9" Diff. What is good/not good
_the gts_
Posted 29 April 2012 - 09:02 AM
I am in need of getting a new 9" diff made.
What would be the best to get for a street car as in strongest/lightest?
My plans so far are 60mm shorter either side, bigger bearings and true track.
Does anyone have any thoughts on the Strange Ultra Case or the Strange 12 bolt drop in centre?
Has anyone had any dealings with Pro9?
Posted 29 April 2012 - 09:49 AM
Make the right decision the first time by asking what people use and what they use it for.
Tyre height should be compared in this research as well.
Every combo has been tried a million times,and it wont be that hard to find the right ratio for your intended use.
It is good to see you are at least considering a 12 bolt option.
I think you should take it a step further and stay away from the sheep mentality of 9 inch being the only option,and go with the regular Strange 12 bolt.
They are more than strong enough for nearly any 5 litre application in a small, light car like a Torana.
90% of 9 inch conversions are a result of a sheep mentality where the public assume they are the only option.
Bah humbug.
They might be the best option for a foulcan,My opinion is to keep it GM.
It will cost you the same money if you are going aftermarket everything anyway.
Good luck with your conversion.
_oldjohnno_
Posted 29 April 2012 - 10:02 AM
Unless I absolutely had to run a 9" I'd much prefer a something like a BW or 12 bolt.
Posted 29 April 2012 - 10:48 AM
i have been thinking about this very same thing .like many other car nuts i to was ready for a 9'' but then a mate recondmended a chev 12 bolt here comes the problem from the home work i have done yes you can still buy new parts from the states yes the 12 bolt can handle the power the problem is cutting and rewelding the ears on the cast case and as for price the 12 bolt is slightly more $$$ having said that this is why i am still thinking 9'' more bang for your buck ..... but i am still doing the home work on the 12 bolt to have a all gm car
_moot_
Posted 29 April 2012 - 10:50 AM
aftermarket new housing (need this for 35 spline) due to bigger bearing size
use 35 spline axles.mine are 31's are will be on there limit.
detroit centre.
i wouldnt bother with fancy parts to much,and the weight difference is bugger all compared to a bw diff. (youir car will need a 9")
check wheel backspacing for the brakes you wanna use.i cant use discs now as the caliper would be used as a bump stop.its hard up against the chassis rail.
my diff also has billet top mounts to hold the bush in much nicer than a folded mount.
the bottom mounts are moved in 100+mm and i have bent chromoly lower arms with helm joints to clear the tyre.the mounts are 6mm plate
my diff has the big brace across the back with coilover mounts and panard rod.
a proper drain plug is nice
all things to think about
Posted 29 April 2012 - 11:30 AM
Most Chev 12 bolts have no ears to cut off. Certainly a strange aftermarket housing would be unusual to have them.hi guys
Fabricating and welding on top control arm mounts to a cast steel housing should provide no challenge for a skilled fabricator.
_LS1 Hatch_
Posted 29 April 2012 - 11:31 AM
Depends...if the housing was out of a Chevelle it will, if it was a Camaro one it would not. Just depends on what you got a housing out of? (assuming you are talking about starting out with a second hand one)
Posted 29 April 2012 - 11:37 AM
can you buy a new all steel 12 bolt or do i need to find a second hand chevelle
_LS1 Hatch_
Posted 29 April 2012 - 11:42 AM
(I have a 9" in my car by the way, ha ha...)
Posted 29 April 2012 - 12:06 PM
_LS1 Hatch_
Posted 29 April 2012 - 12:09 PM
http://www.moserengi...nfigurator.html
Shipping it to Melbourne is easy enough, just not sure on costs for the diff or anything since I've never shopped for one. Might be other companies doing them too ? (maybe check with Strange as well for instance ?)
Posted 29 April 2012 - 01:36 PM
_the gts_
Posted 29 April 2012 - 03:36 PM
I already have a 9" with 28 spline (i think) plus I would like one approx 58mm shorter each side. I already have minitubs & coil over shocks so I am hoping 58mm will be ok?
My engine is somewhere between 5-600hp chev and the tyre size is 646mm OD. I was thinking along the lines of 35 spline axles & the 12bolt centre. Apparently the 12 bolt centre is a little bit lighter and also slightly more efficient but will it handle 500+hp?
I would prefer to stay with the 9" as everything else has already been modified and built around it but would just like to know where it can be improved.
Posted 29 April 2012 - 10:39 PM
It would be worth considering using this style of upper control arm mount. Usually you can get some height adjustament and makes it easier to change upper bushes.
The gears will wear quicker in a 9" alloy case than they will in a iron case due to the alloy case flexing.
Edited by ls2lxhatch, 29 April 2012 - 10:42 PM.
_77hatch_
Posted 30 April 2012 - 11:21 PM
Posted 30 April 2012 - 11:53 PM
Choice and availability of parts just nothing compares.
Iv seen them all break 12 bolt, bw and 9 inch, the guy behind the 5th wheel usually the cause.
If your going to add more power later, 9i ch is the way.
Iv had my diff changed so the upper arms have bushes both ends, and have height adjustment on housing, can be good tuning aid.
Edited by ozyozyozy, 30 April 2012 - 11:55 PM.
Posted 01 May 2012 - 11:08 AM
_the gts_
Posted 01 May 2012 - 05:39 PM
Posted 01 May 2012 - 09:35 PM
from factory the setup isent good for racing under power, rear end dosent sqaut, it lifts.
if you move the top arm away from the diff, this gives more weight transfer to front wheels, more mid corner steering.
if you lower the arm gives more rear grip.
it helps as a tunig aid.
those upper arms need to be the length of lowers to make the rear end work propperly, i vote equal length arm 3 link or 4 link, this is what the big boys are doing.
Posted 01 May 2012 - 09:58 PM
#21
Posted 01 May 2012 - 10:50 PM
#22
_the gts_
Posted 02 May 2012 - 02:53 PM
area you suggesting that If i was to keep the standard 4 link and wanted more rear traction I should get adjustable lower trailing arm mounts, similar to the complete housing that LS2hatch posted above?
SS427 do you know the part number of the case that you are using?
#23
Posted 02 May 2012 - 03:51 PM
Edited by ls2lxhatch, 02 May 2012 - 03:51 PM.
#24
Posted 03 May 2012 - 12:46 AM
#25
Posted 03 May 2012 - 12:03 PM
