Roller Rocker stud size
Posted 18 July 2012 - 08:08 PM
I've had a stumbling block with my new motor, I've done approx 250km so far but yesterday traveling to work I've broken the rocker stud on the no. 1 exhaust valve.
Now the question I have, the rockers in it use the 3/8" stud as apposed to the 7/16" stud. Have I exceeded the limits of the smaller stud or would it simply be that the studs were old and of unknown condition be more likely to have caused the issue.
The specs of the motor are:
Red 202 with black crank and rods
Crane 1.6:1 roller rockers
Solid Camshaft
Lift on exhaust valve : 0.528"
Duration at .050: 244
Total Duration: 282
Compression 10.4:1
Total valve spring pressure over the nose: 285lbs
Installed valve spring pressure: 135lbs
Please let me know if I need to provide more info
Thanks Peter
_Brad1979UC_
Posted 18 July 2012 - 11:44 PM
hey were they arp studs you screwed into it? Where did it snap? Afaik the 7/16 studs are the same at the top as the 3/8 stud, the bottom part that screws into the head is obviously larger. So I would say a break on top would be stud and a break below/stripped thread would be the thread limitation.
I've always used 7/16 studs with the 202 twice (in the torrie and then again on the boat) and the 333 in the torrie without a hassle, mainly because they needed to be milled and tapped anyway. If you want some insurance a set of /16 studs and head re-tap shouldn't cost much for a 202.
Though I am interested in what the limitation of a 3/8 stud actually is.
Posted 19 July 2012 - 08:37 AM
3/8" studs are usually 3/8" on the rocker end & 7/16" on the end that screws into the head.
Posted 19 July 2012 - 06:45 PM
And warren is correct, the stud has a 7/16" UNC into the head and a 3/8" UNF to the rocker.
_Mint_
Posted 19 July 2012 - 07:38 PM
the rocker(not roller rockers) Ford Windsor v8 ones flopped over on the side and aventually broke the stud
so check alinement of the roller action over the tip of the valve
Posted 19 July 2012 - 09:48 PM
Pictures attached
Posted 19 July 2012 - 10:35 PM
_qiksix_
Posted 19 July 2012 - 11:14 PM
Posted 19 July 2012 - 11:26 PM
Edited by Peter UC, 19 July 2012 - 11:28 PM.
_ljxu1torana_
Posted 19 July 2012 - 11:39 PM
my 186 turbo done the same thing broke a arp rocker stud. as the bottom of the rocker was bottoming out.i took of the guide plates and this solved the problem.I have checked the alignment of the rockers when the inner springs went in and they were in the middle of the valve, as expected.
Pictures attached
Posted 20 July 2012 - 07:43 AM
At full lift you need to have clearance of about .060" between the retainer & valve guide.
_qiksix_
Posted 20 July 2012 - 06:32 PM
when checking rocker geometry the roller wont be centre, at zero lift the rocker should start on sparkplug side then cross centre to the in/ex side at full lift, if not you need different lenght pushrods but most 6 bangers are close anyways. check the yella terra site i think diagram's on there.
i just realised you have 1.6 rockers make sure you double check all clearances; retainer to rocker at all lifts, rocker to stud at all lifts, retainer to guide(rotate to full lift and see if you can get anymore by levering the rocker or have a good visual)
one other thing to check i've never come across on a 6 banger is pushrod ball to rocker cup, sbc pushrods have a 120* ball end for high lifts.
Posted 20 July 2012 - 06:38 PM
Edited by greens nice, 20 July 2012 - 06:38 PM.
Posted 20 July 2012 - 06:41 PM
sorry jason but you really need to stop saying this over the net without explaining yourself, some bloke without a clue might go and rip the guideplates off and wala, rocker is now pushing down on the retainer, bang and engine drops a valve.
im assuming this head had the broached pushrod holes?
Posted 20 July 2012 - 07:29 PM
Thanks for your help fellas
_ljxu1torana_
Posted 22 July 2012 - 01:22 AM
well kevin, i am saying is that removing my guide plates worked for me.this is only a suggestion.sorry jason but you really need to stop saying this over the net without explaining yourself, some bloke without a clue might go and rip the guideplates off and wala, rocker is now pushing down on the retainer, bang and engine drops a valve.
_oldjohnno_
Posted 22 July 2012 - 06:56 AM
As Kevin said, a 202 novice could easily trash his engine if he wasn't aware that some head/rocker combinations must have guideplates fitted. What worked for you could be disastrous for someone else.
_ljxu1torana_
Posted 22 July 2012 - 06:01 PM
exactley right.Jason, if you're going to suggest to anyone that they remove their guideplates you must make it very clear that you first have to make sure that the head has the narrow slotted pushrod openings, not the round holes that the later heads have.
Posted 05 September 2012 - 09:35 AM
