lxv8 sedam wiring
32 replies to this topic
#26 Statler
  • 6,317 posts
Posted 25 May 2012 - 12:31 AM
:party: You rock Dave............. recon they could pin that thread in elec ................ :lock:
+1
#27 _Torana Affair_
_Torana Affair_
Posted 25 May 2012 - 10:54 AM
I'll check on the UC tomorrow what colour the temp sender wire is, that square plug looks right but I thought it was a green wire :dontknow:
Appreciate that ............. :bowdown:
#28 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 25 May 2012 - 03:52 PM
And it's...... GREEN! (and greasy)
The plug looks the same though, and the wire goes to one of these plugs, the grey one I think -
#29 _Torana Affair_
_Torana Affair_
Posted 25 May 2012 - 04:21 PM
love ya work
#30 _Torana Affair_
_Torana Affair_
Posted 26 May 2012 - 11:38 AM
Oh UCgazman................
in pics i have ignition module plug and service plug that holden would plug into for problems ( way i was told )
i have 2 x black wires in lug , one goes to ignition module , other to service plug. so assume earth ???
Now this one has me scratching.........
2 individual black wires both with lugs ( assume earth again ? )
traced back - one is joined to a red and other is joined to a brown
Both also go to ignition module...........
Help................
#31 _Torana Affair_
_Torana Affair_
Posted 27 May 2012 - 11:40 AM
ok found the brown and red will go to coil , obviously just extended with black.....
and the the other 2 x blacks lugged together is the earth for ignition module......
I've been wondering if its ok to to mount my ignition module , coil and map sensor in under dash to keep bay clean...
a lot of people say - No good as heat issues , but you would think that there will be more heat in a engine bay then under dash.
any one had any trouble with this?
and because your extending vacuum line to map sensor will this cause problems?
#32 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
Posted 27 May 2012 - 02:30 PM
Sorry Adam, missed your post yesterday....
That first pic with two plugs are ignition module and ALDL diagnostic plug, black wires from these are earth.
You figured out the coil wires, they are often extended to relocate the coil because the factory mounting position below the dizzy is an absolute c#@% to get to. I'm hiding my coil under the wiper panel. Also - use a stock MEC718 coil with the stock ign module, if you change to a high efficiency coil - HECXXX you'll burn out the module prematurely.
As for mounting under the dash, I say go for it, as long as the ign module is not covered by anything so it doesn't get too hot. Also the module needs to be earthed really well.
#33 _Torana Affair_
_Torana Affair_
Posted 27 May 2012 - 05:40 PM
cheers UCgazman it won't be covered ..... also I've taken my manifold off for room and to remove fan cover , I've run all my loom directly behind motor and since I'm not going to use the heater as there a prick when they leak,,,, I've kept the wiring tight underneath and made a hole into dash via air box...all sealed up so no air leaks.. I'm going to run a few spare cables in there too for future use just incase....
