homemade under dash clutch master cylinder
8 replies to this topic
#1 ACJ
ACJ
  • 197 posts
  • Name:adam
  • Car:LH
Posted 02 April 2012 - 11:19 AM
This is my homemade under dash clutch master cylinder. As I was to cheap to pay Mal Wood $790 for his setup ( but his looks good ).
It’s a eBay / Toyota master cylinder for about $60 new and a day stuffing around. The reservoir bottle will be on the fire wall. The outlet will go straight into the tunnel and back to the clutch. Should give me more room for the extractors and very little problem with heat.
I have also relocated my hand brake to the centre of the car.
#2 _The Baron_
_The Baron_
Posted 02 April 2012 - 01:23 PM
Will you have problems fitting the steering column in?
#3 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 02 April 2012 - 02:14 PM
I've got one similar for my LC that a mate made up for me.
#4 ACJ
ACJ
  • 197 posts
  • Name:adam
  • Car:LH
Posted 02 April 2012 - 04:44 PM
No, column is about 10mm away.
#5 ozyozyozy
ozyozyozy
  • 950 posts
Posted 17 April 2012 - 08:56 PM
i`ve done something, almost the same, dosent look as good as other setups, but fuctionality, fantastic.
i used a tilton m/c which uses a standard universal mounting flange, so if the m/c size needs changing its a direct swap.
i have a remote reservoir under the bonnet.
and biggest plus, less than a quarter of the price of other setups.
i made a stop to limit the travel, if not careful can cause over extension at the clutch.
i have half to 2/3rds the travel of the original setup, great for what i want, and its just as light as most road cars.
#6 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 17 April 2012 - 09:32 PM
Whats a tilton master cyl?
Photos please.
Edited by fuzzypumper, 17 April 2012 - 09:34 PM.
#7 ozyozyozy
ozyozyozy
  • 950 posts
Posted 17 April 2012 - 09:40 PM
sorry been having issues trying to put photos up.
tilton 76 series m/c, google or check them out on summit racing, good quality reasonably priced, wilwood does the same job, same size mounting flange,
#8 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 17 April 2012 - 10:22 PM
WHat size bore M/C did you use?
What about the slave cylinder? which one?
Edited by fuzzypumper, 17 April 2012 - 10:24 PM.
#9 ACJ
ACJ
  • 197 posts
  • Name:adam
  • Car:LH
Posted 18 April 2012 - 03:17 AM
I have a McLeod slave cylinder so I emailed them about the M/C size (The bore is 3/4" and the stroke is 1.2")
I have also put the reservoir under the bonnet and also a floor stop on the pedal.
For $60 and a day stuffing around.
