Seam sealer
#26
Posted 12 April 2012 - 11:36 PM
#27
Posted 13 April 2012 - 06:28 AM
Brad where did you get the bucket of sandblasting grit from.
Supercheap Auto mate. $19 a bucket!!
#28
Posted 13 April 2012 - 06:35 AM
#29
Posted 13 April 2012 - 07:40 AM
I've done this a few times over the years and never had a problem.
The Sikaflex can bridge a fair gap and doesn't shrink.
Only LH had the boosterless option (4w Drums !)
Good luck with it !
#30
Posted 13 April 2012 - 08:47 AM
Sikka is what I use as well but I always let it dry before painting
Edited by ryano1911, 13 April 2012 - 08:49 AM.
#31
Posted 14 April 2012 - 09:05 PM
#32 _Bomber Watson_
Posted 14 April 2012 - 09:09 PM
Pronounced "thirty sixty"
I pay about $530 a tonne for it, so a 25kg bag from a proper supplier should be fairly cheap.
Posted 14 April 2012 - 09:24 PM
#34 _Bomber Watson_
Posted 14 April 2012 - 09:29 PM
Posted 14 April 2012 - 10:22 PM
#36
Posted 14 April 2012 - 10:53 PM
Interesting looking at your brake booster mount on the firewall....
Mine has an extra two holes in the mid section... behind them is captive nuts???
You scarred the crap out of me Brad.
I thought; 'Here we go again - another lesson the hard/expensive way', but it turns out my booster only has the fours studs in each corner - hope I have the right booster!
I see you have the ubiquitous rust behind the bonnet hinges - how big a job is it to get that all fixed?
I enjoyed your post about attempting the blasting and I know you pain mate - did you keep it out of the chassis rails?
Tell me, all that rust and old sealant - can you get it out with a wire wheel or will only media blasting get it done?
How did it go anyways - did that fine grit that you have work at all?
Finally, in relation to finding some more coarse grit (garnet or whatever), just look up someone who does the blasting locally and go see them for a bag - likely easier than trying to find a local stockist.
All the best and cheers, TB
#37
Posted 15 April 2012 - 09:30 AM
blasted/bent your tailshaft if you still talk to them.
If you have no joy getting some the local blaster up here
would probably give you enough to do the job or give
McClarty a ring,they got 25kg bags,they might even give you
a name of where to get it in Cairns
#38
Posted 15 April 2012 - 11:37 AM
