Which fuel
Posted 28 July 2012 - 08:58 PM
#2 _Quagmire_
Posted 28 July 2012 - 09:14 PM
and that was cause i cheaped out on the flashlube...
if you want to be flash use the 95 vortex it's nearly the same octane as the old super
#3 _CHOPPER_
Posted 29 July 2012 - 12:25 AM
Posted 29 July 2012 - 01:38 AM
#5 _Quagmire_
Posted 29 July 2012 - 06:16 PM
???? how chop chop?The 253 was designed to run on 98 octane, so it may run better with it. Just get your tank as low as possible and try it.
super/leaded was 96 octane avgas was the next step up at 102
#6 _Bomber Watson_
Posted 29 July 2012 - 06:28 PM
I would never even consider putting ULP into anything Pre 88ish.
That said the ski boat frOcking loves 98 (stock 308)
Posted 29 July 2012 - 06:46 PM
#8 _Bomber Watson_
Posted 29 July 2012 - 06:50 PM
#9 _oldjohnno_
Posted 29 July 2012 - 07:03 PM
Posted 29 July 2012 - 07:53 PM
???? how chop chop?
From memory, back in the late 70's Super used to be 98 octane, then it was reduced to 97 octane, then reduced to 96 octane when Super was replaced with LRP.
Posted 29 July 2012 - 08:04 PM
That pretty much sums it up - if the engine will tolerate it (i.e. no pinging) then it doesn't need higher octane and is unlikely to benefit from it.I don't think plain old unleaded is as bad as it's made out to be and I'll run it in anything that will tolerate it. I'll admit to being a cheap bastard but why put more expensive fuel through engines that don't need it. No additives either, hard seats or not.
Valve seat recession isn't a factor when the engine gets rebuilt often!
Posted 29 July 2012 - 10:05 PM
Posted 29 July 2012 - 11:46 PM
I thought you got better fuel economy with the 98 or is that just a myth
More bounce per ounce so they reckon, so you can go easier on the throttle, but will the fuel savings outweigh the extra cost per litre for the higher octane fuel?
#14 _nicko61_
Posted 30 July 2012 - 07:39 AM
#15 _oldjohnno_
Posted 30 July 2012 - 07:41 AM
I didn't think higher octane fuel had anymore energy than low octane, so unless the engine was on the verge of detonation and the ECU was pulling some timing out I can't imagine the performance would change much at all. I've often wondered whether the gains some people report from using high-octane fuel in ordinary engines are mainly imaginary...
Posted 30 July 2012 - 08:53 AM
I have a VH Commodore, 253 that I drive to work, it has done 400000kms using 91ULP & hasn't had the heads lifted yet, it gets a bottle fo Flash lube every now & then.
Edited by warrenm, 30 July 2012 - 08:58 AM.
#17 _Quagmire_
but you know the saying if it ain't broke don't fix it
personally for a stocker i'd use 91/95
it's when you chase compression that you need 98
#18 _CHOPPER_
Posted 30 July 2012 - 01:35 PM
That's how I remember it.
#19 _Bomber Watson_
Posted 30 July 2012 - 06:12 PM
From memory out of the text book im reading atm with a big list of various fuels, components, and specific energy etc, Octane actually has less energy than petrol per say, but i may be reading that ass about face....MIT text books confuse me lol.
#20 _CHOPPER_
Posted 30 July 2012 - 08:35 PM
#21 _Inj gtr202_
Posted 01 August 2012 - 10:37 AM
Most likely I'm full of s#%t so correct me as required if the above is bollocks.
Edited by Inj gtr202, 01 August 2012 - 10:37 AM.
#22
Posted 01 August 2012 - 12:16 PM
Drive behind someone running E10 on the freeway and see what that shit smells like when a cars under load, not nice!
You cant generally buy normal unleaded anywhere around here though, its all E10 or premium
#23 _Bomber Watson_
Posted 01 August 2012 - 06:28 PM
Other reason i run premium as a minimum in everything.
#24 _LH8VD69_
Posted 03 August 2012 - 01:32 AM
#25
Posted 03 August 2012 - 06:38 PM
I destroyed a 351 XB engine when they first released unleaded garbage. It was impossible to tune properly and eventually had to redo the heads with stainless seats. Worked a charm after that but still ran an additive (couldnt hurt)
HQ ute 173Cu. Hates anything but premium. Better fuel economy evens out extra cost and have unleaded heads done
Torrie 183 Cu. Hates anything but premium. Better fuel economy evens out extra cost and have unleaded heads done
Subaru 94' 2.2L Can even hear the engine pinging if i use anything but premium and really noticeable power difference on big hills
Gemini - stockish 1.6L - cant remember if they have hardened seats/valves from new but noticeable difference in power if anything but premium used. Not sure about economy
Harley. Dont even think about low octane. It may be able to be tuned to it - never tried - but why risk it for $1.50 a tank?
All in all I just cant justify the possible damage to an engine by using the cheap stuff. One damaged engine is worth more than you will ever save over many years and it is good to have peace of mind
FYI
Damage to an engine occurs BEFORE you can even possibly hear it pinging. This is well known in the aviation industry. Why do you think planes run on much higher octane.
Interesting reading if you look it up.
My 2 1/2 cents worth :-)
