Thought id take a few pics of the rotor button, does this look rooted?
Edited by judgelj, 21 February 2014 - 09:21 PM.
Posted 21 February 2014 - 09:20 PM
Posted 21 February 2014 - 10:14 PM
Jacob, I know a few other guys have already suggested this, but if you haven't already taken the rocker cover off and checked you rockers, then you should do so. You mentioned that you heard a bang as you changed down and then the problem started. It is very easy to over-rev on change down and old Holden rockers do not like to rev too high too often. I did exactly the same thing on my old XU1 at Winton with the same result. On the other hand, if you really can turn the rotor button 90 deg without any resistance, then there is clearly a problem in the distributor drive system.
Posted 22 February 2014 - 12:29 AM
Need to look at the other end of the rotor button.
Ummm. Have you followed the guide I posted?
If you do it, and give answers someone here will give you the diagnosis.
Still reckon its internal.
Posted 22 February 2014 - 08:19 AM
I haven't actually had the chance to get down and follow the advice given. Hopefully ill be doing this today, just thought id post up some pics in the meantime. Does it actually look ok in general, or does it need to be replaced?
Posted 22 February 2014 - 08:30 AM
Posted 22 February 2014 - 10:10 AM
Looks ok from those angles. But its the underside where it fits on the shaft is where the damage will be that may be causing your problem.
Posted 22 February 2014 - 12:41 PM
Posted 22 February 2014 - 12:55 PM
Posted 22 February 2014 - 01:17 PM
Posted 22 February 2014 - 01:40 PM
Yay i was right.
Knock the roll pin out with a small pin punch, keep it to one side.
If you have viceys you should be able to get the stud out.
I wouldnt be to keen on drilling and tapping to close to the exposed engine, swarf and all, if you grease the shit out of everything you might be ok.
Possibly a better idea to weld something to it if possible.
Dunno, never treid doing it on the car.
Posted 22 February 2014 - 03:25 PM
I got my hands on a stud puller so i will be drilling and tapping it, but ill make sure i dont make a mess. How am i going to get the roll pin out with a punch? Its in the side of the boss. Looks like it needs to be pulled out...
Do i need to seal the new stud? Im going to do an all nighter try and get it ready for tommorows show.
Posted 22 February 2014 - 04:01 PM
Ah i get the problem now. Again never removed pins without pulling the valve/spring out,
Yeah, have fun with that.
Might be able to tap it all the way through if your lucky then fish it out of the spring assembly.....
If you have earplugs laying around shove them in the oil return holes.
Coat your drill and tap with grease, clean and recoat them frequently. This will catch most the swarf.
I would use red loctite, the stud locker type, upon reassembly.
Posted 22 February 2014 - 04:09 PM
Personally, I'd think it would be quicker/easier/less frustrating to pull the head.
Unbolt the manifold leaving the exhaust and carbs in place, unbolt the rockers, pull the head. (an hours work to pull it I reckon).
Get it on a bench, pop the valve & spring out...rip into it.
If you hit a major snag late in the evening, source another head just so it's mobile for tomorrow.
Someone on here will have one sitting about...
Good luck!
Posted 22 February 2014 - 04:13 PM
Posted 22 February 2014 - 04:17 PM
If there adjustables then yeah that would be a good starting point.
Run it, loosen each one off till it chatts then tighten it up till it just stops, do all of them, then go back and do them all up 1/8th of a turn at a time.
Posted 22 February 2014 - 04:19 PM
Fair enough - your call.
My thought is that if you don't have success you'll be pulling the head anyway and on holden 6 it is an easy job. At least you'll be half way done if/when you decide you need to pull the head...
Good luck
Posted 22 February 2014 - 04:41 PM
Posted 22 February 2014 - 05:05 PM
1/8th a turn at a time, do them all, wait for it to settle, do them all again untill you get to 1/2 a turn.
They dont like it when you just crank down on it in one go, will drop cylinders and stuff most likely.
Posted 22 February 2014 - 05:26 PM
Posted 22 February 2014 - 05:29 PM
Yeah mate. PRetty sure they dont go into water....You will find out when you get the old one out anyway haha.
Just to help hold it.
Posted 22 February 2014 - 06:01 PM
Posted 22 February 2014 - 07:10 PM
Would be easyest to drill it when its fited you would think?
Posted 22 February 2014 - 07:54 PM
Posted 23 February 2014 - 08:53 AM
Does it really need a roll pin? Will tapping it in with a hammer be ok - just go until the sound changes and its obviously been seated?
Can anyone chime in if they know that it has a water jacket?
Edited by judgelj, 23 February 2014 - 08:53 AM.
Posted 23 February 2014 - 09:04 AM
Rocker stud holes do not go through into the water jackets.
Roll pins through the studs aren't factory but some engine builders recommend & install them when using HEAVY valve springs to prevent the studs pulling out of the bosses.
Edited by S pack, 23 February 2014 - 09:08 AM.
