LC S Coupe Rebuild
674 replies to this topic
#451 _judgelj_
_judgelj_
Posted 24 February 2014 - 10:11 AM
Not a bad idea, wonder if i could tap it. Cast iron?
#452 S pack
  • 15,723 posts
Posted 24 February 2014 - 10:34 AM
Tapping a thread into the cast iron will be easy. You will need to ream the existing 3/8" stud hole out to tap a 7/16" thread for the 7/16" screw in stud as well as you may need to remove the head and have the stud boss machined down to suit.
I understand that with the non adjustable rocker heads the bosses have to be machined down to remove the thickness of the hex nut that is built into the screw in studs or the studs will sit too high. Don't know if it's the same deal when fitting screw in studs to an adjustable rocker head.
You may also need to change the rocker arm to suit with a 7/16" stud. Hopefully someone else will know more about this.
#453 _judgelj_
_judgelj_
Posted 24 February 2014 - 12:56 PM
That's ok, I think I'll leave it until the next rebuild as I managed to get it out this morning. Finally got to the engineering shop as they weren't open on the weekend and bought a couple 12.9 tensile cap heads. Tried them in the puller and bang it let go. Should have heard it, I thought it had snapped. I inspected the stud and it was covered in vertical scratches, where as the spare I pulle out of the old head was perfect, looked like it had been machined.
Only problem now is that the boss has water coming out so it has obviously rusted through. Do I need to apply anything special to the bolt seeing as though it's pressed?
#454 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 24 February 2014 - 01:19 PM
you will need some kind of sealant bud as they go into the water jackets,thats what drag lc has mentioned in an old thread as he changed a stud,id be getting 3/8 screw  in studs put in,take it to a machinists shop and they can do it for you.i got mine done a little while ago at jan n albies,john brookfield put em in for me for i think it was 220 bucks,probably double that now but worth the peace of mind..i put s/t rollers on with pr 726s chromemoly pushys undercut,.i dont think your std tappets will go on 7/16 studs so you will be upgrading .but not sure bud .
Maz
Edited by madtoranajzedded, 24 February 2014 - 01:26 PM.
#455 _judgelj_
_judgelj_
Posted 24 February 2014 - 01:28 PM
Yeah I suppose if I have the head off in the future when I'm not on a budget I'll get it done, with some roller rockers or something if the standard rockers won't suit.
Is there ANYTHING other than gm sealant for sealing studs in water? That stuff is dear as poison 76$ for a tube from holden
#456 S pack
  • 15,723 posts
Posted 24 February 2014 - 01:38 PM
LC Workshop manual says to coat interference fit surfaces of new stud with SL90 gear oil.
There is/was a special tool for installing new studs but I would reckon a piece of 5/8" diameter brass rod (drift) about 6" long and a hammer would probably suffice.
Learn something new every day. Always believed the studs didn't go into the water jackets, boy was I wrong.
Dave.
edit: Be careful not to drive it too far into the head.
Edited by S pack, 24 February 2014 - 01:39 PM.
#457 Bullet
Bullet
  • 217 posts
  • Name:Mark
  • Car:LC 2 Door S
Posted 24 February 2014 - 01:43 PM
You could use a smear of permatex or loctite 515 is good stuff also.
Cheers bullet
#458 _judgelj_
_judgelj_
Posted 24 February 2014 - 02:16 PM
Dave, im not too sure. Engine builder says they go into the jackets, a lot of people say they dont. With what i've seen, they must rust thought. Being 40+ years old they have all probably done so by this stage. The spare i pulled out showed obvious signs of rusting through, but i could be wrong. Mark i purchased some permatiex/loctite no 3. Everyone assures me it will be ok, will it? Everyone swears by GM sealer but the difference is about 70 dollars (permatex bottle 6$). I even called loctite who assured me it would be ok. Dave, should i still use oil with the sealer?
Do i just apply it as i would apply GM sealer to the bottom of a head bolt? Can i fit it straight away, does it have to cure at all before i can start the motor and adjust the tappets?
#459 _LS1 Taxi_
_LS1 Taxi_
Posted 24 February 2014 - 02:31 PM
Put the new stud in freezer for 5 or 6 hours before you install it.
#460 _judgelj_
_judgelj_
Posted 24 February 2014 - 03:17 PM
Oh ok will do, will this shrink it?
If they sit in water? How do I know when it's seated. Do I just keep and eye on how far down it goes? Make it sit level with the others?
#461 S pack
  • 15,723 posts
Posted 24 February 2014 - 03:23 PM
Yes (a poofteenth) & yes.
#462 Bullet
Bullet
  • 217 posts
  • Name:Mark
  • Car:LC 2 Door S
Posted 24 February 2014 - 03:25 PM
With a tolerance fit, if both the stud and bore we're perfect then sealer wouldn't be needed thus why the LC manual says to use oil.
Because you said the old stud was scored, the bore will most likely be the same so a light smear of sealant is good insurance in my book.
Stick a screw driver down the hole to see if it has a bottom, but a steel ruler across the other studs to get the hight would be the go.
Cheers Bullet
#463 Rockoz
Rockoz
  • 4,033 posts
  • Name:Rob
Posted 24 February 2014 - 03:50 PM
If you got a CO2 fire extinguisher you dont need you can use that to cool the stud down before fitting.
Works for putting track pins in dozers so should go well for a little stud like that
#464 _LS2 Hatch_
_LS2 Hatch_
Posted 24 February 2014 - 03:52 PM
What show were you eager to go to? An all nighter means it must have been decent?!
#465 _Bomber Watson_
Posted 24 February 2014 - 04:06 PM
I can just see the look on the oh&s wankers face now.
#466 _judgelj_
_judgelj_
Posted 24 February 2014 - 04:20 PM
Awesome input thanks guys. I'll freeze it, why not. Just so glad I didn't have to spend 80 dollars on a tin I won't use again. Why doesn't everyone use permatex if it does the job?
Mark, so if the bore is perfect, why the oil? Being an interference fit you wouldn't want any lube, would you?
There is coolant in the boss, can I still coat the stud and fit it or do I need to drain it first?
#467 hanra
  • 10,973 posts
Posted 24 February 2014 - 04:35 PM
On occasions when Ive been gettin down to the last stubby and had to fish around the bottom of an esky thats had 2 bags of ice in it, I reckon the iced water feels colder then sticking your hand in a freezer. Ive go no scientific proof behind that though.
#468 _LS1 Taxi_
_LS1 Taxi_
Posted 24 February 2014 - 04:43 PM
Iced water will transfer heat/cold much quicker (obviously) but the -30c of the freezer will beat the iced water hands down for temp every single time.  Case in point....how many times have you frozen a Great Northern solid in your esky?   ;)
#469 kiwi-lilj
kiwi-lilj
  • 1,426 posts
  • Name:Blair
  • Car:LIL J
Posted 24 February 2014 - 04:47 PM
I had a similar problem years ago with rocker studs snapping. After the 5th one I pulled the head off and had it modified for screw in studs. I ended having to take it off again as some coolant was leaking out of the old roll pin holes.
If you are going to give your engine a bit of a flogging you may as well fix it properly the first time.
#470 hanra
  • 10,973 posts
Posted 24 February 2014 - 04:55 PM
Good point!!!!!
#471 Rockoz
Rockoz
  • 4,033 posts
  • Name:Rob
Posted 24 February 2014 - 04:59 PM
Mate of mine always takes 3 or 4 with him to do track pins.
Cost of recharging extinguisher more than made up by time saved.
Has a dry powder mounted to the vehicle for the OHS tools
#472 S pack
  • 15,723 posts
Posted 24 February 2014 - 05:20 PM
Never had to replace a rocker stud but my guess is the stud should be such a tight fit in the hole that without lube it may bind before it is driven in to the correct depth.
Was thinking about whether or not the stud holes in the bosses should or shouldn't penetrate into the water jackets.
If the holes were blanked off from the jackets then driving the stud in would compress the air trapped below it and may prevent the stud seating down to the correct depth. So if this theory is correct then it makes sense that the stud holes open into the water jackets.
Edited by S pack, 24 February 2014 - 05:20 PM.
#473 Bullet
Bullet
  • 217 posts
  • Name:Mark
  • Car:LC 2 Door S
Posted 24 February 2014 - 05:34 PM
Agree with Spac, oil is to stop it binding up, good point too with the air lock!
#474 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 24 February 2014 - 05:44 PM
dave is a thinker  :spoton: .the top of the boss must be burred too for the scratches or just the way it came out,would taking the lip off with a file help when seating or ?
#475 S pack
  • 15,723 posts
Posted 24 February 2014 - 05:53 PM
lip on what exactly???
