Axistr's Father & Son LH SLR Project.
333 replies to this topic
#326 Shiney005
  • 9,613 posts
  • Car:Toyota Mirai
Posted 08 January 2016 - 03:53 PM
They have come up a treat. What were you using for your light source Axistr? And what size are the rims on your Clubbie? They fill the guards out nice.
Do you know if any of the non SLR digital cameras have the capacity to hold the "shutter" open for prolonged exposure?
#327 axistr
axistr
  • 1,212 posts
Posted 08 January 2016 - 06:26 PM
Thanks' for the tips Sam, as I said I am only a armature photographer with not much idea. I did do a few outside a few weeks ago but to much moon light on the night. I only have a cheap Sony digital camera and its not an SLR like the car. The camera only has a maximum of 30 seconds shutter opening. The lighting used was a Narver hand held LED mechanics light. Your right to many reflective surfaces in the shed.
Grant 20" on the clubby.
#328 HDT166
HDT166
  • 115 posts
  • Name:Aaron
  • Car:Lx 2 door, VC HDT
Posted 09 March 2019 - 05:00 PM
Just loved reading this!
May I ask what air con condenser you used?
#329 axistr
axistr
  • 1,212 posts
Posted 10 March 2019 - 06:56 AM
G'day HDT166, the hatch a/c compressor is a denso originally from a 98-2001 Toyota hilux 4x4 diesel. On the SLR I used a Sanden compressor which I picked up from cool drive. Choose it from their parts book as it had a 6pk belt drive and four bolt up pattern which made it easy to adapt to my original vr commodore compressor mount with the power steering.
#330 HDT166
HDT166
  • 115 posts
  • Name:Aaron
Posted 10 March 2019 - 10:17 AM
Thanks for the info , but I was after what condenser you used, unit in front of the radiator . :)
#331 axistr
axistr
  • 1,212 posts
Posted 10 March 2019 - 01:20 PM
Sorry forgot to add that part, brain fade/old age/dementia. Both cars have Denso condensers and internal evaporators units from a Toyota Hilux LN106 model from memory.
#332 HDT166
HDT166
  • 115 posts
  • Name:Aaron
Posted 10 March 2019 - 10:34 PM
Thanks heaps mate, love your work :)
#333 350mick
350mick
  • 12 posts
  • Car:Lx Torana
Posted 18 May 2022 - 10:01 PM
What did you do to fit the gearbox, looks like you have not touched the tunnel? Mine sits way higher, did you lower the engine to get that angle?
Hi myss427
Have you got pictures of the floor modifications
That’s you did to fit the T56 Magnum
I’m having trouble with mine
Looks like I need to cut the floor
#334 myss427
myss427
  • 1,636 posts
Posted 19 May 2022 - 10:51 AM
Hi myss427
I do, but on my home computer, I cut the floor out over the top of the rails from the firewall to the floor join seam behind the seats, removed it all. Then source a VL Commodore front floor trimmed it up to suit the same space, had to remove the existing Commodore brackets and chassis, but when welded in it is not noticeable except a huge tunnel. Gearbox angle is 3 degrees, same as depress, before tunnel it was 6!
