Not The Kingswood!
#76
_Woodsy_
Posted 21 January 2010 - 08:39 PM
#77
_Woodsy_
Posted 03 January 2011 - 09:39 AM
#78
_Quagmire_
Posted 03 January 2011 - 09:56 AM
your worse than me josh
might have to holiday over there soon and bring my wing tips with me
#79
Posted 03 January 2011 - 10:39 AM
#80
_Squarepants_
Posted 04 January 2011 - 09:59 PM
Welding is 33% knowledge, 45% understanding the machine you're using and 80% practice. Only then can you weld at 158%.
Otherwise, try and get onto Dirtbag, I think he's in your area. He's a guru at this stuff and he may be able to give you some pointers. Whether or not he's willing to is a different story, but it's worth a try.
Best of luck with the project, it's good to see that you're committed to it... Sentimental value goes a long way.
#81
_Woodsy_
Posted 05 January 2011 - 03:48 PM
I have a stuffed door from the kingswood i want to use as a test piece before i go anywhere near the car itself, i'm not to keen on working at the base of the A Pillars simply because they are structural.
I've already told the girlfriend that if we ever have to evacuate from here her car will be towing the Kingswood up the road lol
Edited by Woodsy, 05 January 2011 - 03:49 PM.
#82
_Quagmire_
Posted 05 January 2011 - 06:52 PM
i got a set of rusted doors i am just going to gut of the windows and dump
would have been perfect for you to practice on
maybe you should tell wot179 to turn around and pick em up
#83
Posted 05 January 2011 - 07:00 PM
#84
_Woodsy_
Posted 05 January 2011 - 07:44 PM
#85
_Woodsy_
Posted 19 June 2011 - 12:00 PM
Ok so no progress for a while now on the old girl, engine is still wrapped up in its blanky covered in oil waiting for everything else. The original crank is quite rusty now so it will have to go to the machine shop to see if its savable. The original pistons need to come off the rods and the new ones put on then it can pretty much go together bar the head.
Now my question is, How long can the re assembled engine sit together on the stand? Is there anything i should do to make sure the internals dont rust up etc or should i wait till the body is done and do the engine last?
The Original cam shaft went to a good home, Its in 2 pieces now as front legs for the bench top on the Home Bar, and the Piston tops will be cut off and used as coasters.
#86
Posted 19 June 2011 - 12:21 PM
#87
_nicko61_
Posted 18 August 2011 - 08:01 AM
#88
_Woodsy_
Posted 23 September 2011 - 10:18 PM
#89
_rob350hatch_
Posted 24 September 2011 - 07:49 AM
just out of boredom in the semi i find myself playing spotto for good old aussie cars.and i cover some ground a typical day might see me go to blackheath then gosford and thats a lot of suburbs in between!!! in 6 months i have not seen one jxz of any description but plenty of q's (i saw one yesterday at wilton a white and black coupe)and strangely quite a few wb tonners.
so pull your finger out boy and give me something to look at next time im up the coast lol
#90
_Woodsy_
Posted 24 September 2011 - 10:04 AM
#91
Posted 24 September 2011 - 12:18 PM
surely someone can lend you one .its allways good to see a j car.
That's true up here as well. There are 2 or 3 q's I see fairly regularly but not often I see the other models.
And woodsy, I don't have a welder but if you need anything and I've got it, give us a yell mate. I'm not too far from ya.
Edited by slr_v8, 24 September 2011 - 12:19 PM.
#92
Posted 24 September 2011 - 12:40 PM
#93
Posted 24 September 2011 - 01:00 PM
#94
_Woodsy_
Posted 24 September 2011 - 08:53 PM
Edited by Woodsy, 24 September 2011 - 09:00 PM.
#95
Posted 24 September 2011 - 09:19 PM
#96
_Woodsy_
Posted 24 September 2011 - 10:09 PM
#97
Posted 26 September 2011 - 06:53 PM
#98
Posted 27 September 2011 - 09:32 PM
nothing lately, its covered in dust still waiting to save up for a welder, once i get that its full steam ahead.
what type and size you want, I will send one tomorrow, we can work out the funds later ....
#99
Posted 27 September 2011 - 11:02 PM
He wants one of those ones that when you pull the trigger, it squirts a new plenum chamber onto the car.
#100
Posted 28 September 2011 - 09:28 AM
