Reading Dyno Sheets
_Yella SLuR_
Posted 31 May 2006 - 04:39 PM
_Yella SLuR_
Posted 31 May 2006 - 04:41 PM
_[2_FLY]_
Posted 31 May 2006 - 05:32 PM
Looks like and ignition breakdown right up the top too. Your afrs start pretty good but are getting a touch rich at the top end. Ideally you want to keep them in the mid-low 12s
Posted 31 May 2006 - 08:46 PM
I wouldn't worry about the jaggered looking curves. When the ramp starts the engine is in a state of transition and it takes a sec. or 2 to sort itself out. It does go progressively lean in the top end though, this could be fixed with a air flap and/or needle hanger adjustment. I would really want to see the whole AFR dropped to mid, low 12s for safe max power. The dip in power at the end could be due to the operator getting off the pedal, or something else, possibly valve springs.
Let me know if you want some dyno time, I like playing with the old Q jets.
There is a bit of a hesitation at the start of the curve (around the 88km/h mark).Mine used to do that was a powervalve problem.
I would say this is caused by the air flap opening too quick as evidenced by the lean condition, but would warrant further investigation.
13 :1 is actually lean.
An ignition miss will show up in the AFR as a rich spot, as fuel is passing through the engine without being burnt. No evidence of that here.
_Yella SLuR_
Posted 31 May 2006 - 09:23 PM
I promise you we will play at some time Andrew, just don't ask me when at this stage. Poor ole car hasn't got much of a look in of late.
_Oldn64_
Posted 31 May 2006 - 10:52 PM
What needles (secondaries) and hanger are you running?
_devilsadvocate_
Posted 01 June 2006 - 07:54 AM
_Yella SLuR_
Posted 01 June 2006 - 08:10 AM
