LH Cotter Pin Instal
Posted 19 June 2012 - 11:19 PM
First question, the rubber coupling has some movement up/down the shaft of the steering rack, I would imagine this is going to shift the position of the steering colum once installed... how will I determine the correct spot for the coupling to go...? Or will I just have to try and slighting collapse or extend the colum to suit?
Second...
How far are the cotter pins expected to go through????
Ive just snapped my little G-clamp trying to get the first pin through. There is what appears to be a groove machined around the end of the pin where I thought perhaps this is where its supposed to push in up to???? Im still a little bit away from that point when my clamp snapped.
You can just make out the groove in this pic
Posted 19 June 2012 - 11:31 PM
Pitty about the G clamp but thems the breaks (pun intended) LOL.
I would suspect your cotter pin is in as far as it's going to go so put on the nylock nut and tighten it up to the torque specs in your shop manual, however you might want to leave it loose ATM (if that is on the steering rack shaft) until you get the intermediate shaft and uni joint in and connected to the steering column.
Don't try to pull or collapse the steering column shaft to obtain adjustment. Work with whatever adjustment has been built into the other parts but don't force the steering column shaft otherwise you could shear the collapsable pins.
Edited by S pack, 19 June 2012 - 11:43 PM.
Posted 19 June 2012 - 11:35 PM
Posted 19 June 2012 - 11:53 PM
AFAIK the LH/LX uses the same cotter pins as the LC/LJ.
Posted 20 June 2012 - 07:12 AM
I just had a look at the uni joint with the shaft in it, this is how far I can get the pin through just with finger pressure.
Posted 20 June 2012 - 08:00 AM
G/day Brad
Didnt see the rest of your reply last night.
The coupling wont move up/down the rack shaft with the cotter pin pressed in like it is, so regardless if the nut is on/off I now have no adjustment there.
Perhaps I should just leave everything finger tight pressed in until the K-frame/motor is in, then fit the colum and use the adjustment I have in these components, then swear my head off trying to press in the cotter pins then????
Posted 20 June 2012 - 08:18 AM
Posted 20 June 2012 - 08:52 AM
Posted 20 June 2012 - 09:26 AM
For some reason they will fit in 1 side further than the other. I then mark the inside of the hole with a white paint pen so i know which side to feed the pin in from.
I know this doesn't make any sence as the hole is supposed to be the same bore on both sides, but it works for me.
Posted 20 June 2012 - 09:39 AM
#11 _walpolla_
Posted 20 June 2012 - 10:11 AM
I do not press them in, just tap them in first , put some tension on the locknuts, then with a heavy hammer against the housing alongside the pin, give the pin a couple of sharp taps with a smaller hammer to finally seat the pin. Tension nut to spec, good to go.
Works for me. No g clamps and all that.
regards,Rod
Edited by walpolla, 20 June 2012 - 10:11 AM.
Posted 20 June 2012 - 10:16 AM
#13 _walpolla_
Posted 20 June 2012 - 10:41 AM
Would be a different matter just hammering on the pin - no way I would do that. And I am not talking about full on bashing, just a couple of sharp taps to finally seat the pins home.
regards,Rod
#14 _torbirdie_
Posted 21 June 2012 - 07:49 AM
#15 _76S.L.R_
Posted 24 June 2012 - 12:49 PM
#16 _benster208_
Posted 28 June 2012 - 08:06 AM
