Door plastic trim chrome strip needs re-chroming
Ideas to redo
22 replies to this topic
#1 Pop's-SS
Pop's-SS
    Pops
  • 4,971 posts
  • Name:Barry
Posted 10 March 2012 - 08:31 PM
G'day All
My missus's Hatch is a B&B, (budget build) and I have sprayed the door trims black vinyl spray but the plastic strip has lost a lot of its plastic chrome finish.
Any ideas on how to get that chrome finish back ?
AND no, I do not want to send them to a u-beaut retrimmer as there is money to be spent elsewhere that is more important.
Regards ... Barry
Edited by Pop's-SS, 10 March 2012 - 08:32 PM.
#2 _Bomber Watson_
Posted 10 March 2012 - 08:38 PM
silver paint pen??
#3 TerrA LX
Posted 10 March 2012 - 08:44 PM
Pretty sure you can buy it on a roll just the same as pin strip, maybe try your local panel beating and spray paint supplier.
Edited by TerrA LX, 10 March 2012 - 08:45 PM.
#4 Pop's-SS
Pop's-SS
    Pops
  • 4,971 posts
  • Name:Barry
Posted 10 March 2012 - 09:12 PM
Two ideas that sound like a plan as I have to take the missus's Hatch back to the spray painter on Monday for minute touch up job on the respray.
Thanks .,.. Barry
#5 S pack
  • 15,762 posts
Posted 10 March 2012 - 09:32 PM
Yep, I've got a roll of chrome self adhesive tape approx 12mm wide that I found at an art supplies, probably 25 years ago though.
Did the chrome strips on my XU1 door trims, seems to last ok if you don't pick at it. I found the best way to install it was to remove all old chrome finish, carefully prepsol the plastic strips, carefully scuff the surface of the plastic strips with fine sandpaper and prepsol again.
#6 debkar
debkar
  • 912 posts
  • Car:1971 LC 2 Door
Posted 10 March 2012 - 09:40 PM
Hi Barry
SAAS product is till available from Autobarn. I did the LC GTR trims with SAAS chrome pinstripe, Also ebay from hobby stores in the US, chrome pin stripe is available.
As Dave says, prepsol helps it stick. It's hard to get it to go around tight radius, straight is easier and stays on well.
Regards Simon
#7 _Bomber Watson_
Posted 10 March 2012 - 09:44 PM
Thats a better idea, and yeah, autobarn stocks it still iirc.
#8 AbsynthHatch
AbsynthHatch
  • 741 posts
  • Name:Mark
Posted 10 March 2012 - 09:49 PM
Awesome info guys
#9 Pop's-SS
Pop's-SS
    Pops
  • 4,971 posts
  • Name:Barry
Posted 11 March 2012 - 07:43 PM
:clap: That's what I like about gmh-torana, you are bound to find a solution with the amount of knowledge here :spoton:
Regards .... Barry
#10 _j.e.d._
_j.e.d._
Posted 12 March 2012 - 02:40 PM
Would these work? I don't have my car nearby to check the width of the factory chrome moulding on the door panels, but they come in varying widths.
http://www.ebay.com/...r#ht_5931wt_939
http://www.ebay.com/...#ht_2545wt_1170
http://www.ebay.com/...r#ht_728wt_1170
#11 debkar
debkar
  • 912 posts
Posted 13 March 2012 - 06:44 PM
Hi,
I think 7mm would go close, I used 6mm tape on the GTR trims, but it was not quite wide enough,
Regards Simon
#12 S pack
  • 15,762 posts
Posted 13 March 2012 - 07:27 PM
The products in those ebay ads is more like the mylar chrome windscreen strip or body side protection moldings not a pin striping tape.
#13 debkar
debkar
  • 912 posts
Posted 13 March 2012 - 08:12 PM
Hi Dave
That's correct, you would need to remove the original strip or part thereof to fit this.May well be a better option that tape over the top.
The 7mm strip is 2.5mm in height, so quite feasible to use, once original strip is removed in part or full.
Regards Simon
#14 S pack
  • 15,762 posts
Posted 13 March 2012 - 09:52 PM
Hi Dave
Regards Simon
Hi Simon
Question is though, is it possible to remove the original strips without damaging the vinyl trim? I've never tried to do this so don't know if it could be done.
Dave.
#15 debkar
debkar
  • 912 posts
Posted 14 March 2012 - 07:43 AM
Hi Dave,
Not too sure, I have ordered some of the 7mm strip off ebay and will have a go at some old LC S trims I have,
Will be a few weeks, but I'll post up how it goes,
Regards Simon
#16 shadey1963
shadey1963
  • 343 posts
  • Name:Steve
  • Car:5/72 LJ S 2 door Model
Posted 14 March 2012 - 08:13 AM
Probably hard to go round corners though
#17 debkar
debkar
  • 912 posts
Posted 14 March 2012 - 08:23 AM
Hi Steve,
I think it would be, luckily the LC S trims are straight,
Even adding the pin stripe tape to my GTR trims was difficult getting the corners to look as they should,
Regards Simon
#18 shadey1963
shadey1963
  • 343 posts
  • Name:Steve
Posted 14 March 2012 - 08:38 AM
Could try these?
http://www.vinylgraphics.net/shopdisplayproducts.asp?id=190&cat=Mirror+Chrome+Striping
http://www.stickerart.com.au/?cPath=92_94&osCsid=5367dc68fc4903c4b3206d2f2c2b9737
#19 a9x868
a9x868
    maurice mead of hatchbacks
  • 1,428 posts
  • Name:facebook dave
Posted 14 March 2012 - 10:20 PM
close call guys but your not quite there yet
you need to think outside the square!
6mm is right though for all lh lx and most
other holden trim chrome
not to sure on lc lj apps
#20 _outer control_
_outer control_
Posted 16 March 2012 - 08:38 AM
A mate did his a9x door trims 10 years ago with chrome pin striping still ok used supa glue dab on ends
#21 _dagsy_
_dagsy_
Posted 06 November 2012 - 09:41 PM
did you get this to work? i have been trying to do the ones on my HB and bloody oath.....they look good for about a day and then it all starts to peel off.
completely removed old chrome tape scruffed up with 180 paper, wax & grease remover and even used a heat gun with contact cement
still trying!!!
#22 _lj tory_
_lj tory_
Posted 16 November 2017 - 07:06 PM
im trying to get this to work but not having much luck, facebook dave do u know of a better solution????
#23 Rockoz
Rockoz
  • 4,065 posts
  • Name:Rob
Posted 17 November 2017 - 09:10 AM
Have you thought about going to a signwriter and getting chrome sticker from them?
There will be lots af wastage but the stuff probably isnt that expensive.
1 metre or so should do a whole car.
Cut it to a basic shape then apply it.
Then trim it up as needed.
No problem with corners then.
