inch outlet from tank,to a 6-8 psi electric pump(not big pressure).a 10mm line from pump to carb,with no regulator at all.
Posted 18 January 2012 - 07:20 AM
Posted 18 January 2012 - 03:49 PM
Thanks again for the input.
#17 _mad350_
Posted 26 January 2012 - 10:32 AM
Posted 29 January 2012 - 06:20 PM
for a N/A V8 street application.
fuel vapour separator and return line
increased fuel line size
fuel line heat shielding
increase fuel pump pressure 3 - 7 psi
dual mechanical/electrical fuel delivery system. Electrical intank fuel pump ( EFI style control)and Mechanical pump on the motor.
Big single electrical (at the tank) fuel pump. keeps whole line under pressure!
You don't need fuel pressure:- all you need is volume (3 psi is fine as long as you have volume)
9 psi and higher cause needle and seat premature wear and failure.
High pressure can effect the float level . it can cause a higher float level needed to shut off the needle and seat against a higher input pressure..
(revised fuel pressure means revised float level)
rubber tipped needle and seat is always good @ 7psi or above.
N/A motors are easy. Blown/ injected/ surge tank/ return fuel systems can be a nightmare.
Balfizar
Edited by Balfizar, 29 January 2012 - 06:32 PM.
Posted 01 February 2012 - 10:52 AM
I was told a couple years ago there used to be an external fuel bowl available for the standard carbies to prevent fuel starvation, as the small bowl can heat up and fuel vaporise which leads to the car starving of fuel - does anyone know of this? (sorry if this is slightly off topic)
Posted 01 February 2012 - 11:30 AM
#21
Posted 02 February 2012 - 12:49 PM
#22 _Jewboy_
Posted 20 February 2012 - 08:13 AM
#23
Posted 20 February 2012 - 11:58 AM
#24
Posted 01 March 2012 - 06:34 PM
To put it in simple terms it's like putting your thumb over the garden hose, pressure increases flow decreases.
L34 had the 3/8 fuel line from the tank to the pump, but it was still 5/16 up to the carby. You could run the L34 pump with 3/8 lines and deliver more fuel to the carby.
#25
Posted 02 March 2012 - 08:45 AM
The L34 pump will deliver more pressure than a standard pump with the same size fuel lines. If you increase the size of the fuel line from 5/16 to 3/8 what you would find is the pressure drops to around the same as the standard pump delivers with the 5/16 line, but the flow is increased.
Yeah, I have noticed that Since I upgraded my fuel line from standard, to 3/8th the pressure at the gauge has dropped to about 5.5-6psi max now, as opposed to much closer to 7psi when I just had the standard lines...
But As Red says, the flow as increased, which is what the important bit is...
Is there a way that you can measure the GPH of these pumps? Or is that too hard because it fluctuates to much? I have 'heard' that they 'can flow' up to 80GPH, but is that true or just someone making stuff up? haha.
I remember reading in a SM Tech article a while back this little equation.
GPH Required = Desired Horsepower x 0.55 / 6
On a 450HP engine, that is only like 41GPH, which really isnt all that much.
