LC S Coupe Rebuild
674 replies to this topic
#426 _judgelj_
_judgelj_
Posted 23 February 2014 - 09:54 AM
You are a legend Dave thanks I was stressing. I'm gutted I couldn't do it last night. I'm giving it another crack now. Am I right to tap the new stud back in?
#427 _LHSL308_
_LHSL308_
Posted 23 February 2014 - 10:04 AM
Good luck mate I could imagine how much of a tedious job it is.
#428 _judgelj_
_judgelj_
Posted 23 February 2014 - 10:15 AM
Man this is in that tight that my puller is snapping high tensile bolts, I'm making a slide hammer hopefully that will help.
#429 _judgelj_
_judgelj_
Posted 23 February 2014 - 11:01 AM
Ok so slide hammer didn't work. This stud is not coming out. I'm going to attempt to drill it all the way. What am I trying to achiever by drilling it? And I drilling it to make it easer to pull or an I going to drill the material into nothing?
#430 S pack
  • 15,725 posts
Posted 23 February 2014 - 11:23 AM
Maybe time to remove the head and take it to an engine rebuilder to get this repair done.
Drilling the stud out with a hand held drill you risk drilling off centre or through the stud at an angle into the cast iron stud boss and frOcking it completely.
#431 _threeblindmice_
_threeblindmice_
Posted 23 February 2014 - 11:31 AM
Would running it until hot help , expanding the head , any thoughts on that theory ?
#432 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 23 February 2014 - 12:08 PM
Hey Jacob, can you get a good picture of it please.
Might help every one.
Marty
#433 N/A-PWR
  • 9,639 posts
Posted 23 February 2014 - 12:10 PM
Hi All,
Heat in Steel expands equally slowly, unless you give one part a rapid heat, like a Blue Tongue ( OXY ),so you have to work very quickly,
on the other hand is, Freezing, and again you need to act Fast.
Loctite ( from a Bearing Shop ) has Freezing in a can for about $11, so you drill a hole in the Head bolt at the thread, spray in the hole Freezing, put in  the biggest Easy-out, and hope for the best, also a nut welded on the bolt at the thread would have much more Torque. Dave I
#434 _judgelj_
_judgelj_
Posted 23 February 2014 - 12:27 PM
I think it's time to take it off too. Just going to be a prick as I'll have to repainy everything.
I'll get some pics up soon just have barely been home ive been working on this car
#435 _judgelj_
_judgelj_
Posted 23 February 2014 - 03:49 PM
The problem
Removing a spare rocker stud
Removing roll pin
Drilling stud
Tapping stud with 6mm tap
Attempting to remove... 5 snapped high tensile bolts later...
5 snapped high tensile bolts later... After this i tried the LPG but its too risky for my positive valve seals if i haven't burnt one up already.
Resorted to making a slide hammer
So there you have it. A detailed series of pictures showing you why i am so gutted right now. And on top of everything, it actually turned out to be an amazing day today (despite yesterdays rain and clouds). I saw one slr5000 on the road and i shed a tear as i made my way back from bunnings with the supplies for the car.
I seriously do not know what to do. And i know you are going to say remove the head ya wuss, but its honestly the very last resort.
Edited by judgelj, 23 February 2014 - 03:55 PM.
#436 N/A-PWR
  • 9,639 posts
Posted 23 February 2014 - 04:14 PM
Did I miss something, can it be screwed in Jacob, mine are in the 186 head, Dave I
Just pinned for locking
#437 _LS1 Taxi_
_LS1 Taxi_
Posted 23 February 2014 - 04:26 PM
Have you had a go with a stud remover?
Even if it's not threaded, it could go a long way to freeing it.
#438 _Bomber Watson_
Posted 23 February 2014 - 06:08 PM
Get it off, get proper screw in studs fitted, no more issues.
#439 _judgelj_
_judgelj_
Posted 23 February 2014 - 07:46 PM
Dave they are pressed in as far as I know.
Didn't even know stud removers existed? What do they do exactly?
Screw ins are on the cards if it comes off. Oh the mess I will make with the coolant!!
#440 _Bomber Watson_
Posted 23 February 2014 - 07:50 PM
I know the coolant pain.
While my engines out this time im thinking about getting some fittings and running some line from the drain bung in the side of the block down to a ball valve to make life easy.
#441 _LS1 Taxi_
_LS1 Taxi_
Posted 23 February 2014 - 08:12 PM
This is a stud remover.
Any decent tool shop/total tools/autobarn/repco etc will sell them - $25 to $40 usually.
If you can get a bite on the remaining stud with it, you put a rachet on it and it should hopefully twist it free.  The tighter you twist it, the harder it grips the stud.
Attached File  15-1532StudExtctr.jpg   98.38K   4 downloads
#442 _judgelj_
_judgelj_
Posted 23 February 2014 - 08:24 PM
A drain valve would make life SO easy. If i had a dirty motor i wouldnt care, but the amount of water stains ill have to polish out is painful!
Not a bad idea.. So its not pulling it, its twisting?. My only concern would be it crushing the stud as it is drilled. I wonder if it would work.
#443 _judgelj_
_judgelj_
Posted 23 February 2014 - 08:44 PM
My other question is, can they actually be tapped in with a hammer, or are they pressed in with a press? If they cant be tapped in, no point leaving it on the car.
#444 hanra
  • 10,975 posts
Posted 23 February 2014 - 09:22 PM
Maybe try putting it in a bucket of iced water before fitment?
#445 N/A-PWR
  • 9,639 posts
Posted 23 February 2014 - 10:08 PM
Jacob,
If you do get the Stud remover, put a solid pin in the drilled hole and turn the stud remover anti-clockwise just in case. Dave I
Edited by TORYPOWER, 23 February 2014 - 10:09 PM.
#446 _judgelj_
_judgelj_
Posted 23 February 2014 - 10:17 PM
That's a good point Dave I can thread in a bolt or something.
Does the ice water contract the steel?
#447 N/A-PWR
  • 9,639 posts
Posted 23 February 2014 - 10:26 PM
You would need Dry Ice, has to be very very cold.
Rubber snapper Cold, to shrink Steel enough, you are only talking 1 thou shrinkage, also, that Loctite stuff gets a bit of lube in the gap at the same time.
also, if the ICE is on the other part, then there is no gain, as that part is shrinking too. Dave I
Edited by TORYPOWER, 23 February 2014 - 10:32 PM.
#448 _judgelj_
_judgelj_
Posted 23 February 2014 - 10:35 PM
Dave can these press in studs be hammered in?
Would a penetrant spray actually penetrate around the boss?
#449 N/A-PWR
  • 9,639 posts
Posted 23 February 2014 - 10:43 PM
A hammer has a different Force ( too much, and in the wrong direction ), a Press is Controlled, so the right pressure does the job with just the right amount of Force, and in one direction.
A Pressed fit, is too tight to penetrate.
#450 N/A-PWR
  • 9,639 posts
Posted 23 February 2014 - 10:46 PM
But a Hammer can do the Job, I won't watch.
Make sure you use a drilled and/or Tapped Dolly to protect the Stud.
Best bet, is to Tap the Boss, and put in a Screw in Stud, the drill the pin hole and Pin it too
