LC S Coupe Rebuild
674 replies to this topic
#551 red6
red6
  • 591 posts
  • Car:1971 Lc Torana S 2 Door
Posted 01 March 2014 - 04:54 PM
[/quote]
Oh so I can't rule it out yet. Can they dislodge on their own. Maybe when the booster is physically handled?
Can I remove that seal without damaging anything to check?
No, Yes, Yes, Yes.
Take the booster an lie it pushrod facing up on a pile of rags. As before, slowly pull the pushrod out of the booster 10mm or so. push it back in with a little force and you should be  able to tell if it has the reaciton disc behind it (if it sounds/feels cushioned) or is it is missing (if it sounds metal on metal) Have a look at the link below if you need some info to make what your trying to determine more clear.
https://www.google.c...iw=1280&bih=681
#552 _judgelj_
_judgelj_
Posted 01 March 2014 - 05:05 PM
Makes plenty of sense, but if it can't easily be dislodged the it must not be my problem. I'll try it anyway.
#553 S pack
  • 15,722 posts
Posted 01 March 2014 - 07:36 PM
Jacob
The m/cyl piston has a recess (female) and the booster pushrod (male) engages into the piston.
Have you checked your booster yet to see if there is a reaction disc at the end of the m/cyl pushrod?
If not, unbolt the master cyl and ease it away from the booster. Pull the booster pushrod out about 20mm then sharply push it back in.
If you hear a definite hard clack or clunk type of sound then the reaction disc is missing.
If the rubber reaction disc is in place then it will act as a cushion and the impact should be somewhat softer and fairly quiet.
Otherwise remove the booster from the car, stand it vertically in a vise, carefully remove the m/cyl pushrod and visually inspect for the reaction disc.
#554 Redzone
Redzone
  • 517 posts
  • Car:Mini torana's - Gemini coupe 10.787@123mph, log booked Group A DOHC Gemini under resto..
Posted 02 March 2014 - 08:48 AM
It is a well known fact that if you depress the brake pedal on a car that has the booster fitted but no master on the front of it, that you run a high chance of the reaction disc falling out.. Could that have happened when you pulled it apart the second time?
#555 S pack
  • 15,722 posts
Posted 02 March 2014 - 09:28 AM
Or if you pull the booster off and don't secure the front pushrod so it can't slip out before you start swinging it around on the way over to your work bench.
#556 Redzone
Redzone
  • 517 posts
Posted 02 March 2014 - 09:40 AM
Yep!
#557 _judgelj_
_judgelj_
Posted 02 March 2014 - 01:12 PM
Either way. The booster did get moved around a bit and spent a while on the floor rolling around. Its plausible. Anyhow i will take on that advice and check. Its always top advice anyway, thanks guys. Dave did you do anything about the weeping seal? It's $200 for a rebuild, and i dont think it is entirely necessary.
Another thing, are all the rockers supposed to have oil feed all the time? When i was doing the adjustments i noticed that some had pools of oil, the others just a light film and no visible oil feed for the duration of the job. I want to go back and pull the pushrods out to check for obstruction, but wanted to ask first.
#558 N/A-PWR
  • 9,637 posts
Posted 02 March 2014 - 01:21 PM
blow out the push rods and see through them Jacob
#559 S pack
  • 15,722 posts
Posted 02 March 2014 - 02:16 PM
Yes I put a kit through the master cyl and had to clean up and repaint the booster.
Oil flow through the pushrods to the rockers should be constant.
When adjusting valves I've seen Holden 6's at idle squirt oil out the oil holes in the rockers and all over the engine bay and other 6's that just seem to seep oil out the holes.
Maybe to do with the oil pressure at idle but I suspect it's more to do with the lifters.
#560 _judgelj_
_judgelj_
Posted 02 March 2014 - 02:39 PM
Yeah i noticed that. Everyone says it makes a mess but i didnt have one drop leave the valve area. So ever rocker should have pooled oil, ill pull them out and blow them with the compressed air. This might explain why my engine clacks when i turn it over. Takes about 10 seconds for it to quieten down.
#561 _judgelj_
_judgelj_
Posted 03 March 2014 - 03:49 PM
If i find that i keep fouling plugs after proper tune, can i try a hotter plug? I use BP5ES and i was thinking to try the BP4. Are there any negatives to this?
#562 N/A-PWR
  • 9,637 posts
Posted 03 March 2014 - 04:00 PM
6 is best - the Carb settings need changing
#563 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 03 March 2014 - 04:23 PM
if you have an old rocker cover laying around jacob you can cut the top off along the two lines on top to stop
oil going everywhere when you adjust the tappets.
Maz
#564 _judgelj_
_judgelj_
Posted 03 March 2014 - 07:55 PM
6 you reckon, dave? The carbs were tuned just right, took about 300 k's of driving to foul.
Maz surprisingly my tappets dont squirt oil, strange i know.
#565 _judgelj_
_judgelj_
Posted 10 March 2014 - 12:11 PM
Some pics from the all Holden day.
#566 hanra
  • 10,969 posts
Posted 10 March 2014 - 12:35 PM
Shit, how many cars were there? All Holdens?
#567 _judgelj_
_judgelj_
Posted 10 March 2014 - 01:39 PM
There were actually 700+ cars there. 7000 plus visitors.
#568 hanra
  • 10,969 posts
Posted 10 March 2014 - 01:56 PM
Thats insane. We had to combine the Holden day with the Ford day just to get enough cars to make a show......
#569 _judgelj_
_judgelj_
Posted 10 March 2014 - 02:14 PM
Was pretty full on. Would have been nice without the VX + models, who unfortunately made up some numbers. Could have also done without the blasting stereos!
#570 _Macca97_
_Macca97_
Posted 10 March 2014 - 02:18 PM
looks like the weather was good to.... a real stereo is an XU-1 muffler :P
#571 _judgelj_
_judgelj_
Posted 10 March 2014 - 04:56 PM
That's my kind of music. I think they need to start kicking out people playing obscenely loud music. Send them to maccasnats i say.
#572 _judgelj_
_judgelj_
Posted 11 March 2014 - 05:04 PM
Can anyone explain what a hotter plug will do for my ignition system? I've fouled yet another set of plugs, and before i can do any other trouble shooting i need to replace the plugs anyway (most likely a temporary set). Im thinking maybe a hotter plug to compensate for my SU needle selection as the mixtures were correctly set, unless of course they have gone out of adjustment?
Could there be any side effects to a hotter plug? Is it worth a shot?
#573 TerrA LX
Posted 11 March 2014 - 06:34 PM
Hotter plugs can induce detonation and run on.
If your plugs are only fouled then simply just clean and dry them.
Hotter plugs are intended for cooler chambers and are a real band aid fix for fouling plugs.
Make sure your ignition system is right upto scratch before you go chasing your tail with mixtures.
A weak ignition will foul plugs and look rich on the plug.
#574 S pack
  • 15,722 posts
Posted 11 March 2014 - 07:11 PM
Here's an interesting vid on understanding spark plug heat ranges.
#575 _judgelj_
_judgelj_
Posted 11 March 2014 - 07:29 PM
Well thats the thing, i dont know what to fault, everything is new no exceptions (ignition wise). I was under the impression they needed to be replaced. How can i clean them? They are charcoal black.
What kind of cars would need a hotter plug, say in a 6 cyl BP4ES?
Ill have a watch now Dave.
The only reason i ask is the plugs have to be replaced anyway, and if it was a mixture problem i thought i would end up needed yet another set by the time i get around to getting to tuned, so though it might be worth a try. Just didnt want to do any harm...
