Bruce do you know where i can get a replacement mirror like this?
Does anyone else. It's worn out and the wind moves it.
Posted 26 February 2014 - 12:46 PM
Posted 26 February 2014 - 03:01 PM
Posted 26 February 2014 - 03:30 PM
Posted 26 February 2014 - 05:41 PM
Maybe message Matthew (looznugtr) he might have one and he only lives near me. I know he sold one a few weeks ago.
Posted 26 February 2014 - 05:57 PM
wayne is that LJ or aftermarket style?
Bruce is that LJ style mounting, there's one on ebay similar but not sure if it will mount up.
Drop some red loctite into the back of the mirror to stop the wind from moving it on the ball. Works like a treat on Harley's
Didnt think of that, have to get it right before it sets though lol
Ill do that if i dont get one before the all holden day this weekend. cheers
Posted 26 February 2014 - 06:44 PM
Posted 26 February 2014 - 08:01 PM
Well its definitely not LC. But im not sure if the holes are custom or its an LJ door.
Posted 26 February 2014 - 08:43 PM
LJ side mirrors aren't mounted adjacent to the 1/4 window, they are further back near the door glass division channel.
Posted 26 February 2014 - 08:55 PM
Posted 26 February 2014 - 09:08 PM
Quarter glass hits on the mirror.
Posted 26 February 2014 - 09:17 PM
Well its not an LJ door then, i wonder if the holes are LJ dimensions. That would help. I messages the seller but no reply.
Posted 26 February 2014 - 09:22 PM
I am not sure if he's even got one but he may have. Just pm him if your still after one, he's normally on here almost everyday.
Posted 26 February 2014 - 10:03 PM
These look similar to yours?
http://www.ebay.com/...s-/310882700855
or maybe this Mustang mirror?
http://www.ebay.com/...E-/350996797881
Posted 27 February 2014 - 12:01 PM
Like those, Dave.
This was the one i was looking at from AUS
http://www.ebay.com....852b958a&_uhb=1
Unfortunately now im tending to a sheared water pump bolt. someone really doesn't like me.
Posted 27 February 2014 - 12:14 PM
The joys of old cars Jacob.
Always something to be done.
Posted 27 February 2014 - 04:24 PM
Mate i JUST got the bolt out. what a pain in the ass. I replaced it but noticed there is now a crack in the lower alternator mount. And now my fuel pressure gauge is not registering any pressure. So yeah things are great haha
Posted 27 February 2014 - 08:16 PM
So i accidentally moved the dizzy a while back when i was troubleshooting the broken rocker stud. Now i chucked a timing light on and it was showing 0 deg. My dizzy was spun for 12-14deg btdc IIRC, so where should i be adjusting my timing mark? Is it X amount of notches past 8 deg?
Also sort of figured out why my brakes are spongy. Pulled the booster off looking for a missing reaction disc and found this:
Posted 27 February 2014 - 09:33 PM
Posted 28 February 2014 - 08:59 AM
Posted 28 February 2014 - 01:12 PM
We'll I'm hoping that's it and nothing internal. Problem is my MC must be leaking and that's probably what is causing the spongy pedal.
Minor leakage past the rear seal won't necessarily make the pedal spongy. Mine was weeping past the rear seal but the brakes worked perfectly.
Posted 28 February 2014 - 01:45 PM
Posted 01 March 2014 - 12:31 PM
Posted 01 March 2014 - 02:15 PM
Could that not be a sign of air escaping? Well at least that's my theory but I'm likely to be wrong. Hrm. Is that the reaction disc you spoke of, Dave?
That's the front seal on the booster you can see the pushrod poking through. The reaction disc is inside the booster, located in the valve body under the end of the front pushrod.
Posted 01 March 2014 - 03:56 PM
Edited by judgelj, 01 March 2014 - 04:02 PM.
Posted 01 March 2014 - 04:00 PM
When I first pulled the booster out and re fitted it the brakes were fine. It wasn't until I removed it the second time, along withy the master cylinder, brake lines and prop valve that the problem came about. Spent a long time bleeding the system on several occasions in case there is air trapped in the master but still nothing. The most confusing part is that some bleeders cause the pedal to feel really hard when pushing it.Did you bleed the air out when you put the new booster on ? With your mirror , you may be able to fit a new head to the old mount .
Edited by judgelj, 01 March 2014 - 04:03 PM.
