LC S Coupe Rebuild
674 replies to this topic
#626 _judgelj_
_judgelj_
Posted 20 May 2014 - 10:14 PM
Had to pull the radiator/water pump out for that fix!! Better not snap this 12.9 tensile allen key bolt or i will flip!!
Anyway, not much is going on since the weather change. Alternator was a bit angled so im slotting to lower bracket (which was also cracked in two) to compensate.
Ill ask this again too. Anyone know what this clunking noise is everytime i back off the throttle. Only happens at higher speed/revs.
#627 Rockoz
Rockoz
  • 4,031 posts
  • Name:Rob
Posted 21 May 2014 - 11:31 AM
Can you narrow down the area the noise is coming from?
Could be clutch linkages.
Trailing arm bushes.
Gearbox mount.
Engine mount.
An extra long bolt somewhere it shouldnt be.
Flywheel bolts.
Bit hard to tell from video though.
#628 _judgelj_
_judgelj_
Posted 21 May 2014 - 07:18 PM
Im trying to narrow it down, but from what i can  hear sounds like its close to the trans tunnel so im thinking its gearbox related. Maybe linkages? What would be clunking?
#629 TerrA LX
Posted 22 May 2014 - 07:25 AM
Anything on an old car hehe.
#630 _Macca97_
_Macca97_
Posted 22 May 2014 - 09:24 AM
My shifter hits my tunnel when its idling and when in reverse gets worse.
#631 _judgelj_
_judgelj_
Posted 22 May 2014 - 10:56 AM
Haha that too but i was wondering what part of the shifter linkages can clunk...
I didn't think of the shifter maybe it's hitting when i back off and hit the throttle.
Also i've noticed lately that it clacks on startup like the lifters have to bleed up. Why is it doing this it never used to? It's a bit embarrassing when you give it a bit of a rev to start and it sounds like its going to blow up.
#632 TerrA LX
Posted 22 May 2014 - 03:08 PM
Maybe related to all the smoke coming from the rear tyres once it is warmed up...
#633 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 22 May 2014 - 06:39 PM
Uni joints are a very common cause of clunking on acell/decelleration - if it sounds like it's coming from trans tunnel, I would check the front uni first.
#634 _judgelj_
_judgelj_
Posted 22 May 2014 - 07:57 PM
Nah smokey tyres are normal. Honestly though it was always doing it seemed to have started after i broke the rocker stud.
Uni sounds plausible ill have a look. How would the uni me making noise?
#635 Potta
Posted 22 May 2014 - 09:13 PM
By being fr0cked.
Just replace it.
#636 _LS2 Hatch_
_LS2 Hatch_
Posted 22 May 2014 - 09:34 PM
Mine were making noises once, wasn't really sure where it was coming from. Front one broke getting onto the freeway! SHAT myself big time and caused some big damage. Worth getting a mechanic to check if you are unsure
#637 S pack
  • 15,721 posts
Posted 22 May 2014 - 09:53 PM
What about that 3/4 gear selector lever on the side of the g/box, you were having dramas getting it to clear the tranny tunnel. Could it be hitting when you punch the throttle?
#638 Rockoz
Rockoz
  • 4,031 posts
  • Name:Rob
Posted 22 May 2014 - 11:20 PM
Could be a Uni joint, but usually you will get vibration when they get worn.
And usually found you get a clunk on initial take off when they are worn.
But there are always exceptions.
#639 _judgelj_
_judgelj_
Posted 23 May 2014 - 11:01 AM
I dont think so, i think the first time i fitted them they fouled, since i used the non plastic adjuster (which is very tall) they dont look like they would hit. But ill have a look.
Though only does it at high speeds. Would it be worn needles inside the uni that cause the play which makes noise?
That doesnt sound like fun, did it drop the tailshaft?
#640 _LS2 Hatch_
_LS2 Hatch_
Posted 23 May 2014 - 04:59 PM
Yep it dropped the tail shaft, smashed the housing of the auto and changed the shape of my tunnel. It was far from pretty. Leaked oil everywhere making a huge mess too (including the mess in my pants with the noise it makes!)
#641 _judgelj_
_judgelj_
Posted 23 May 2014 - 08:23 PM
Geeze mate lucky it didnt catapult the car!!
#642 _judgelj_
_judgelj_
Posted 28 May 2014 - 06:35 PM
what about noisy lifters on startup? could i have a bad lifter out of the lot?
#643 _Macca97_
_Macca97_
Posted 28 May 2014 - 06:41 PM
just listened again, clutch fork hitting bellhousing?
#644 _judgelj_
_judgelj_
Posted 28 May 2014 - 09:13 PM
You know what, that makes a lot of sense. Could it have popped off its ball? Ill check it for slop.
#645 _judgelj_
_judgelj_
Posted 03 June 2014 - 12:24 PM
car show on the weekend
finally finished my tray sides too !
#646 N/A-PWR
  • 9,637 posts
Posted 03 June 2014 - 12:34 PM
Very Nice Shine for the Car Show Jacob,
You even managed to Decal the HILUX to the rear side too.
#647 _judgelj_
_judgelj_
Posted 03 June 2014 - 02:06 PM
Haha how factory does it look!!
Not really but it was funny at the time!
#648 _judgelj_
_judgelj_
Posted 08 December 2014 - 10:27 PM
Soo, guess who had to get another road worth because their reg expired and was subsequently cancelled, lol whoops.
But anyway all done now. Locknut came loose on one of the rockers and stuffed me up on a trip this morning. Got a replacement as well as some regular 3/8 unf nuts to go on top. Managed to change the faulty door rubber, re mount the side mirror and syphon 1/2 a litre of oil out of the sump. So all going good-ish except for two things.
Firstly, my M/C is weeping and it looks like it has melted some of the engine bay paint, fantastic!! What can i do about this for now? Quick fix-ish type until i rebuild it. What seal is weaping exactly? Its from the back.
Also noticed this, ideas?
#649 _ljxu1torana_
_ljxu1torana_
Posted 08 December 2014 - 10:32 PM
put posi locks on the rockers.
#650 Ice
  • 15,200 posts
Posted 08 December 2014 - 10:35 PM
Oooh bit of gunk in that radiator time for an engine flush maybe
