It's a 77 LX sedan, i bought it a few years ago. It was a 253 auto, never drove it as the brakes have no pressure and dodgy electrics, the rust was in both rear quarters and passenger sill. Unfortunately i had to park it outside because there was too much shit in the shed, anyway since they started work on the Peninsula Link (the amount of dust that blows over is incredible!) she started to show rust bubbles, so the other week i got off my arse and made room in the old shed.
THE PLAN:
Build a neat weekend cruiser with a bit of GO.
DRIVE LINE:
MOTOR:
Not long after i bought a vs hsv 5l with 72 on the clock.
I was just going to leave it stock, but remembered how disappointed i was when i drove my brothers vs hsv commonwhore ute. So i thought i would give it a bit of a tickle, then thought stroker, finally realised best bang for buck = forced induction. So i bought a supercharger off a v6.
Also going to fit roller rockers, heaver springs (i here LS1 springs work ok?) clean up the heads and match port it.
Roaring through a twin 2 1/2" exhaust.
GEARBOX:
I was going to go a supra box, but got the shaft when i bought motor because it was supposed to come with manual ecu but slipped me a auto one insted. Wanker probably sold it for $1000. Anyway didn't wont to buy another one so i've got a 460le that i'll get a shift kit and beef it up a bit, with standard stall convertor.
DIFF:
Going for a skyline diff, with 3.45 or 3.7 lsd.
WHEELS:
Not sure yet? just know i want some wide ones to fill the flares. Maybe looking at 16-17" diameter.
BODY:
I bought a set of flares and 2 piece front spoiler, they have never been fitted, don't even have any bolt holes in them yet. Hope they fit up alright. So she'll be kitted up.
Also going to smooth out the engine bay a bit
color, well changed my mind a few times. Was originally going Seabring Orange, then i seen a few cars on here that were too. Now i'm thinking either Atomic Green or another commodore color, can't remember the name but it's a dark blue on the ve. With the blackouts of coarse.
INTERIOR:
It came with a fairly new black velour interior. I'll keep that but add some grey or tan strips.
I might get some hate mail for this but i hate the flat LH/X dash and the location of the heater controls. so i'm going to put a UC dash in there. I like them a lot better.
PROGRESS:
PORTING SUPERCHARGER:
I did a bit of research on porting the supercharger, after sorting the wheat from the chaff, i gave it a go. Pulled out the old dremel and went at it. My main aim here is to increase it's efficiency = more boost less heat. I enlarged the outlet removed the dags and put a radius on it removing the sharp edges. On the inlet i just cleaned it up, was pretty rough in there, looked like th outside of a banana manifold. I'm happy with it so far but the proof will be when it's running on the car.
I bought a throttle body off a ford V10 for the US of A, i'm starting to think it might be to big??? Don't remember the exact size but i think it was 54mm x2.
MANIFOLD:
Now we have to mount the superchager to something, so i bought a spare banana manifold for $10 and started attacking it with the dremel and a grinder.
As you can see still a way to go, but i think it should work. I need to cover the top of the ports, i need to add some material here and there and to #7 port and take it to someone with a mill.
I haven't started on the intercooler yet. I'm going to use some phenolic sheets, just tring to find some for a good price. Going to sandwich a small oil cooler with the phenolic.
Thats about all i've done on the motor side.
BODY:
Like i said earlier only just got it in the shed the other day. I started to strip the rear because i figure it's the worst, so took the tail lights out because there was a few bubbles around them. I did passenger side thought yeah not to bad. drivers not so good, oh well my own fault for leaving it outside.
Then i took off the bumper and said a few choice expletives, then had a small chuckle thinking, this is going to be a fast car with all these speed holes. so i've bought metal to start fixing. But can't start that till i re-tile the shower
Thats it for now.
Edited by FLY_LX, 13 June 2012 - 01:25 AM.
