LC S Coupe Rebuild
674 replies to this topic
#326 S pack
  • 15,726 posts
Posted 19 January 2014 - 11:20 AM
Anyway keen to here from dave. Does the master cylinder usually have a male or female parts on the booster side? The booster has a hole there does it?
Jacob
The m/cyl piston has a recess (female) and the booster pushrod (male) engages into the piston.
Have you checked your booster yet to see if there is a reaction disc at the end of the m/cyl pushrod?
If not, unbolt the master cyl and ease it away from the booster. Pull the booster pushrod out about 20mm then sharply push it back in.
If you hear a definite hard clack or clunk type of sound then the reaction disc is missing.
If the rubber reaction disc is in place then it will act as a cushion and the impact should be somewhat softer and fairly quiet.
Otherwise remove the booster from the car, stand it vertically in a vise, carefully remove the m/cyl pushrod and visually inspect for the reaction disc.
#327 _judgelj_
_judgelj_
Posted 19 January 2014 - 02:33 PM
Dave that sounds like a great idea I'll do that. Does the reaction disc sit behind the booster pushrod?
#328 _judgelj_
_judgelj_
Posted 22 January 2014 - 04:24 PM
Well anyway, fixed the temperature gauge issue. Turned out to be the wrong sender and a VDO one did the trick. I explained it in more detail in the separate thread i posted. So it still gets hot (needs a cowel), but at least i can see it climbing. Sometimes i notice coolant just bellow the top tank of the radiator on the side in that little lip. Just cant figure out if its coming from the cap or leaking out of the overflow outlet.
Got the headlining in, pretty happy about that, but he bent the absolute shit out of my rear view mirror which im not happy about. I wonder how i can straighten the base to stop it from rocking back and forth. Apart from that my damper came off my SU and it turns out the thread is broken. So now it pops off and throws my engine out of tune. Not sure if i can glue it, pretty desperate for a replacement so i can drive the car this weekend. Also noticed that my rear screen was put back in sort of the one side, how can i shift it over so it closes all gaps evenly?
Do the aussie 4 speeds usually clunk about in high gear when you let go of the throttle?
i dont know if you can see but the thread had split away from the actual top.
And this is for you dave regarding the warning switch.
had to say goodbye to one of my rescue pups he went to work at port Phillip prison as a rehabilitation dog!!
Edited by judgelj, 22 January 2014 - 04:28 PM.
#329 Potta
Posted 23 January 2014 - 02:18 AM
There should be a little bracket with a switch that gets pushed in when the handbrake is down.
It goes just in front of where the pivot bit with the cogs on is.
#330 S pack
  • 15,726 posts
Posted 23 January 2014 - 12:20 PM
#331 _judgelj_
_judgelj_
Posted 23 January 2014 - 06:58 PM
We'll that certainly clears that up for me. What I don't understand is why the loom had two wires going to the brake warning light on the dash?
Where these things optional?
#332 _Bomber Watson_
Posted 23 January 2014 - 08:08 PM
THe other wire goes to the prop valve under the bonnet.
Either one triggers the warning light.
Its a 72-73 thing TMK, my LC never had the prop valve.
#333 _judgelj_
_judgelj_
Posted 23 January 2014 - 09:17 PM
Yeah ones to the prop valve, the other is to the handbrake switch as per the wiring diagram. Problem is I have two wires bridged together and no handbrake switch. Did lcs really not have prop valves or fail switches?
#334 S pack
  • 15,726 posts
Posted 23 January 2014 - 09:47 PM
 The brake junction block incorporating the brake fail switch was introduced for 1971 LC production.
The handbrake warning switch was a Dealer fitted accessory and could also be purchased as a kit over the dealers spare parts counter.
#335 _Bomber Watson_
Posted 23 January 2014 - 09:49 PM
Ah, my LC was 1970, hence the confusion. Thanks for clearing me up Dave.
#336 _judgelj_
_judgelj_
Posted 23 January 2014 - 10:28 PM
I'll have to trace the extra wire...
#337 _LONA-CK_
_LONA-CK_
Posted 24 January 2014 - 07:27 AM
hope this helps
see brown wire here coming out of dip switch
runs out across the floor here to switch
as dave as posted this is the switch you need
this is where the wire plugs to the switch
a lc one if you need it
cheers gong
#338 _judgelj_
_judgelj_
Posted 24 January 2014 - 09:36 AM
Attached File  GTRWiringHarness.jpg   276.47K   6 downloads
Definitely not there in mine. I vaguely remember there being two pink/tan wires going to the back of that warning light. Now i cant remember what did what. Anyway, where is the brake fail wire i cant see it?
Edited by judgelj, 24 January 2014 - 09:42 AM.
#339 TOERUNNER
TOERUNNER
  • 630 posts
  • Name:RODNEY
  • Car:73 lj gtr 73 lj 2 dr S
Posted 24 January 2014 - 09:49 AM
the tan wire should be taped up in the harness near the dip switch,
that's where mine was ,it had a female bullet connector on it ,but mine is in a lj,
I used a door light switch  from an old corolla to activate the light
cheers rodney
#340 S pack
  • 15,726 posts
Posted 24 January 2014 - 09:59 AM
You won't find the brake fail warning circuit on that 1969 workshop manual wiring diagram. LC didn't get the brake fail switch until 1971 and updated LC workshop manuals were never published.
#341 _judgelj_
_judgelj_
Posted 24 January 2014 - 08:31 PM
Makes sense, i didnt even think it was that old...
Dave ill pull the booster off maybe tomorrow. Could the reaction disc have dislodged and fallen inside the booster whilst moving the thing around?
cheers rodney
So you pretty much made your own?
#342 S pack
  • 15,726 posts
Posted 24 January 2014 - 09:52 PM
That is a strong possibility if the m/cyl pushrod had accidentally slipped forward or came completely out of the booster.
There is also the possibility the guy who recoed the booster forgot to put the reaction disc in or had a mishap handling the booster.
FYI, the reaction disc has a flat face and a raised nib in the middle on the opposite face. The flat face contacts the end of the m/cyl pushrod and the raised nib contacts the tip of the rear pushrod.
#343 TOERUNNER
TOERUNNER
  • 630 posts
  • Name:RODNEY
Posted 25 January 2014 - 06:27 AM
it was easy as, could probably use any door light switch and fab a bracket to suit
#344 _judgelj_
_judgelj_
Posted 25 January 2014 - 09:38 AM
Rodney I'll look into it I have as pair hilux switch sitting here to use.
Dave it worked immediately following the reconditioning. The problem started after I stripped the car to bits. It is very possible it may have fallen in as the booster was moved a lot before it was finally put back in. But whatever happened, happened between the time it was rebuilt and refitted, and when the car was stripped for resto.
The other worry was if I had shit in the brake lines I made up from cutting and flaring.
#345 _judgelj_
_judgelj_
Posted 29 January 2014 - 05:26 PM
Ok now i seem to see this a lot lately, after i have driven the car and it has cooled down (typically the next day, never on the day). I cant figure out where its coming from. Doesnt look like its leaking from the overflow hose, so it must be coming from the radiator cap. But its brand new, as is the radiator?
#346 _LONA-CK_
_LONA-CK_
Posted 29 January 2014 - 05:34 PM
back presser from the overflow line or is it dripping from your automatic line you have blocked off there.
cheers gong
#347 _Agent 34_
_Agent 34_
Posted 29 January 2014 - 07:16 PM
there are two types of radiator cap ;
recoverable and
non recoverable
recoverable = bottle
work the other out
It may have something to do with the cap as above.
G
#348 S pack
  • 15,726 posts
Posted 29 January 2014 - 07:30 PM
Could be the radiator cap or upper hose or a fault in the solder joining the top tank to the core or one of the fittings into the top tank.
#349 _judgelj_
_judgelj_
Posted 29 January 2014 - 09:52 PM
cheers gong
It's not the auto line it must be a bit of an illusion but the coolant is in the lip of the top tank. I too was thinking overflow line but there is no evidence of it dripping coolant.
recoverable and
non recoverable
work the other out
G
I'll have a look but it's strange as it does it only when cooling
I think you're on the money with the top hose I didn't even think of it. Perhaps it has something to do with the thermostat coil being fed through.
#350 Rockoz
Rockoz
  • 4,033 posts
  • Name:Rob
Posted 29 January 2014 - 10:00 PM
Did you put the little rubber spacer in with the thermostat tube inside the top hose?
