Seam sealer
Posted 10 April 2012 - 07:16 PM
I've noticed in the rear corners of the bay there appears to be evidence of old dry seal sealer that is flaking off.
What is best to use to replace this. Also rust converters, I guess POR15 is the stuff to use?
Ive got some SLS 2k primer that I used on my donk and was planning to use in the bay, but what should I put on the bare panels whilst I'm working on them???? As this job might stretch out over a week or two... I'm really dreadin it!!!!
This is what awaits me.... Shudder....
#2 _Bomber Watson_
Posted 10 April 2012 - 07:26 PM
Remove all the 1k primer before using a 2k primer.
Any rust converter will do.
Prime before you seam seal the corners.
Seam sealers theres a million out there. Use a polyurethane of some description.
Posted 10 April 2012 - 07:31 PM
#4 _L32M20_
Posted 10 April 2012 - 08:28 PM
Posted 10 April 2012 - 09:19 PM
Geeeeeeez..... Can't someone else do it.... :-(
Posted 10 April 2012 - 09:52 PM
Posted 10 April 2012 - 10:03 PM
Posted 11 April 2012 - 07:36 AM
dont expect anything else from you hanra.Ok well crappy dirty paint job is not what I want. Do it once. Do it right.
Posted 11 April 2012 - 10:14 AM
It might look like a shit of job but but once you start and finish one bit
you will see its worth it.
Posted 11 April 2012 - 12:22 PM
Primer and then seam sealer and then paint is the way to go.
I used the brush on type called U-Pol 'Grey Stripe' bought through a local smash repairer.
It is a permanent flexible product and can be overpainted after an hour, plus it is made to look like the OEM stuff (brush on).
Laid down masking tape each side of the joins where we could, brushed it on and removed the tape for a clean edge - about 2.0cm wide.
I bought a 1 litre tin (still have some left over) but forget how much it cost sorry.
Referencing your photos, here are the pics of how it turned out on mine - just ignore the light grey bits - still need to clean the engine bay entirely after washing out all the sludge from rubbing down the primer;
Cheers, TB
Posted 11 April 2012 - 12:47 PM
Mine has an extra two holes in the mid section... behind them is captive nuts???
Posted 11 April 2012 - 02:06 PM
Gun kit:
http://www.superchea...489#Description
Media:
http://www.superchea...800#Description
Edited by ryano1911, 11 April 2012 - 02:13 PM.
Posted 11 April 2012 - 03:08 PM
Posted 11 April 2012 - 04:15 PM
I've got the one with the hopper on top, less trouble with trying to suck up sand I figured. Only given it a test run on some surface rust around a windscreen edge on a hatch, far better than trying to sand or lightly grind, the finish looked very clean with a frosty look which I imagine is a good surface for paint to stick.You know whats really weird.... Is I just jumped on the SCA website before to look at air powered sanders and stumbled upon those air blast kits! I think Ill give it a try!!!!!
Only thing is on the short run I did the sand goes everywhere including bouncing back at your face, you really need some sort of full face protection
Wondering if those two holes are for a master cylinder, did LH's ever come without a booster?
Edited by tuxedoss, 11 April 2012 - 04:16 PM.
Posted 11 April 2012 - 04:24 PM
Not sure how that Norton stuff goes I usually use red Garnet like most sand blasting shops. but that stuff should be fine for the amount of blasting your doing.
Oh and make sure you use at least a paper face mask
Edited by ryano1911, 11 April 2012 - 04:26 PM.
#16 _Bomber Watson_
Posted 11 April 2012 - 07:02 PM
I offered.
Re the sand blasting, i've tried using those little jiggers and they shit me to tears. But perhaps im just used to using the big industiral setup i do everything with, with a 250kg hopper and a 200cfm compressor lol.
The little ones will do the trick, but i highly reccomend you strip as much of the crud off as you can. They seem to take rust off really nicely, but anything bounchy/flexible like paint, body deadner etc they will tuck there tail between there legs and run away.
Posted 11 April 2012 - 08:06 PM
Wire wheel on a drill or grinder or if your feeling rich black or purple clean and strip wheel is the easiest for removing paint witout diging holes with a grinder
Posted 11 April 2012 - 09:41 PM
Any suggestions on brands or types of Sean sealers?? Or are they all basically the same?
#19 _Bomber Watson_
Posted 11 April 2012 - 09:57 PM
Posted 12 April 2012 - 09:48 PM
#21 _double ss trouble_
Posted 12 April 2012 - 10:06 PM
#22
Posted 12 April 2012 - 10:18 PM
#23
Posted 12 April 2012 - 11:18 PM
My engine bay looks exactly like yours Hanra, I chipped a bit of that white sealer out of the passenger side corner yesterday and the metal has a light surface rust on it. The supercheap blaster will be perfect to clean that corner up, just need to cover stuff up to keep the sand out
#24
Posted 12 April 2012 - 11:24 PM
#25
Posted 12 April 2012 - 11:34 PM
