![](https://secure.gravatar.com/avatar/d41d8cd98f00b204e9800998ecf8427e?s=100&d=https%3A%2F%2Fwww.gmh-torana.com.au%2Fforums%2Fpublic%2Fstyle_images%2Fblackstream%2Fprofile%2Fdefault_large.png)
can anyone help RE: low mount a/c compressor bracket
_richo05_
Posted 16 June 2012 - 09:34 PM
Posted 16 June 2012 - 09:44 PM
_richo05_
Posted 16 June 2012 - 10:21 PM
Posted 17 June 2012 - 03:49 AM
Try this link.
http://www.gmh-toran...41-galaxyhatch/
_richo05_
Posted 17 June 2012 - 10:10 AM
_galaxyhatch_
Posted 23 June 2012 - 06:40 PM
Lucky I have these messages come through my Optus account as I haven't had the chance to have a look at GMH Torana forum for a long time.
I tell you what though............if I had a buck for everyone who asked me about that AC install ......................I would be a rich man
But luckily I love letting everyone know how have done things to my car................no secrets here.
The reason I did it this way was neatness, asymmetry and to hide the compressor............my opinion is that if I open a bonnet I want to see an engine......not every braided hose, compressor, and accessory hanging off it.
I have posted a pic of my wife’s SLR 5000, and my SS for comparison (I would have done this to my missus car also but I was going for original look)
![Posted Image](http://www.gmh-torana.com.au/forums/uploads/monthly_03_2012/post-8341-0-78976600-1332322720.jpg)
![Posted Image](http://www.gmh-torana.com.au/forums/uploads/monthly_10_2009/post-8341-12566389619765.jpg)
You are right one the money with your assumption....It is a reverse mounted, low mount alt bracket. I machined up some round stock into spacers using a lathe and veneers to get them accurate, and then had them chromed.
Worked out that because of the position of the oil pump, I couldn't swing the compressor like the alternator to tighten the belt. So I had make up a solid bracket arm to the base of the compressor and welded a commodore pulley idler with adjuster to it and spent hours smoothing out the welds and the edges then had it chromed also.
I had cut off the un-used lugs on the compressor when I rebuilt it and polished it...............but one of my mistakes was that I cut the wrong ones off and ended up having to mount the compressor upside down which does make it hard to fill with oil and hard for the compressor to retain the oil. (so don't make the same mistake) even though the hoses look better coming from the bottom, it can still look good with 180 deg bends out of the discharge and suction fittings at the top and then back down to the chassis rail.
![Posted Image](http://www.gmh-torana.com.au/forums/uploads/monthly_10_2009/post-8341-12567234999825.jpg)
I made up the custom crank and water pump pulley (but now I think you can buy them with the Gilmer set)
The hoses disappear under the rail and to the receiver dryer at the back of the wheel well (out of sight).
I hope all this helps and I didn't waffle on too much. As always.....if you need any more help....let me know.
Cheers Dave
Posted 23 April 2014 - 06:54 PM
Just looking at doing this now..
_Figjam61_
Posted 14 May 2014 - 06:22 PM
Posted 17 May 2014 - 06:54 PM
Figjam61, I'm looking at the Sanden compressor, model SD5H09 as it's compact enough to low mount it in front of the oil pump & above the oil filter. Should be arriving in a week or two..
_Figjam61_
Posted 26 May 2014 - 10:16 PM
Where did you get the mounting brackets.
Will it clash with the oil sender.
Posted 22 July 2015 - 04:01 PM
To galaxyhatch, you posted a pic in this thread of your wife's car with aircon. Can you tell me if the bracket in that car is original or have you had to manufacture it from something else? - Cheers
Posted 02 June 2019 - 05:48 PM
Posted 03 June 2019 - 06:17 PM
I know of 3, Torana and Holden H series that look similar and I have one some where that,s supposed to mount alternator and air
con compressor
Posted 03 June 2019 - 08:26 PM
Aaron, throw up a pic of the one you are trying to use and I'm sure you will get a response as to right or wrong. Cheers Ron
Posted 06 June 2019 - 05:23 AM
It can be done. Did mine a few years ago.
I went through a lot of trial fitting & different mock ups to make it work for my car.
It's one of those jobs you have to figure out yourself but I got there in the end.
Posted 08 June 2019 - 11:53 PM
Posted 11 June 2019 - 05:39 PM
Both my Toranas have A/C, I found it better to put a Sanden compressor on the right of the Holden V8 and Left on the Chev engine. Both mounted down low so you cant see it without looking a bit harder.
IMG_20140912_163804_386_22752.JPG 289.53K
17 downloads
IMG_20150116_093301_7032753.JPG 316.97K
11 downloads
DSC_0136_22350.JPG 144.99K
11 downloads
DSC_0135_12345.JPG 212.21K
8 downloads
Posted 11 June 2019 - 07:10 PM
is galaxyhatch compressor only monted by one bolt? looks like it in the pictures
Posted 16 June 2019 - 10:39 PM
Posted 17 June 2019 - 08:10 PM
Really like how you did your ac , axistr but how did you mount the alt on the passenger side ? What bracket did you Use?
G'day Aaron, I used the original VR 5lt commodore alternator bracket and modified it slightly so the alternator mounted on the inner bolt and made a spacer for the outer. This allowed me to move the alternator in towards the engine by around two inches to clear the chassis. My alternator is adjustable but is all the way in. I have an adjustable idler pully to adjust the belt, I am running a serpentine belts. One belt drives the alternator, water pump, power steering pump. The second belt drives the A/C compressor only.
#21
Posted 18 June 2019 - 11:07 PM
That's great work. I'm playing around with putting my alt on the passenger side , I used the head hole on the outside sort of like what you did , I rotated the alt housing and I have good clearance and good swing for adjustments . But I'm using v belts .
My dilemma at the moment is the alt doesn't line up with the crank . So it looks like I need to space the water pump and crank pulley . Or I could use a gilmer setup . Unsure which way to go
#22
Posted 19 June 2019 - 07:21 PM
Yeah I had to space my alternator foward to get it to line up with the other pulleys. I also had to bend the bracket slightly to compensate for the foward spacing but was a reasonably simple mod.
#23
Posted 20 June 2019 - 07:03 AM
This is another AC & PS unit I made using 2 plates, long bolts & spacers.
I used 2 x 11A V belts which are individual for the compressor & pump.
The belts run over a Holden 3 row crank pulley. Everything clears.
The only change I made was to put the oil sender on a 90 degree elbow to clear the back of the compressor.
No need to change the Torana alternator location. The idler pulleys are slot adjustable for belt tensioning.
I find this design is a lot better to my first design as there is no belt slip when under load.
IMG_4636.jpg 61.35K
11 downloads
IMG_4637.jpg 60.92K
9 downloads
IMG_4638.jpg 52.38K
8 downloads
IMG_0008.jpg 72.35K
11 downloads
#24
Posted 20 June 2019 - 04:07 PM
that looks awesome , great work , very neat and tidy
#25
Posted 20 June 2019 - 06:07 PM
Nice Ando.
