roller vs flat tappet
Posted 01 April 2012 - 07:52 AM
Posted 01 April 2012 - 03:46 PM
Posted 01 April 2012 - 04:39 PM
Posted 01 April 2012 - 07:35 PM
Edited by TerrA LX, 01 April 2012 - 07:36 PM.
_2wild4u_
Posted 01 April 2012 - 09:58 PM
Posted 02 April 2012 - 07:43 AM
_Liam_
Posted 03 April 2012 - 06:42 PM
Posted 03 April 2012 - 09:23 PM
_oldjohnno_
Posted 04 April 2012 - 06:22 AM
...but you get quite a bit more horsepower with a roller with the same lift and duration...
You hear this all the time but it only really applies to bigger profiles. A flat tappet can have higher initial acceleration rates than a roller, and for anything under about 0.4" lobe lift (and this would include any cam marketed as a "Street Hydraulic") it's actually possible to get as much or more area with an appropriate flat tappet profile.
But as you said, rollers have other advantages, even with small profiles.
Posted 04 April 2012 - 09:18 AM
Posted 17 April 2012 - 08:42 PM
In some applications it might be true, but its going to be the exception, rather than the rule
_TorYoda_
Posted 17 April 2012 - 11:31 PM
_oldjohnno_
Posted 18 April 2012 - 07:24 AM
in a very hot 202 you will make 45hp more witha roller compared to a flat tappet...
As others have mentioned, what roller profile are we comparing to what flat tappet profile?
Given that the little Holdens lobe size is ultimately limited by the small size of the cam journals and the need to maintain a reasonable base circle diameter, I'd be extremely surprised if it wasn't possible to get at least as much area under the curve with a state-of-the-art flat tappet profile as a roller. And with a 903 lifter I'm sure the flat tappet would be well in front.
I've mentioned this before but many of the traditional Holden six flat tappet profiles are very "agricultural" - any roller cam will look good if the cam you're comparing it to is bad enough...
Posted 18 April 2012 - 05:49 PM
_Liam_
Posted 18 April 2012 - 06:44 PM
Posted 16 May 2012 - 05:27 PM
http://users.telenet...ers_search.html
Posted 17 May 2012 - 09:02 PM
The factory stuff has now done an uneventful 40,000k on the crane stick.
The combo of hyd roller with aluminium VN style heads is a much nicer and torquier combo than the old steel VN heads and big solid were.
Posted 18 May 2012 - 12:30 PM
offers less friction .2. you can get a decent lift where it is needed at around 70 deg atdc
of induction stroke.
Add those 2 together and it has to be better.
Me mate builds engines and wont use anything but roller,and as above regarding lifters
Me mate found that out too with the releif on lifter comming out of lifter bore but
just as well he spotted it before the thing was screwed together and got the correct lifters.
Just out of interist,has anyone ever compared how much difference in torque it takes to
turn over a v8 with roller cam compared to flat tappet?
_oldjohnno_
Posted 26 May 2012 - 10:06 PM
