Convo Pros on LX
#1 _Liam_
Posted 04 June 2006 - 06:57 PM
Cheers fellas.
Posted 04 June 2006 - 08:07 PM
15x10 rear and 15x8 front should work pretty good though, i know plenty of cars that have this combo and work well.
RIM
#3 _kangur_
Posted 04 June 2006 - 08:24 PM
#4 _kangur_
Posted 04 June 2006 - 08:27 PM
Posted 05 June 2006 - 01:07 AM
Will look Mint Though!~
Posted 05 June 2006 - 09:35 PM
If your not flared and not tubbed run 7's on the front and 9's on the rear.
Tubbed and you can run whatever you please on the rear.
#7 _kangur_
Posted 06 June 2006 - 12:38 AM
#8 _Liam_
Posted 09 June 2006 - 08:22 PM
Cheers for the help.
#9 _user asked to be removed_
Posted 09 June 2006 - 09:25 PM
#10 _Oldn64_
Posted 10 June 2006 - 02:32 AM
Oh not to mention the increased drag and thus increased fuel consumption.. :S
Posted 10 June 2006 - 03:59 PM
(I run 2 different sets of wheels on mine, and have 2 sets of different rear springs). If I have my 8.5" Convo's on, I can run my super low springs and it looks ace and doesn't scrub (because all the offset goes inwards). If I run my 9.25" wide Hotwires though, I have to run taller springs again because these sit out heaps wider and scrub a lot easier.
Let us know what you end up doing and how you go with it.
#12 _timbotorrie_
Posted 11 June 2006 - 07:54 PM
195s on the fron and 295s on the rear
the diff is 1 inch shorter each side and a9x flares on it aswell
the 10s have the big dish
Posted 12 June 2006 - 12:46 AM
#14 _Liam_
Posted 14 June 2006 - 06:34 PM
#15 _timbotorrie_
Posted 14 June 2006 - 07:53 PM
my front tyres cost me nothin and my rears cost me two hundred bucks! both new!
#16 _Liam_
Posted 19 June 2006 - 06:53 PM
Posted 19 June 2006 - 07:04 PM
5" back spacing on standard torana width diff under flares
they sit really nice under the flares with 50mm lowered king springs
the fronts are 15x7 with 3 3/8 back spacing with 225/50 tyres.
if i was doing it again i would have gone for 8 1/2 rims with the same tyre and back spacing
hope this helps
Damo
#18 _[BOTTLEDUP]_
Posted 19 June 2006 - 09:32 PM
These are 15x4's and 15x8.5's, with a 3 3/8" B/S on the rears.
In torrie pattern.
Edited by [BOTTLEDUP], 19 June 2006 - 09:36 PM.
Posted 19 June 2006 - 09:59 PM
Posted 20 June 2006 - 01:32 PM
I would suggest some 215s for the front if there are no clearance issues.
Drive a little bit spirited and the 195s on 7" rims have more likelihood of stripping off.
Grant..
#21 _user asked to be removed_
Posted 20 June 2006 - 04:07 PM
#22 _QIKSLR_
Posted 20 June 2006 - 07:56 PM
Not with flares dude, I ran 245s on the front with ease.Excuse my stupidity, but I thought 215's on the front were huge as?
With drag slicks, if you have say a 10" wide slick, do you want a 10" rim or do u want smaller. I notice that alot of drag ppl seem to run a narrower rim than tyre so it bags out more. Is this disireable?
#23 _timbotorrie_
Posted 21 June 2006 - 07:59 PM
there is a few more pics in my build up under "tims a9x replica"Timbo do u have any side on views?? Oh yep i see, well i got priced on the wheels and the said about 1400 also, and not sure bout rubber, wat brand is yours??
my rears are McCrearys and fronts are just radials, cant remember brand!
#24 _timbotorrie_
Posted 21 June 2006 - 08:02 PM
i did have 225s on it before but have changed the suspension a bit and now has hz brakes aswell which dropped it down a bit more due to the stub axle being different, and they hit the flare, i got the 195s for nothing so on they went!Timbo,
Grant..
with soft suspension and big and little tyres i dont go round corners quick anymore!
it has soft springs and 90/10s in the front!
Edited by timbotorrie, 21 June 2006 - 08:03 PM.
