Stock exhaust to manifold flanges
, May 02 2012 06:23 PM
8 replies to this topic
Posted 02 May 2012 - 06:23 PM
There is a cast flange that joins the stock exhaust pipe up to the stock cast exhaust manifold. Would there be items on the market that would replace this? Or will I need to track down the correct ones to fit my exhaust system up to my manifolds?
Posted 03 May 2012 - 07:41 AM
In case Ive confused some... This is the bit Im talking about.
Posted 03 May 2012 - 08:54 AM
Can't say I've ever seen them new, but wouldn't be hard to track some decent second hand ones down as they don't tend to get damaged and everyone just replaces with extractors
Posted 03 May 2012 - 09:01 AM
Yeah Im just curious is I need to use the exact Holden item or would an exhaust shop have something that would be compatible. We dont have a great deal of choice in exhaust shops up this way and no doubt asking them about this would result in a blank look. Id had to drag the car in there to have an exhaust done only to find it cant be mated to the header correctly..
Posted 04 May 2012 - 10:23 AM
Would the 6 cyl flanges be the same??
Posted 04 May 2012 - 11:22 AM
I think they may be a little smaller in diameter?
You could probably get away with bevelling the inside of a standard flange a bit so it matches the pipe flare, as long as everything sits square the sealing rings can take up quite a bit and should seal fine.
Someone must have some old ones lying around, they're not uncommon and most people don't really want them.
Posted 04 May 2012 - 12:17 PM
Yeah I was hoping some one might have a pair or have some info on them. Im sure plenty get tossed when extractors are fitted.
#8 _deantl2003_
Posted 04 May 2012 - 10:10 PM
Hi hope this photo helps what your looking and here is link http://www.xu-1.com...._bay_parts.htmlYeah I was hoping some one might have a pair or have some info on them. Im sure plenty get tossed when extractors are fitted.
When time comes i will get complete exaust at moment mine is still good and sounds nice...cheers
Posted 04 May 2012 - 10:21 PM
Sorry, once again I havnt made myself clear enough.... Im after the flanges to mate up to the stock cast iron 308 exhaust manifolds.
