K-Frame legs: Detail on bolts attaching to side member needed
43 replies to this topic
#26 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 29 January 2012 - 08:01 PM
Persistence pays off mate :-). Torana's and big hammers go hand in hand LOL....
#27 _My74LH_
_My74LH_
Posted 03 February 2012 - 01:17 PM
Just found these bolts .
Edited by My74LH, 03 February 2012 - 01:21 PM.
#28 _GORMZ_
_GORMZ_
Posted 01 March 2016 - 04:59 PM
I'm doing exactly the same project, and need to know where you purchased the bolts, as mine are a bit old and bent.
#29 LXM21
LXM21
  • 450 posts
Posted 14 March 2016 - 08:04 PM
Make sure they are grade 5 bolts.
#30 tsn007
tsn007
  • 1,019 posts
  • Name:Tony
  • Car:LX hatch, LX sedan
Posted 30 December 2018 - 09:52 PM
old thread
what size nuts for the 4 top bolts on the k frame
#31 tsn007
tsn007
  • 1,019 posts
  • Name:Tony
Posted 31 December 2018 - 05:24 PM
The UC parts manual shows the leg bush fitted correctly. The LH and LX parts manuals are wrong.
how do the bolts in picture b, hold the kframe to the body
#32 hanra
  • 10,975 posts
Posted 31 December 2018 - 09:14 PM
Go take a look at your car and you will figure it out.
#33 tsn007
tsn007
  • 1,019 posts
  • Name:Tony
Posted 01 January 2019 - 06:25 AM
sorry , i can not remember how,
it was over 2 years ago i stripped the car
what size and  washer
#34 hanra
  • 10,975 posts
Posted 01 January 2019 - 08:29 PM
This help?
#35 Cook
Cook
  • 1,531 posts
Posted 01 January 2019 - 09:25 PM
Hi Tony, are you referring to the bolts that fix the K frame to the chassis at the rear via the outriggers.  If so Brads pics are what you need.  There is also a mounting bush that fixes to the outrigger arms.
If you are referring to the 4 bolts that come up through the chassis at the front, these are different.  They are sort of pressed in from the underside of the K frame and seated via 4 rubber (with metal sleeves) mounting bushes. Is that what you need info on?  Cheers Ron
#36 tsn007
tsn007
  • 1,019 posts
  • Name:Tony
Posted 02 January 2019 - 06:13 AM
yes Ron,
the 4 upper kframe bolts
#37 Cook
Cook
  • 1,531 posts
Posted 02 January 2019 - 09:29 AM
Tony, here is a pick of the bolts.  I think they are readily available at Restocountry or Rares but if you are just after the nut size let me know and I will dig one up form the garage. There are also some photos on the thread "K frame to body bushes" Cheers Ron.
Edited by Cook, 02 January 2019 - 09:35 AM.
#38 koalasprint
koalasprint
  • 297 posts
  • Name:Steve
  • Car:LX SS Hatch
Posted 06 January 2019 - 08:58 PM
The original four bolts that mount the k frame to the chassis near the UCA don't have hex heads, but those in Resto Country should work. I was able to use a sprak plug socket to do them up/undo them. You need something with a long reach.
#39 Cook
Cook
  • 1,531 posts
Posted 06 January 2019 - 10:28 PM
Hi Steve.  I'm curious as to what heads yours have if not hex.  I can't be sure if they were original or not but the ones that were on my car were hex headed. Cheers Ron
#40 koalasprint
koalasprint
  • 297 posts
  • Name:Steve
  • Car:LX SS Hatch
Posted 07 January 2019 - 07:21 AM
They're a semi elliptical shape. The splines hold them from spinning as you tighten or loosen them. I have a few spares under the house. I'll see if I can get a pic when I get back home later in the week. The also have a point on the threaded end to help with loacting the frame and bushes, etc.
Cheers, Steve.
#41 CYCO355
CYCO355
  • 152 posts
  • Name:Cameron
  • Car:G PAK and a LH sl, VS Senator, VE SSV sedan
Posted 07 January 2019 - 03:06 PM
#42 Cook
Cook
  • 1,531 posts
Posted 07 January 2019 - 03:19 PM
Ok cool.  Mine were definitely not original then. Cheers Ron
#43 Cook
Cook
  • 1,531 posts
Posted 08 January 2019 - 08:27 AM
Cameron.  I am getting old and forgetful.  I had another look at my bolts and they are as you describe. Cheers Ron
#44 tsn007
tsn007
  • 1,019 posts
  • Name:Tony
Posted 08 January 2019 - 06:47 PM
i was able to but nuts for these bolts , thanks
But the 2 outrigger bolts and large washer are not as easy to find
