Just gave this manifold a strip down and clean and found some corrossion and a hole..... Can this be re-welded and repaired???
Can Inlet manifolds be welded/reparied?
, Feb 04 2012 12:42 PM
4 replies to this topic
Posted 04 February 2012 - 12:42 PM
Posted 04 February 2012 - 12:55 PM
just had one fixed myself, cost $125 for about the same amount of work...just took it a cylinder recon joint
Edited by GML-31, 04 February 2012 - 12:56 PM.
Posted 04 February 2012 - 01:10 PM
yep, the manifold on the targa hatch, sitting under those 4 beautiful webers , is the shittiest piece of porous aluminium you can ever see. Been welded and patched a number of times
Posted 04 February 2012 - 01:33 PM
Ahhhh
Just bog it up with Devcon ... hehe
Yes they can be repaired
I was told to always use a better grade of coolant when theres been a repair to alloy
SO I would suggest using the V6 commodore coolant as a minimum
Genuine stuff... straight from the dealer.... cheap enough
#5 _Bomber Watson_
Posted 04 February 2012 - 03:42 PM
Yeah i could fix that.
