Axistr's Father & Son LH SLR Project.
333 replies to this topic
#201 axistr
axistr
  • 1,212 posts
Posted 17 July 2014 - 07:31 PM
Agree with you 100% Andy, I do not recommend anyone using plastic style aftermarket coupling unless they have standard manifolds on their V8 or an inline six cylinder. They just don't like the heat and soften easily if the heat source is close, I prefer to use the material/rubber style coupling.
#202 axistr
axistr
  • 1,212 posts
Posted 18 July 2014 - 09:01 AM
Andy Just out of curiosity who's coupling is that in the photo.?
#203 ls2lxhatch
  • 5,332 posts
Posted 18 July 2014 - 03:29 PM
The picture is from this thread.
http://www.gmh-toran...-kits/?p=762910
#204 axistr
axistr
  • 1,212 posts
Posted 20 July 2014 - 12:15 PM
After much grinding the brake calliper brackets finally fitted. Only had to take 150" tho off the disc rotors O/D.
Assembled the clutch and fitted the gearbox onto the engine and the whole assemble sat on my portable bench to wheel it under the hoist.
#205 axistr
axistr
  • 1,212 posts
Posted 20 July 2014 - 12:17 PM
And its finally in, Christ these EFI engines are a tight fit. Still a long way to go but one step closer.
#206 SmacT
SmacT
  • 979 posts
  • Name:Sam
  • Car:LX 4dr 383, TKX, BW
Posted 20 July 2014 - 04:28 PM
Nice work Lenny. I'd kill for that hoist! What's the next job?
#207 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 20 July 2014 - 05:51 PM
Coming up a treat!  Keep up the good work.
#208 308mate
308mate
  • 523 posts
  • Name:scott
  • Car:76 SS hatch (Royal Plum, Chevron Chamois interior), HQish Van (Orchid Metallic)
Posted 20 July 2014 - 06:37 PM
Love your work. A work bench on castors & a hoist. How handy. The yellow looks great.
#209 axistr
axistr
  • 1,212 posts
Posted 28 July 2014 - 03:55 PM
I have been literally in the engine bay for two days trying to sort out the harnesses, heater hose & tap etc etc.. I modified an air box from a Vy commodore but when I put it in today it looked shit house. I might modify and try the original VS HSV box which is in the last photo.
I have seen a couple of 5lt efi conversions and the airbox they have used looks neat but I don't know what they were out of, and carn't seem to find any photos of them.
Please post up some photo if you have any that might fit the bill. I don't like open pod filters so would prefer to go with something that has that factory look about it.
#210 76lxhatch
  • 7,208 posts
Posted 28 July 2014 - 04:07 PM
Maybe a V6 one would be the go? Same box as a V8 (except HSVs which had the smoother version like you've got there) but the inlet is more of a 45 degree on the corner rather than straight in the side.
When I did the VK I modified an HSV box to it suited a V6, maybe something like that is an option if you want to muck around with it?
#211 N/A-PWR
  • 9,639 posts
Posted 28 July 2014 - 04:11 PM
Getting Closer Lenny,
has got to be right, looks good from here.
#212 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 28 July 2014 - 06:47 PM
I modified a v6 airbox to fit and it looks ok, but I think the hsv ones look better (I was too cheap to buy one!).
Edited by UCgazman, 28 July 2014 - 06:51 PM.
#213 SmacT
SmacT
  • 979 posts
  • Name:Sam
Posted 28 July 2014 - 09:08 PM
I am struggling with this bit too. I am tossing up making a box to suit the shape and a standard air filter out of mild steel and painting it, as i can't find an airbox that fits like I want it to. I have put it in the too hard basket for now, but I can afford to because my car is far from the stage yours is.
With your skills and equipment, could you make something custom to fit and look just right? Then sell one to me... (you saw that coming I am sure... :-))
Forgot to say - which heater hoses did you end up using? I am just shortening my original donor engine ones (VN V8) but would rather ones that look neater like yours.
Edited by SmacT, 28 July 2014 - 09:11 PM.
#214 _LS1 Hatch_
_LS1 Hatch_
Posted 29 July 2014 - 01:36 AM
I did up an aluminum airbox...
#215 SmacT
SmacT
  • 979 posts
  • Name:Sam
Posted 29 July 2014 - 04:54 PM
Yeah! Like that. Nice one Jeff.
#216 ls2lxhatch
  • 5,332 posts
Posted 29 July 2014 - 07:11 PM
A few people seem to have made the stock airbox fit reasonably well. Picture from this thread.
There are a few airboxes discussed in this Autospeed Article.
I made a fiberglass airbox.
Edited by ls2lxhatch, 29 July 2014 - 07:22 PM.
#217 axistr
axistr
  • 1,212 posts
Posted 29 July 2014 - 07:30 PM
Wow Andy that looks very flash. I am going to play with the HSV box that come with the engine and see how I go. There not a very big box but still might do the job.
#218 a9x868
a9x868
    maurice mead of hatchbacks
  • 1,418 posts
  • Name:facebook dave
Posted 29 July 2014 - 09:09 PM
lenny
have you thought of cutting the guts out of an orig
style battery
taking one side out
and mounting a pod filter inside
original battery tray and fake leads etc!
would go some way to the original GMH look!
just a thought!
davemc
#219 N/A-PWR
  • 9,639 posts
Posted 30 July 2014 - 02:34 AM
Flash is very clean looking.
just need to decide on your design Lenny
#220 axistr
axistr
  • 1,212 posts
Posted 01 August 2014 - 07:01 PM
Finally got the front brake callipers milled, redrill and plugged to suit the Torana. Back on the car bleed and tested all good now.
#221 axistr
axistr
  • 1,212 posts
Posted 01 August 2014 - 07:11 PM
Thanks for the comments and photos of the air boxes guys.
I ended up fitting a HSV air box that that I had lying around for some time. It didn't take much work to get it to fit and I can adapt a cold air induction pipe up without to much mucking around. I think it fits in with the look I was trying to achieve.
Thanks Andy the link you posted recommended this air box as being one of the better ones to use. I thought it may have been a bit small but the figures show it flows better than I thought.
#222 ls2lxhatch
  • 5,332 posts
Posted 02 August 2014 - 11:36 AM
The HSV air box looks at home in the engine bay.
What is the length and width of the panel filter for the HSV box? Just the filter area not including the rubber seal.
Edited by ls2lxhatch, 02 August 2014 - 11:38 AM.
#223 76lxhatch
  • 7,208 posts
Posted 02 August 2014 - 02:08 PM
The HSV box uses the same filter as the standard one, its just a lot more rounded and has a snorkel thingo out the front of the base instead of just a hole (having said that I can't see it above, maybe that's a standard bottom half?)
#224 axistr
axistr
  • 1,212 posts
Posted 02 August 2014 - 02:55 PM
I will get back to you on the measurements but I think 76lxhatch is right about being the same filter. The snorkel in the base was cut off so it didn't hit the alternator and the electric fans. I will connect a cold air pipe to it from below and keep the same size inlet so I don't stuff up the flow.
#225 ls2lxhatch
  • 5,332 posts
Posted 02 August 2014 - 03:54 PM
I was just interested in running the usable filter dimensions through the K&N filter sizing formulas to see what CID and RPM the filter element can theoretically handle.
