LJ XU-1 battery
_big jack_
Posted 02 July 2012 - 01:01 PM
What Battery do all you XU-1 owners use and with what CCA. Trying to get as close to original as possible?
Thanks. John
Posted 02 July 2012 - 01:43 PM
After looking around the best I could come up with was an Exide 310D 50RC. It has a 310cca rating which i guess is okay for a small battery.
Whatever brand you choose, it needs to be around 130mm wide and around 230mm long to fit the small battery carrier of the XU-1. The other important detail is that the negative post is to the front of the car and to the inside. I see a lot of cars with the terminals oriented incorrectly.
I hope this helps
Bazza
Posted 02 July 2012 - 05:59 PM
I have Century type 51, Ultra High Performance. Rated at 355 CCA. Fits in the XU-1 tray well, terminal size and polarity are good, Size 238 x 134 x 173
It is bright yellow though... Bazza's black Exide may better suit original look bay.
http://www.centuryba...batteries/ID-83
Cranks my 210 ci motor really well, never have issues starting it.
Regards Simon
Edited by debkar, 02 July 2012 - 06:02 PM.
_big jack_
Posted 02 July 2012 - 07:52 PM
Cheers. John.
_oz772_
Posted 02 July 2012 - 08:10 PM
Hi John
Regards Simon
I've got one of those as well. You just have to ask them for the version with the terminals in the correct sense for the XU1; they make them either way. My car sits for a few weeks some times without being turned over, and I've never had a problem with it.
Posted 02 July 2012 - 08:13 PM
_big jack_
Posted 03 July 2012 - 07:49 PM
Agree, get type 51, type 53 is identical battery, opposite polarity ie negative at opposite end of battery to type 51, they are a good battery
Any idea on the price.
Thanks again.
John.
Posted 03 July 2012 - 07:53 PM
I paid for my last one, about 6 months ago, $149.00 at Autobarn,
Did check Supercheap,but they didn't have that battery in stock and I needed one straight away
Regards Simon
_oz772_
Posted 03 July 2012 - 09:16 PM
Hi John
Regards Simon
I paid pretty much the same at Battery World.
_big jack_
Posted 05 July 2012 - 04:37 PM
_big jack_
Posted 06 July 2012 - 08:57 PM
Thanks again.
John.
Posted 06 July 2012 - 10:00 PM
173mm , should be, but I'll measure tomorrow. I also looked at higher CCA batteries, and found that they hit the bonnet due to the height
Regards Simon
Posted 07 July 2012 - 12:05 PM
Still has the small battery tray fitted .
The height from bottom of battery case to top of battery terminals is - 210 mm .
There are no issues with bonnet to terminal clearance or arcing .
Original XU1 battery retainer , threaded rods and dimpled wing nuts fit too .
THE DOWNSIDE ------- Negative terminal is on passenger side , so a longer lead is required .
Posted 07 July 2012 - 12:21 PM
_big jack_
Posted 07 July 2012 - 07:20 PM
_big jack_
Posted 07 July 2012 - 07:33 PM
Thanks again.
John.
Posted 28 November 2013 - 03:34 PM
Hi
I hope this helps
Bazza
Hi Guys,
This thread is a little old now, I have searched for an Exide 310D 50RC like Bazza has however I don't think that Exide make them anymore.
I am not real keen on a century yellow banana under the bonnet so was wondering if anyone has found a suitable battery for their XU1
recently?
_Bushy_
Posted 26 June 2018 - 12:24 PM
Pretty old thread now... But Whos using what these days?
_Bushy_
Posted 26 June 2018 - 01:37 PM
Think I found what I'll be using... https://www.autobarn...ing-power-smf57
Supercharged batteries SMF 57 (bellow). Or you can get the MF 53 (650cca) but needs to be terminal type D. Both have the Black case.
Length: 237mm
Width: 171mm
Height: 182mm
Total Height: 203mm
Terminal Type: Standard Terminals
Special Features: Central Venting, Fold Down Handles, Hydro Eye, End Ledge, Front Ledge
Warranty: 30 months
Volts: 12
Cold Cranking Amps(CCA) @ -18c: 550
Reserve Capacity(RC) @ 25c: 95
Weight: 14.6kg
Edited by Bushy, 26 June 2018 - 01:38 PM.
Posted 11 July 2018 - 12:05 PM
I'll still ask for a discount
#21
Posted 11 July 2018 - 07:35 PM
#22
Posted 15 July 2018 - 08:16 PM
Hi Greg
57 battery is too wide if you are using an XU-1 size tray. Some makers quote 57 for XU-1 but they are too wide.
51 century will fit and terminals are correct. 53 will also fit the XU-1 tray but as you say terminals are incorrect.
Do autobarn have a type 51 width battery 130mm or thereabouts in the supercharge range?
Simon
Edited by debkar, 15 July 2018 - 08:19 PM.
#23
Posted 21 August 2018 - 04:39 PM
What's the height of these batteries? There's 2 I can choose from, but 1 is approx 215mm overall height & I'm thinking this will be too tall.
#24
Posted 21 August 2018 - 04:50 PM
#25
Posted 21 August 2018 - 04:56 PM
A friend of mine that lives in a frost hollow has a 430 CCA rated battery in his XU1 .
This is the NS60LS battery Kockum described.
Screenshot_20180821-145324.png 899.45K
8 downloads
