Proportioning valve and Master Cylinder Kits
Posted 22 January 2012 - 12:26 AM
As my brakes are in very poor condition from the car have sat for a number of years... Id like to run a kit though everything. Ive dismantled the prop valve and its full of sludge...
The GM manual states its not able to be service and must be replaced... well in this day and age thats a bit hard to do...
Posted 22 January 2012 - 12:47 AM
Are there kits available for these???
Hi Brad
Getting a kit for the master cylinder shouldn't be too hard. Try Repco or your local brake repair shop.
From what I can gather you'll need to take the proportioning valve and all the O rings that came out of it to a brake shop to see if they can match up new ones for you.
#3 _My74LH_
Posted 22 January 2012 - 07:32 AM
I just bought a new master for $138 and had the p/valve recoed for $38 also recoed the booster total for the lott was $497, is it worth your time trying to get the M/C and P/valve recoed ?
Posted 22 January 2012 - 08:02 AM
Depends, if it is the original cast iron m/cyl and you want originality, then yes it is worth the effort.
Posted 22 January 2012 - 08:04 AM
Pretty cheap for the m/c and prop valve though.
But it sounds promising that I might be able to get some bits... One part I am worried about is the rubber seal that is fitted to the large bolt/fitting right at the end of the prop valve. It is full of cracks and deteriorated.
Edited by hanra, 22 January 2012 - 08:13 AM.
#6 _My74LH_
Posted 22 January 2012 - 08:27 AM
True that, But i didnt have the castiron one , so it was an easy decision for me ,I guess I would have gone your way if I had the orig one .
Posted 22 January 2012 - 08:29 AM
Posted 22 January 2012 - 11:32 AM
Posted 22 January 2012 - 11:44 AM
Posted 22 January 2012 - 11:46 AM
Posted 22 January 2012 - 11:50 AM
Thanks for that Dattoman! Appreciate your help!
