what toyota clutch should i use?
13 replies to this topic
#1 Evan
Evan
  • 1,287 posts
Posted 03 June 2006 - 11:27 AM
heya guys , just putting in the supra 5 speed into my 308. and was wondering what clutch plate i should use??
i would like a heavy duty one, and dont know much about all this.
whats the deal with ceramic, button and puc clutches?, can these all fit? ., how do they range on price and relyability and drivability.
Thanks guys
Evan...
#2 _@milco@_
_@milco@_
Posted 04 June 2006 - 09:59 PM
i got a celica/supra boxing my lj (6cyl) and i used a dyna truck clutch..... dunno about v8's tho
#3 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 05 June 2006 - 12:22 AM
Evan, you want to use a cushioned ceramic, that will be the best combo for what you are doing. Find out the diametre pressure plate you want to use and how many splines are on the input shaft and it's diametre, and go to coventries in morley and ask for a guy called colin i think, he is one of the few knowledgeable guys at the place, and was very helpful to me in the past in regards to clutches.
Dave
Edited by 355LX, 05 June 2006 - 12:23 AM.
#4 Evan
Evan
  • 1,287 posts
Posted 05 June 2006 - 01:28 AM
Heya dave
thanks for that, ill have to go and see colin at coventries.
i have got 3 pressure plates at my house, how do i tell what ones are heavy duty and what ones are standard??
i can take photo's.
Regards
evan...
#5 _Oldn64_
_Oldn64_
Posted 05 June 2006 - 12:44 PM
Heya dave
i can take photo's.
Regards
evan...
Usually the number of fingers and how thick they are. I would suggest that you look at taking a few photos and posting them up...
#6 dattoman
  • 16,487 posts
Posted 05 June 2006 - 08:01 PM
If you have used pressure plates don't use them
Take them to the clutch factory in DOwd St Welshpool and get Graham to test them to pick the best
Then get him to rebuild it to the specs you think you want
#7 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 05 June 2006 - 08:38 PM
If your going to the trouble of fitting a new friction plate, spend the extra $$$'s and get a pressure plate to suite as well.....worth it in the long run.
Dave
#8 Evan
Evan
  • 1,287 posts
Posted 07 June 2006 - 06:51 PM
heya gius
when i put the aussie 4 speed in a few monts back i put brand new clutch kit, althoe it was just a stand one, not heavy duty, and i found that it would not chirp when i changed gears hard. If i tried to smoke it up with my 235's on, the clutch would just slip. found i had to have it fully enguaged and rolling and then swing it into a nut.
so i was thinking that it was not heavy enough.
ill poste some pics of the 3 i have,
the bloke i got the 4 speed off told me it was new heavy duty one. it looks in alwrite nick.
was having a look at the new clutch and pressure plate that i got for the aussie box when i put it in , and its conciderably larger than the so called heavy duty one i have here that came with the aussie.
they all have 18 prongs.
ill get some pics for ya.
#9 Evan
Evan
  • 1,287 posts
Posted 08 June 2006 - 08:24 PM
heya guys, got some pics here.
there are all the 3 setups i have.
why do 2 of them havve springs and round tube things in the centre, and the other has just springs.
what do you guys think??
Evan...
#10 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 09 June 2006 - 05:44 PM
If you really want to try and use what you've already got, take it to the clutch specialist Neil mentioned, or one you already know of. That way there is no second guessing, which is something you do not want to do with a clutch. Nothing worse than unnecessarily pulling gearboxes in and out!!
Dave
#11 _[BOTTLEDUP]_
_[BOTTLEDUP]_
Posted 09 June 2006 - 08:59 PM
You'll most likely find that the kist has been made up out of a Supra friction plate, and a Holden pressure plate. But as Dave and Neil have said it would be best to check in with an expert, ie the Clutch Factory. :)
#12 Evan
Evan
  • 1,287 posts
Posted 09 June 2006 - 09:03 PM
thanks dave, yer i know , i hate doing it too cos ya have to take the whole car apart ,just to get the fkn thing out..
ill take ti to that baloke that datto said, n get it all checked out , just atm , i cant really spare heaps of extra cash atm as this conversion is costing me heaps, and many headaches.
ill go hard on it tomorows, ( sat ) n let ya know how it goes.
Evan ...
#13 _Oldn64_
_Oldn64_
Posted 10 June 2006 - 02:55 AM
Ok you have answered your own question here. have a look at your pics. see the difference in teh spline in teh centre. notice the fine spline clutch plate this is the supra one. the aussie one will not fit the supra box. firstly check the clutch on the input shaft, then make sure there seems to be a good amount of meat on teh clutch then take the matching pressure plate and clutch to teh specialist. from here they will be able to build you a clutch that will suit your application.
I have needed to do teh same with teh Galant as the clutch slips like crazy at present above 3800, just lets go. I ran a Heavy duty chevy 1 ton truck clutch in my old black VC SLE. This used to hang on like nothign on this earth. the biggest issue was the requirement to mod the bellhousing to fit it all. But I never had that one slip. Infact it was hell heavy that may whom drove my car asked whether they where pressing the brake... Just the way I liked it.. :D
#14 _QIKSLR_
_QIKSLR_
Posted 12 June 2006 - 11:47 AM
My mate also used a toyota Dyna clutch behind his celica 5pd/253. Very heavy! Very tuff. Made mince meat of banjos (as in snap the baring caps in half).
