Gasket Goooooo
23 replies to this topic
#1 hanra
  • 10,977 posts
Posted 10 March 2012 - 07:51 PM
Whats a recommended brand/type of gasket goo to use on Holden 308, for things like inlet manifold, timing case, water pump, oil pump, sump?
#2 _Bomber Watson_
Posted 10 March 2012 - 08:02 PM
THREEBOND!!!!
#3 hanra
  • 10,977 posts
Posted 10 March 2012 - 08:09 PM
You sound excited!!! Hahahaha, thanks!
Any particular type? It would be used in conjunction with a gasket.
Judging by the website, I would assume the yellow one?
http://www.threebond...u/1100&1200.htm
#4 308 Sunbird
308 Sunbird
  • 973 posts
  • Name:Stuart
Posted 10 March 2012 - 08:20 PM
Brad, I've used genuine Holden Sealing Compound (3835215) for years- never let me down.
Available in 250ml tins from Holden.
#5 hanra
  • 10,977 posts
Posted 10 March 2012 - 08:24 PM
Interesting, Ill give my local stealership a call on Monday to see if they stock it.
Otherwise I was thinking perhaps Permatex # 2?
#6 _Bomber Watson_
1207C is my preferred goo.....Expensive but awesome.
I never use RTV in conjunction with a gasket, only in place of it.
For cork gaskets i just use a bit of contact adhesive, and for paper gaskets i use either Loctite #3 or #4 gasket adhesive, depending on the position.
#7 _robslxhatch_
_robslxhatch_
Posted 10 March 2012 - 08:48 PM
Remember that less is often better , I don't put anything on waterpump timing case or oil pump gaskets usually . I may put a small amount around areas where coolant flows but if you use any more than required you could end up with a silicone worm blocking an oil pick up or radiator core. Also I do not use silicone on rubber or cork.
#8 _robslxhatch_
_robslxhatch_
Posted 10 March 2012 - 08:50 PM
:spoton:
#9 _oldjohnno_
_oldjohnno_
Posted 10 March 2012 - 09:34 PM
These "which sealant?" threads always end up with a heap of different people very strongly recommending a heap of different products. The truth is that with reasonably good practices and modern products you'd actually have to try pretty hard to build a leaker.
A couple of comments: the very early RTVs (like the original Silastics) had very poor oil and fuel resistance and didn't last well on sump or manifold gaskets. Those days are long gone but still people avoid them for this reason even though the OEMs have been using them for a decade or more. There are specialty sealants made for anything you can think of (and some people will use 4 or 5 different ones on a single engine) but really you can assemble something like a Holden engine using nothing more than Loctite Black Maxx or Wurth 250 or any of the million equivalents. You can use it on anything; paper, rubber, cork (cork usually weeps a bit without sealant). It works with or without a gasket, but if you want something a bit stiffer for gasketless joints the grey stuff is the go. But really if you have a tube of black and some thread sealant you can do the entire engine.
#10 dattoman
  • 16,487 posts
Posted 10 March 2012 - 09:51 PM
3J... non hardening
And GHM sealant on any bolts that go thru water
#11 hanra
  • 10,977 posts
Posted 11 April 2012 - 04:41 PM
Just contacted my local dealership with that P/N, lucky cause they had no idea what I was on about... Holden Sealing Compound...? Really???
Anyways.. $72.60 RRP ouch...
#12 dattoman
  • 16,487 posts
Posted 11 April 2012 - 08:03 PM
Sealer Head Stud 250ml (Delco) 3835215 621-CAWA-Kelmscott 1 List: 55.00 55.00
Local Coventrys
#13 hanra
  • 10,977 posts
Posted 11 April 2012 - 09:25 PM
Cool man. Not sure if we have a coventrys here...?
#14 dattoman
  • 16,487 posts
Posted 11 April 2012 - 10:06 PM
Unlikely
But what I'm saying is there are options besides just your dealer
Just for shits and giggles ring your "local" repco
http://www.fullnoise...tuds-250ml.html
https://www.american...n=1530136216525
#15 _Bomber Watson_
Posted 11 April 2012 - 10:13 PM
http://www.cgl.com.a...s/find-a-branch
None within 300km of me, where are you Hanra??
#16 _Quagmire_
_Quagmire_
Posted 11 April 2012 - 10:55 PM
know a workshop?
got a abn? or know someone with one
covs posts/deliver...i'm sure of it
you may need a trade account but
or assk auto prro/auto barn to get some in
#17 hanra
  • 10,977 posts
Posted 11 April 2012 - 11:57 PM
I'm up in the sticks. Townsville would be the nearest, 380odd clicks? The one in Cairns is closed down.
Would the Permatex # 3 do the job? I got a full bottle of that!!
#18 _Quagmire_
_Quagmire_
Posted 12 April 2012 - 02:35 AM
hunra...i'm sure a forum member will pick it up off the counter and post to you if you ask nice
and i know auto pro/auto one/auto barn will order it in.....
#19 _oldjohnno_
_oldjohnno_
Posted 12 April 2012 - 06:57 AM
Loctite 567 pipe sealant is as good as anything else on head bolt threads, and you can get it anywhere.
#20 hanra
  • 10,977 posts
Posted 12 April 2012 - 10:11 AM
I like that option better!!!! Thanks.
#21 _ingles_
_ingles_
Posted 16 April 2012 - 11:43 AM
Go with the holden sealer for head bolts for sure; for silicon /silastic type sealer- try the local toyota dealer; I think p/no. is 08826-00080a,or 00090a.Ones red, ones black-black one is awesome on oil and water joints.Red is for transmission and diff applications.Both work VERY well.They might even be Threebond gear, manufactured for Toyota.
#22 orangeLJ
Posted 16 April 2012 - 08:36 PM
I tend to just use the red permatex silicon on everything.... exhausts, oil pumps, water pumps, thermostats etc etc.
never had any problems, stays rubbery, great with heat and oil..
#23 _likatiger_
_likatiger_
Posted 16 April 2012 - 08:59 PM
Hanra, I work at a Repco store and we stock the Holden sealant. I can post you one if you wish.
Jason
Edited by likatiger, 16 April 2012 - 09:00 PM.
#24 hanra
  • 10,977 posts
Posted 16 April 2012 - 09:41 PM
Cheers mate. We have a Repco store up this way, but it may be more $$$ then Holden quoted? Plus freight costs. I think I'll take a chance with the Loctite stuff! Cheers.
